Old 08-07-2013, 10:13 PM   #37036
jglow
Two wheeled traveler
jglow's Avatar
Oddometer: 393
A couple of buddies and I rode a pretty awesome loop around Utah. All of us have 2008 WR250R's. We used some of the UTBDR and filled in the rest with OHV trails, forest roads, blm roads, etc to create a Ultimate Adventure Loop Around Utah.
I am currently working on a ride report here: Ultimate Utah Adventure Route The UTBDR and a Whole Lot More
jordan
jglow is offline   Reply With Quote
Old 08-07-2013, 11:21 PM   #37037
RACINGTHESUN
Oddometer: 116
Thank you!
I want to thank the adventure riders who have helped me out on the bash plate issue. Still am not totally sure what to get the hard plastic or the flatlander aluminum. Plan on doing a ride around Colorado soon, and I definitely need a bash plate for the Jeep trails I ride on. Going to post pics of the places I go.
Connected my Zumo to the new WR tonight. That was a major accomplishment for me. I am almost totally mechanically declined. Wish I could meet another rider around the Boulder/Denver area who would like to ride and could possibly show me how to do some minor mechanical stuff. Even though the GPS was put on, I will have to have the dealership fix the wiring when I take it in for the break in maintenance. It looks like hell, but hey it works...so far
RACINGTHESUN is offline   Reply With Quote
Old 08-08-2013, 07:50 AM   #37038
ohgood
ohgood's Avatar
Oddometer: 2,736
Originally Posted by BENRON View Post
My penny-tech "super moto" set up...
The old style ninja 250 wheels are silly cheap on Fleabay.
Took a handful of custom machined bits and bobs, and I still don't have a big brake on the front, But it seems to handle ok so far
another cheap hooligan modder - sweet !
i'm guessing you had to make:
internal bearing spacers
external axle spacers
caliper relocator (or haven't yet, given the "no big brake yet" part)
did you have to adjust the cush drive any ?
(i finished the drz + gs500/gsf400 wheel setup last month)
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 08-08-2013, 08:01 AM   #37039
ryguy83
ryguy83's Avatar
Oddometer: 98
Has anyone tried or know if the Delta graves exhaust would work with the Megabomb header,i like the look of the graves exhaust but want the performance of the megabomb header. Will they fit together without any problems??
thanks,
-ry
ryguy83 is offline   Reply With Quote
Old 08-08-2013, 08:50 AM   #37040
jon_l
jon_l's Avatar
Oddometer: 3,153
thanks,
-ry
Look what you've done. HardWorkingDog's eyes are bleeding now.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 08-08-2013, 08:57 AM   #37041
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,658
Front: WR stock axle, EX stock wheel, EX stock brake rotor with diameter turned down, different bearings to accommodate axle. Custom spacer to locate wheel left-right and custom center tube.
Rear: custom axle, custom nut, custom spacer to locate the stock EX disc correctly and one to go between the wheel and the brake caliper mount. Stock EX bearings.
Both ends use the stock WR calipers and brackets.
Nice job! It's only penny-tech if you have a lathe and know how to use it
I'm curious why you went with Ninja 250 wheels. They're 16" right?
cjbiker screwed with this post 08-08-2013 at 09:32 AM
cjbiker is online now   Reply With Quote
Old 08-08-2013, 09:23 AM   #37042
jon_l
jon_l's Avatar
Oddometer: 3,153
Originally Posted by jglow View Post
I am currently working on a ride report here: Ultimate Utah Adventure Route – The UTBDR and a Whole Lot More
jordan
Days 1 and 2 are awesome! Looking forward to the rest of your report Jordan.
CBF1000 & PCX150
Old 08-08-2013, 09:27 AM   #37043
BENRON
I'm Mr. Crabtree
BENRON's Avatar
Oddometer: 3,610
Yeah, all Ninja 250's were 16 inch wheels from 88-07 so they're plentiful and cheap.
