Old 10-19-2013, 08:12 PM   #38686
BluePill
AARP Slacker
BluePill's Avatar
Oddometer: 4,909
Originally Posted by mtntrails View Post
2009 WR250X
So, I'm checking the owners manual for oil capacity and noticed a "burping" procedure mentioned to check for proper oil pressure. The check valve is on the rear of the cylinder on the left side.
Is this part of the normal oil change procedure or a separate procedure just to check oil pressure?
If you only change the oil filter every second oil change, as per the factory schedule, I see no reason whatever to burp the system when changing the oil only, since no air is introduced into the system. To be cautious, it might pay to burp when changing the filter.
2008 WR250R - Tru Blu
"While we live, let's live"
BluePill is offline   Reply With Quote
Old 10-19-2013, 09:25 PM   #38687
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,522
My take on the manuals reason for doing this isn't to remove air from the system, its to check oil pressure, since it doesn't have a low oil pressure light.
I guess if you manage to install the oil filter wrong you would have a pressure issue. I did the check once the first time I changed oil. After cleaning up the huge mess I never felt the need to check it again.
I'd say if you sleep better at night knowing you did your oil change by the book then I would recommend doing the check.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Old 10-20-2013, 07:21 AM   #38688
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,442
Originally Posted by SR1 View Post
Hey guys, does anyone know of a good, easy to fit, front fender support? Something to keep it stiffer when a tube bag is fastened on? Thanks!!
Hey guys, thought I'd ask again, just in case some folks missed it. :)
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is online now   Reply With Quote
Old 10-20-2013, 01:30 PM   #38689
skierd
Wannabe Far-Rider
Oddometer: 2,957
Originally Posted by debaisley View Post
readily available at a hardware store , thanks
anyone know if the plug on the vacuum port on the throttle body is susceptible to the same type of rot /cracking ? should I pull the tank and take a look ?
It is and you should. I got tired of replacing it every season (it cracks that fast, as does the AIS plug) so I slathered the last replacement in black RTV silicon. Been 3 years and no issues. For the AIS, I just put the AIS system back on.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 10-20-2013, 02:44 PM   #38690
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 419
Reinstalled the AIS......why?
2011 UPAT
rubberband is offline   Reply With Quote
Old 10-20-2013, 03:22 PM   #38691
skierd
Wannabe Far-Rider
Oddometer: 2,957
Because the rubber caps I and most everyone uses to plug the hole on the airbox kept rotting. I went through 4 or 5 in a year and a half, and at least three separate times I found the top of the cap basically missing letting a bunch of unfiltered air in to my airbox behind the air filter so I decided it wasn't worth the 8oz weigh reduction to remove the system. YMMV.
And the same goes for the flapper valve cap on the throttle body. Regular rubber caps will rot and let unfiltered air in to the throttle body. Check and replace them every time you have the tank off, cover the next cap with silicon so it cant rot, or leave the flapper valve system alone. I'll probably opt for the third option should I ever replace my WRR.
2008 Yamaha WR250X
Old 10-20-2013, 05:30 PM   #38692
sieg
sieg's Avatar
Oddometer: 2,861
I've had a tube and tire irons and co2 on my fender on the WRR forever with no issues, And my WRF which gets beat harder, and I think it uses the same fender. So you may not need one. Look for some vintage parts like the old Honda Elsinore.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is online now   Reply With Quote
Old 10-20-2013, 06:30 PM   #38693
malignity
The Hurt Locker
Oddometer: 397
My buddy and I took our WR250R's (his 2008, mine 2010) out for a 105 mile ride today. I just removed my EXUP servo, AIS, and installed an FMF programmer, etc.
Less than 500 feet into my ride (first bump I guess?), my horn started blaring uncontrollably by itself. I simply pulled over and unplugged it, but does anyone know what would cause it to do that by itself? The bike has just over a thousand miles on it.
'10 Yamaha WR250R , '93 Yamaha TW200, '03 Honda Foreman 450ES 4x4, '96 Yamaha Big Bear 350 4x4. www.gldsmc.org
malignity is offline   Reply With Quote
Old 10-20-2013, 07:38 PM   #38694
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 1,084
Yeah, pretty sure they all do that - it's just to tell you the battery's fully charged. Mine's done that since new. I just wear ear plugs, never thought of disconnecting it.
Reeksy screwed with this post 10-20-2013 at 08:14 PM
Reeksy is offline   Reply With Quote
Old 10-20-2013, 09:17 PM   #38695
Llamaha
Oddometer: 849
Yes mine too, I just listen to my audiobooks and it drowns out the noise. If anything it makes you safer on the road because the surrounding vehicles are aware of your presence.
Llamaha is offline   Reply With Quote
Old 10-20-2013, 09:18 PM   #38696
Reeksy
Reeksy's Avatar
Oddometer: 1,084
True - but it shits the HD riders as it takes attention away from them...
Old 10-21-2013, 03:28 AM   #38697
malignity
The Hurt Locker
Oddometer: 397
So is this seriously a common problem or are you guys all pros at trolling? Lol
Its nice having a horn, no way to signal the leader of a ride otherwise if you need to stop for something.
Old 10-21-2013, 05:02 AM   #38698
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,442
Wow, I put an HD tube on the fender alone (in a bag of course) and it was floppin' around everywhere. Hmm...
Old 10-21-2013, 07:10 AM   #38699
woofer2609
woofer2609's Avatar
Oddometer: 780
Are you sure you have all 4 bolts holding the fender on? They are notorious for falling off. How close to the headlight are you attaching the bag? I found the headlight is pretty low...
woofer2609 is offline   Reply With Quote
Old 10-21-2013, 07:13 AM   #38700
woofer2609
woofer2609's Avatar
Oddometer: 780
Not normal. Follow the wiring and check the switch. Shouldn't be too hard to isolate...
Times are GMT -7.   It's 05:39 AM.
