Old 08-18-2013, 07:39 PM   #37321
chabon
chabon's Avatar
Oddometer: 293
Originally Posted by Buzzbomber View Post
It does not adjust the rate of accumulation of mileage, rather just the number displayed. In other words, if you find it is off by .1 miles after two miles and adjust it, it will be off .1 miles again after traveling another two miles. It is meant for matching roll chart mileage.
Not very useful to me then. Thanks for the explanation.
Copper Canyon Mexico or Will I Come Back Alive?
Baja Team 6
Barracas Del Cobre
Chabón - F650 Funduro - WR250X
chabon is offline   Reply With Quote
Old 08-18-2013, 08:57 PM   #37322
woofer2609
woofer2609's Avatar
Oddometer: 769
Originally Posted by AZ TOM View Post
Thanks Ba.
Also has anyone replaced just the plastic fan? Don't need the whole motor, it's good just need the fan??
Might be just as cheap to use a fan designed for a computer that is of similar size. I have friends who have used computer fans and found them to be fairly reliable.
woofer2609 is offline   Reply With Quote
Old 08-18-2013, 09:08 PM   #37323
BarKnee
BarKnee's Avatar
Oddometer: 72
Originally Posted by BMW-K View Post
Does anyone make an oversized rear brake pedal or replacement pedal?
I looked around but couldn't find one, so made one up.
BarKnee is offline   Reply With Quote
Old 08-18-2013, 09:34 PM   #37324
AZ TOM
Oddometer: 4,029
Thanks will check that out. Also are there any other complete fans that will fit/work?
AZ TOM is offline   Reply With Quote
Old 08-18-2013, 09:43 PM   #37325
TrailDust&SaddleLthr
TrailDust&SaddleLthr's Avatar
Oddometer: 194
BEST Tail Rack... IMHO... + Screen too...
Originally Posted by RACINGTHESUN View Post
I pretty much know what I plan on purchasing for the WR with the exception of the tail rack. Does anybody know who makes a pretty wide tail rack for the WR? I don't particularly care for the ones that are just as wide as the fender. Any help is greatly appreciated.
Hi! Been away from here for a few weeks and had to catch up.... If you have not yet made up your mind or found the right tail rack for you, THIS ONE should fit the bill...
http://wr250rforum.forumotion.com/t6640-new-billet-cargo-rack-available
Send Jared a PM... he is the NICEST guy and his work is OUTSTANDING! I waited almost 5 years to find the right rack... and Jared was the RIGHT man for the job... handmade and TOP quality.
Drop him a line!
For a Screen.... look for this one out of Australia... also... BEST one on the market for me... and owner is the NICEST person to deal with as well...
http://www.screensforbikes.com/shop/yamaha/wr-250-r-08-12-2/
Also worth the almost 5 years to get it... had to wait till it was designed and produced... well worth the wait... works awesome, easy to install, perfect size and very efficient... what a difference it makes when at higher speeds!
Good luck with your farkling! :)
TrailDust&SaddleLthr is offline   Reply With Quote
Old 08-18-2013, 09:52 PM   #37326
Oddometer: 194
Jared's Tail Rack IS Compatible with Wolfman's Rack...
I saw that one earlier, and I wonder if it can be mounted along with the Wolfman side racks? Looks like they share some of the same areas to place bolts/screws
Here is your answer in pics... scroll down the page a bit...
http://wr250rforum.forumotion.com/t6640p180-new-billet-cargo-rack-available
P.S.: I have NO affiliation with either Jared or Screen for Bikes, just a MOST satisfied customer with their FINE products... NOT made in china... and NOT available at damn walmart!!!... Thanks for small favors! :))
TrailDust&SaddleLthr screwed with this post 08-18-2013 at 10:00 PM
Old 08-19-2013, 07:35 AM   #37327
johninlv
Oddometer: 39
These guys make racks for the wr250r in three sizes.
http://www.automotivemachine.com/ind...d=51&Itemid=56
I have the middle size and it works with my Wolfman rack. Plenty of room even for the large rack.
