Old 09-08-2013, 05:18 PM   #37786
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,472
Originally Posted by godwinmt View Post
On a more positive note, I put together a rear rack for mine today. Needed something more substantial than the stock luggage plate to hold the duffel for any sizeable trip, so I went walking through Menards and pieced together something that would work well. It's all bolt together since I'm welderless together, and is made primarily from 1"x1/8" thick aluminum angle, some 3/4" aluminum square tubing for the mounts to the bike, and some miscellaneous corner brackets to hold it all together.
And the bike loaded up:
-M
Dangerous that.
Bikes with a flat rear plastic end and frame rails don't need racks. The Wolfman and Kriega methods are sufficient. Nothing you can't do with straps.
tmotten is offline   Reply With Quote
Old 09-08-2013, 05:49 PM   #37787
Dirtpatch
Oddometer: 81
Ims tank how do you get all the fuel out
Bought a used wr and drained the 4 gal ims tank to fuel starvation. Good news went 100 miles on reserve. Bad news is had a couple inches in the wings where I could see gas left. Over the winter what do I adjust to run the wings dry.
Dirtpatch is offline   Reply With Quote
Old 09-08-2013, 07:09 PM   #37788
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,129
YZ front end on WRx
What do you do when you have a 2000 YZ250 front end with 21" tire on an XT550 and want an sm wheel on it and you own an 08 WRx and want a 21" tire on it... swap forks and brake calipers of course
This was my brother-in-laws Sunday project today... According to him the forks swapped over easy as can be, biggest pain was bleeding the brakes. The XT used to be his trail machine, but now he is thinking it will make a better sumo... I would agree with him there.
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 09-08-2013, 07:46 PM   #37789
what broke now
Petroleum Brother
Oddometer: 1,425
Aren't the yz forks longer than the wr's?
what broke now is offline   Reply With Quote
Old 09-08-2013, 09:19 PM   #37790
pilacs
pilacs's Avatar
Oddometer: 72
Question Can it bedone???
Hi all, I'm thinking of buying one of these magic machines. Would the little machine be a good stablemate for my 990adv!? I'm planning a route from Florida to Canada to South Korea,Siberia,Mongolia and to Eastern Europe for next summer,about 12,000 miles. Would that be to much to ask from a 250R? I'm 6'1" 220. Thanks
pilacs is offline   Reply With Quote
Old 09-08-2013, 11:53 PM   #37791
skierd
Wannabe Far-Rider
Oddometer: 2,956
Too much? Hell it'll barely be broken in by then. If you're not looking to cruise at 80mph the whole time it's a great choice of travel bike. Mine broke 40000 miles leaving Deadhorse doing 90+mph with a weekend camping load. It's a durable bike.
Those who've had engine issues typically have abused and really beat on their machines. Drowning, dirty air filter, running low on oil somehow, etc.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 09-09-2013, 07:19 AM   #37792
BluePill
AARP Slacker
BluePill's Avatar
Oddometer: 4,900
One concern might be fuel quality & octane. Yamaha recommends 91 octane due to the high compression (11.8:1) and dirty fuel is tougher on high pressure fuel injection systems than carbs. Any failure of a high tech system in the boonies is a real problem. A basic air-cooled and carbureted motor is a lot easier to cobble a fix.
You might want to research some ride reports here on ADV for the areas that you are going to, and see what experiences other riders have had.
2008 WR250R - Tru Blu
"While we live, let's live"
BluePill screwed with this post 09-09-2013 at 07:27 AM
BluePill is offline   Reply With Quote
Old 09-09-2013, 07:29 AM   #37793
Luke308
Luke308's Avatar
Oddometer: 425
WR250R Won't Start
After changing my chain and sprockets, spark plug, etc. I rolled the bike outside and tried to fire 'er up. Fuel pump was priming, it turned over, bike in neutral, side stand up, etc. but not starting.
Started to run through in my mind everything I touched that I should go back and check, but I jumped on Google, typed in "WR250R won't start", read about the little trick of starting the bike with the throttle wide open, went outside and it fired right up. That's a good Ace to have up your sleeve before you go take apart the entire bike looking for the problem...