The new ones look way more swanky and are 17"... But when I was lookin they were harder to come by and more expensive. If I wanted to spend money I'd just get the pre-built Warp 9 setup
BENRON is offline   Reply With Quote
Old 08-08-2013, 10:35 AM   #37044
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,720
...gotta wear shades now
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 08-08-2013, 12:11 PM   #37045
ryguy83
ryguy83's Avatar
Oddometer: 98
Call me stupid,I don't get it,sooooo does it work or no?
Old 08-08-2013, 12:14 PM   #37046
TexaNate
TexaNate's Avatar
Oddometer: 389
Originally Posted by noahdr View Post
Thanks for the quick reply. No, I don't belive it is stripped as the screw does change position, but I cannot find a stopping point or zero spot. I think I went too far screwing it in trying to find that zero.
The compression screw on the bottom of fork makes no clicking at all that I can hear so I have no clue what position its at. The other side of the fork clicks just fine...
Wait, so the screw changes position but if you tighten it, you can just keep tightening it forever as it buries itself in the fork? At the full stopping point, the screw should be pushing up against a locknut on the damper assembly and it shouldn't turn anymore unless you really force it, which will grind the screw into the locknut. I guess if you turned hard enough, you could grind off the end of the screw on the locknut. You may have damaged the adjuster screw or the base valve - the base valve is pretty expensive ($200 OEM) but you can probably find a used set of complete forks on eBay for $300-$400 (that's your worst case scenario). I don't know if anyone sells replacement adjuster screws, I think they're built into the base valve.
However, on my forks, it's also difficult to find a stopping point - it just gradually gets a little tighter and I make an educated guess as to where to stop before I break something. Other guys with other bikes say they definitely have a stopping point but our manual says something like "don't try to force the screw" so I don't push it once I feel strong resistance to turning. I can't say for a certainty but I have a feeling these clickers are somewhat approximate and only accurate to 2-3 clicks anyway (someone correct me if I'm wrong there).
Sometimes it's damn near impossible to hear the clicking - usually I just feel a slight clicking at my screwdriver handle.
Instead of recording clicks, I would just record half-turns to approximately equal the number of clicks on the opposite fork leg (if you can eventually find full-stop).
Good luck!
2014 690 Enduro R
TexaNate is offline   Reply With Quote
Old 08-08-2013, 12:47 PM   #37047
mpatch
Oddometer: 983
I'm in Fort Collins and know the WRR pretty well if you need a hand with anything let me know.
mpatch is offline   Reply With Quote
Old 08-08-2013, 01:29 PM   #37048
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Cheap parts, cheap tires, potentially less unsprung and rotational mass.
I just started this project too. I got straight 05 wheels with the rear cush drive delivered to my door for $67. Both wheels.
bxr140 is offline   Reply With Quote
Old 08-08-2013, 02:05 PM   #37049
simmons1
simmons1's Avatar
Oddometer: 1,513
Is one of you guys willing to put some instructions together and make some conversion parts to sell?
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is online now   Reply With Quote
Old 08-08-2013, 02:22 PM   #37050
noahdr
Oddometer: 11
Good luck!
Thanks for the great response!
Yes, it will bury itslef in the fork. I'm hoping its not broken and I can live with it. I think I just over torqued it and assumed there would be an abrupt stopping point. Not having an abrupt stop kinda makes it difficult to see if we're all using the same clicks. Once I start backing the screw out it will eventually hit an abrupt stopping point so I'm just going to use that as a benchmark and click down (opposite the way the manual states).
I just wonder how much damage has been done and if it is rideable. I guess there is only one way to find that out. If the shock still changes with the clicks then I guess it is still OK.
That's a good idea on measuring the revolutions of the screw. I might have to use that as a fall back if I am not confident that I got both sides of the fork even!
Thanks again for the great response and I'll let you know how it does.
noahdr is offline   Reply With Quote
Times are GMT -7.   It's 03:28 PM.