2004 Yamaha xt225, 2008 Wr250R Works in Progress
johninlv is offline   Reply With Quote
Old 08-19-2013, 07:43 AM   #37328
Caucasian
Oddometer: 28
Bars
So I bent my butter bars, which didn't take long. First lay down, a stupid spill where the bike slid out on an off camber corner with loose dirt.
So now I'm looking for new bars, any opinions?
I'd like to know what bar and mounts I can change to for the most rise with the stock cables and controls. Is there a significant difference in going with fat bars?
I saw Rick Ramsey put the Pro Taper SE CR high bend handlebar on then the Easton EXP woods. I couldn't tell if he had to modify anything. Also, does Easton still make the Pro Taper bars.
Sorry in advance if this has been discussed here before.
Caucasian is offline   Reply With Quote
Old 08-19-2013, 09:13 AM   #37329
ramz
Professional Trail Rider
Oddometer: 2,006
The Pro Taper SE are 7/8" bars, so no modifications necessary. Remove everything from stock bars, remove stock bars, install Pro Tapers, install controls, ride.
I did cut about 3/4" off each end and I did install new grips and handguards, all of which required fiddling with.
The Pro Tapers are available from Rocky Mountain for about $63.
The Easton EXP is no longer made and you'll have a hard time finding them. MotoSport had some clearance sales late last year and I bought 5 sets in different bends. Two woods bend sets went with the WRR when I sold it and the others are sitting on my KTM Freeride 350 farkle pile, waiting for KTM to release the bike in the US...
ramz is offline   Reply With Quote
Old 08-19-2013, 11:13 AM   #37330
rhollamby
Oddometer: 333
rear brake pedal
I need to lower my rear brake pedal. It seems I just adjust the two nuts on the master cylinder, then adjust the sensor for the brake light....but how do I know that I'm not slightly engaging the rear brake?
rhollamby is offline   Reply With Quote
Old 08-19-2013, 11:43 AM   #37331
woofer2609
woofer2609's Avatar
Oddometer: 769
I'd elevate the rear end off ground and spin the wheel before and after adjustments, both should have relatively the same drag . Minute drag is normal.
Old 08-19-2013, 11:53 AM   #37332
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,799
Adjusting the brake lever position does not change the free play of the pedal (which is fixed).
cjbiker is offline   Reply With Quote
Old 08-19-2013, 01:01 PM   #37333
coresports
coresports
coresports's Avatar
Oddometer: 303
nice picture
Originally Posted by DougZ73 View Post
Not the greatest shot since it was with my cell phone, but had I known my riding buddies were gonna bail on me, I could have brought the better camera.
Sometimes,there is something to be said for riding and exploring alone. What is normally a 25 mile/1/2 hr ride on pavement, was turned into a 39 mile- ~2hr ride on as much dirt as I could explore and and find to get me home.
coresports is offline   Reply With Quote
Old 08-19-2013, 01:32 PM   #37334
BMW-K
F800GS FTW!
BMW-K's Avatar
Oddometer: 1,439
Ok, that's a win for me!
2010 F800GS Anniversary - a return to Eden
2011 Yamaha WR250R, 2012 Ducati Monster
2007 R1200GS (Sold)
IBA # 20880. STFU and Ride.
BMW-K is offline   Reply With Quote
Old 08-19-2013, 05:30 PM   #37335
Bogus Jim
Oddometer: 107
1128 miles in 2 days
OK, 1128 miles in 2 1/2 days, to be exact. Took the WRR for a weekend ride, on the Trans South Dakota Adventure Trail. If you ever have a need to ride across South Dakota, it's a much more scenic route than I-90.
Here's a teaser photo...
and a ride report on our local website (I didn't post it on ADVrider)
Riding the TSDAT in 2 days
2012 800 XC
2009 WR250R
2008 250 XC-W
Bogus Jim is offline   Reply With Quote
Times are GMT -7.   It's 05:02 AM.