Oh, and this chain tension thing has me running around in circles, seems like half the folks here think it should be tight, the other half think loose, and when I push up on the chain the new chain slider interferes before I can get a good measurement from the swingarm.
Luke308 is offline   Reply With Quote
Old 09-09-2013, 07:47 AM   #37794
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,125
Originally Posted by Luke308 View Post
This picture worries ma tad bit. Overall, the slider does not look that worn compared to the new one right next to it. Looks nasty, but not worn too bad.
What front sprocket were you running?
EDIT: Check that...just realized I was looking at the top side not being too different..then realizing the bottom side is completely worn away.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 09-09-2013, 07:58 AM   #37795
TwilightZone
Oddometer: 3,110
>"the other half think loose,"
Yup. Run a 14 tooth sprocket in the front. 50 or 51 on rear.
8K miles now on that setup...
The swing arm guard shows no wear on the bottom.
(I wore 4 of em out in the first 10K miles on the 250, 13T sprocket).
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 09-09-2013, 08:02 AM   #37796
Luke308
Luke308's Avatar
Oddometer: 425
Yep, it was the bottom side that is causing me headaches. I regreased my swingarm bearings last night and sure enough the bearings directly beneath the chain "furrow" have been compromised and are tough to spin by hand. I did not have the foresight to check that before I epoxied the furrow, so I'm unsure if it was from the hole itself, or my epoxy getting down in there. I'll have to fix it in the future, but I'll keep riding it in the meantime. Yes, it will wear funky, but I don't feel like it will make my swingarm fall off either...live and learn, eh?
Luke308 screwed with this post 09-09-2013 at 08:13 AM
Old 09-09-2013, 08:03 AM   #37797
Luke308
Luke308's Avatar
Oddometer: 425
How loose is "loose"?
Just installed the 14/50 combo.
Edited to add: I didn't realize how much the 50T reduces the clearance on the rear chain guide. Not a lot of gap there, but I guess at that point it's not a big deal since everything is pulled straight and tight at that location.
Old 09-09-2013, 09:52 AM   #37798
jon_l
jon_l's Avatar
Oddometer: 3,287
We keep perpetuating the idea that front sprocket size is the cause, but plenty of folks are running 12 and 13 sprockets without chewing up the sliders. I think after years of discussion, all we know for sure is that it must be caused by a combination of factors.
Theories include front sprocket size, loading, and chain tension (both loose & tight).
I have ~3,500 miles on a 12T front and minimal slider wear.
CBF1000 & PCX150
jon_l screwed with this post 09-09-2013 at 04:09 PM
jon_l is offline   Reply With Quote
Old 09-09-2013, 10:08 AM   #37799
simmons1
simmons1's Avatar
Oddometer: 1,538
Originally Posted by jon_l View Post
We keep perpetuating the idea that front sprocket size is the cause, but plenty of folks are running 12 and 13 sprockets without chewing up the sliders. I think after years of discussion, I think all we know for sure is that it must be caused by a combination of factors.
I agree. I just changed mine out at 11.5K miles while I was doing other maintenance. It looked to be just over 50% worn through. I have used 12 and 13 tooth sprockets for the all of the mileage.
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is offline   Reply With Quote
Old 09-09-2013, 10:21 AM   #37800
coresports
coresports
coresports's Avatar
Oddometer: 305
you can destroy any bike by not breaking it in properly usually ending with a major motor malfunction at a much later date or by not properly maintaining it and at the same time running the crap out of it.
i have owned several yamaha dirt/dual sports over the past 40 years and this one is the best i have seen so far. they are about as reliable as you can get, imo.
Originally Posted by freetors View Post
I'm starting to dislike this thread. It's really making me question the reliability and longevity everybody thinks these bikes should have. Engines just should not have internal failures with less than 30000 miles unless they are really highly tuned or beat to hell.
coresports is offline   Reply With Quote
Times are GMT -7.   It's 12:02 PM.
