Old 10-10-2013, 06:24 PM   #38461
keiji
Oddometer: 1,111
Originally Posted by rvsixer View Post
Also curious. It's my understanding the tightest chain condition occurs when the front sprocket, swingarm pivot, and rear axle points all line up in a straight line. Not sure how side stand vs. lift would matter in that case?
Typically I get these three points aligned, then firstly adjust the the chain so it has about 1/2" give between sprockets, then secondly (and ONLY IF NEEDED) loosen a bit more so there is no direct tension/forced rubbing on the plastic sliders.
For what it's worth, the technical service bulletin says to adjust ON the side stand whereas previously the service manual said to perform the adjustment on a lift. From my understanding, there was accelerated wear on the guards (mostly because you ride with sag, not with the rear wheel in the air.)
https://docs.google.com/file/d/0B6Av...it?usp=sharing
keiji is offline   Reply With Quote
Old 10-10-2013, 06:29 PM   #38462
drifter dave
drifter dave's Avatar
Oddometer: 134
I swear, half of this colossal thread is dedicated to chain tension. My method is to get onto the bike, with any gear I might be carrying and check for slack with the full weight of rider on board. It should be pretty obvious at this point if you are running too slack or too tight.
I'm at 13,000 kms and little swingarm guard wear.
I personally would never trust a chain tension measurement done with the bike unloaded: there are too many variables in play; rider weight, sag setting, sprocket size, etc.
Vancouver to Belize and back:
http://www.advrider.com/forums/showthread.php?t=544121
drifter dave is offline   Reply With Quote
Old 10-10-2013, 07:09 PM   #38463
debaisley
debaisley's Avatar
Oddometer: 1,424
+1
6 bikes in my garage , my chain tension measurment is " a little bit of slack when the suspension is compressed" no numbers , no rulers
16K on my WR , swapping wheels back and forth , one with a 42T and one with a 47
chain slider still about 60%
debaisley is offline   Reply With Quote
Old 10-10-2013, 08:41 PM   #38464
crunchiespg
Oddometer: 1,044
does anyone do an adventure/rally kit for the wr250r? something like this..
something with huge tanks, bit of wind protection, better headlight options etc..
crunchiespg is offline   Reply With Quote
Old 10-10-2013, 10:08 PM   #38465
woofer2609
woofer2609's Avatar
Oddometer: 769
I'm really trying to look at the practical side of this design, and not trying to be rude, but somehow this rally fairing business really takes away from the beauty of not only these bikes, but most bikes in general. I'm all for big tanks and better headlights (oh how I wish this bike came with a round headlight, big design mistake IMHO) but the beak is, well... maybe I'm just old fashioned. I am sure they are practical. But so were Pontiac Aztecs.
Unless it's stuffed with electronics, I am curious as to the benefits of the high er...nose. I have never been bothered by the air flow on this bike.
woofer2609 is offline   Reply With Quote
Old 10-10-2013, 10:29 PM   #38466
crunchiespg
Oddometer: 1,044
i guess beauty is in the eye of the beholder. I love the look of rally bikes. The rally ktm 690's for example look great.
However I'm not concerned about looks. But I am so overwhelmed by how versatile this bike is I think a rally kit would work great to make it even better for long journeys while still being off road worthy.
Old 10-10-2013, 10:35 PM   #38467
juun
Oddometer: 23
I swore I had a similar kit bookmarked at one point but it was on the opposite side of the pond and I remember correctly was going for 1500 usd. Of course I can't find it now.
juun is offline   Reply With Quote
Old 10-10-2013, 10:45 PM   #38468
Wallrat
Wallrat's Avatar
Oddometer: 730
This is the best write up of adjusting chain tension I've ever seen. A bit involved the 1st time, but after that its a cinch.
http://www.dualies.com/downloads/fil...Adjustment.pdf
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 10-11-2013, 12:49 AM   #38469
mramosc
mramosc's Avatar
Oddometer: 152
There is a guy that sells something somewhat similar, see post 72 of:
http://www.advrider.com/forums/showt...=622796&page=5
mramosc is online now   Reply With Quote
Old 10-11-2013, 04:16 AM   #38470
Fistful of Bacon
Oddometer: 92
Originally Posted by Earth Rider View Post
It'd probably be easier if you posted what you are looking at and we told you yea or nay.
Well theres been all 08's, one with 1200 miles for 4k, one with 4000 miles and road rash for 3.8, and an x with 14k miles for 3.6. Those have been the only ones in the area for 2 months or so
Fistful of Bacon is offline   Reply With Quote
Old 10-11-2013, 04:23 AM   #38471
AdvNener
Oddometer: 42
For wind protection (adjustable screen),headlight options and a big dashboard, there is the lynx fairing. Not used it by myself (but considering it), but some on this megathread did:
http://www.britanniacomposites.com/i...-yamaha-wr2506
You still have to find a bigger tank after that.
AdvNener is offline   Reply With Quote
Old 10-11-2013, 04:29 AM   #38472
rvsixer
Oddometer: 72
Thanks for that link, I have seen that TSB (imo written to sell special tools LOL). Its apparent from the various WR sites/threads those that have followed it still experience accelerated chain/slider/swingarm wear (and led me to research the root cause and find an alternative method).
By adjusting the chain tension at the tightest possible position it can ever physically be in through its entire travel (i.e. with front sprocket, swingarm pivot, rear axle all in a line), you guarantee the chain will never be too tight at any other point in suspension travel. No special tools are needed, its non-bike specific, it doesn't matter if the chain is adjusted on the sidestand or a lift or floating in space; rider weight, rider sag, sprocket sizes etcetera are all non-factors.
Those who are adjusting by sitting on the bike all geared up and adjusting chain tension at that variable sag point, and experiencing excellent service life, are IMO either:
1) Able to ride in a manner that rarely exercises the rear suspension to the point of maximum chain tension on a regular basis
2) Just plain lucky their riding weight gets the front sprocket, swingarm pivot point, and rear axle in a straight line before adjusting chain tension
To illustrate, I am 220 lbs/100kg, and all geared up I have about 4" rider sag. This is not enough sag to get the swingarm up to the point of maximum chain tension. Hmmm next time I adjust the chain I will measure and report the exact sag required to get the three points in a row .
rvsixer is offline   Reply With Quote
Old 10-11-2013, 04:49 AM   #38473
dnsjo
dnsjo's Avatar
Oddometer: 27
Originally Posted by Fistful of Bacon View Post
been in the market for a wrr for a while, anyone know some price ranges for used ones? ive seen a couple that were on sale that seemed a bit expensive, and looked at KBB and NADA, but those prices seemed too cheap for what ive been seeing, thoughts?
I only landed one by checking this site once or twice a day, and not wasting any time when the right one showed up.
http://www.bikefinds.com/yamaha-wr250r-for-sale
Happy hunting.
dnsjo is offline   Reply With Quote
Old 10-11-2013, 05:02 AM   #38474
Earth Rider
Oddometer: 2,994
1200 miles for 4k sounds pretty great to me.
Earth Rider is offline   Reply With Quote
Old 10-11-2013, 06:14 AM   #38475
shortbritches
Oddometer: 105
Fistful sent you a pm
"I will not follow where the path may lead, but I will go where there is no path, and I will leave a trail". Muriel Strode,1903
2012 KTM 350 EXCF - 2008 WR250R
Kelley Joe
shortbritches is offline   Reply With Quote
Times are GMT -7.   It's 12:27 PM.
