Old 02-15-2014, 06:13 AM   #40306
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,803
Looks like one of the swing arm linkage nuts.
cjbiker is online now   Reply With Quote
Old 02-15-2014, 06:15 AM   #40307
4play
Next?
4play's Avatar
Oddometer: 2,592
Originally Posted by cjbiker View Post
looks like one of the swing arm linkage nuts.
+1
Family isn't always about blood
4play is offline   Reply With Quote
Old 02-15-2014, 06:19 AM   #40308
sieg
sieg's Avatar
Oddometer: 2,849
Originally Posted by xathor View Post
I pulled my WR in the house the other day to grease the swingarm bushings and replace the plastics. After several days and cleaning up I found this on the floor.
I removed the EXUP and the AIS... I just can't seem to remember where on earth this nut came from. Usually when I take something apart I put all the fasteners back where they came from so I don't have to look for them later. This nut is a mystery!
A 17mm hex, self locking nut, would fit the lower shock bolt. And from my search that is the only place on that bike that such a nut is used. The top shock nut is not self locking and the other suspension and swingarm self locking nuts have a 19mm hex.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 02-15-2014, 07:30 AM   #40309
Creekgeek
Custom Sarcasm Dir.
Creekgeek's Avatar
Oddometer: 1,106
Put on reading glasses. Now see 17 on wrench. Nice pull dudes
Creekgeek is offline   Reply With Quote
Old 02-15-2014, 12:57 PM   #40310
xathor
Not actually Gnarly
Oddometer: 448
Unfortunately all those bolts have nuts on them...
2014 KTM 690 Enduro R (21/18 & 17/17's)
2008 Subaru STi (e85 powered beast, ~500hp)
1998 Land Rover Discovery (daily driver)
Past: 800xc, WR250R, 450EXC-R, KLR
xathor is offline   Reply With Quote
Old 02-15-2014, 01:13 PM   #40311
r6realtor
Oddometer: 222
looks good, what size tire do you have up front?
r6realtor is offline   Reply With Quote
Old 02-15-2014, 02:29 PM   #40312
xathor
Not actually Gnarly
Oddometer: 448
90/90-21?
I don't remember. Whatever the stock size is in D606's.
Old 02-15-2014, 02:53 PM   #40313
Whitehall
Easy Does It
Oddometer: 12
First ride
Well, I just ran my first tank of gas thru my wr250r. What a blast!
It was a new leftover 2013, and it's just been sitting in my garage for weeks due to weather and my work schedule.
Now I'm in the garage adjusting ergos and tightening the bolt that attaches the front brake line to the fluid res. It came loose and I lost my front brake momentarily. Luckily I was in a parking lot moving slowly.
I've learnt a ton from this forum, and will be hanging around. I'm a relative newb, but would like to hook up with folks for rides this Spring.
Whitehall is offline   Reply With Quote
Old 02-15-2014, 03:15 PM   #40314
AdvRich
Parallel Reality
AdvRich's Avatar
Oddometer: 1,797
Looks like your covered there. Maybe check up under the top triple tree to ensure that both the nuts that hold on the lower handlebar clamps are still on as it is the same size and style.
"If you do not change direction, you may end up where you are heading." Lao Tzu
AdvRich is offline   Reply With Quote
Old 02-16-2014, 04:51 AM   #40315
philp38
philp38's Avatar
Oddometer: 3,243
Been researching rear racks for the WR and like the Cyclerack. I had one on a TW200 and liked how well you could load it. My wife also liked it due to the fact she had hand holds while riding as passenger. It looks like it tucks out of the way on the sides (where it mounts). Any pros or cons? I have to admit it looked better on the TW than the WR.
Temple Lodge,No 25.F.& A.M. Winthrop Maine
Paddle faster I hear banjos
philp38 is offline   Reply With Quote
Old 02-16-2014, 10:12 AM   #40316
what broke now
Petroleum Brother
Oddometer: 1,412
I use one on mine and lay a two gallon rotopax on top.
, which fits perfectly. That is attached with velcro one-wrap straps to the bars of the rack. Sometimes a tank bag sits atop the rotopax with a net over that. Iv'e crashed many times with that setup and the rotopax stays put.
I don't ride two up, so I haven't tested it that way. It takes about 15 minutes to bolt on or off once you get used to it. It makes a nice handhold or pickup point if you fall, and protects the rear signals.
Not very bling-like, but real handy.
what broke now is offline   Reply With Quote
Old 02-16-2014, 11:00 AM   #40317
xaman
Oddometer: 556
I had something similar on a different bike, with the rotopax attached 90% of the time. My passenger actually preferred the rotopax to stay on, as it became a sort of very low backrest. She said it made her feel better about "not falling off"...
xaman is offline   Reply With Quote
Old 02-16-2014, 11:55 AM   #40318
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,654
Servicing my forks today. Do you guys want a step-by step with pics?
henrymartin is offline   Reply With Quote
Old 02-16-2014, 12:09 PM   #40319
dazler
Oddometer: 178
which No Toil filter to use?
http://www.rockymountainatvmc.com/p/...=1392566400673
or
http://www.rockymountainatvmc.com/p/...Filter?v=10553
Do the wr250 need the cage on the 1st link or the one on the second link be just fine plus the metal holder that is already on the air box
BTW the bike have a K&N filter now, but due to the dirt that is like dust in my area I would need better protection.
WR250X/R
http://www.webbikeworld.com/Motorcyc...-standards.htm
Motorcycle Clothing Safety Standards
dazler is offline   Reply With Quote
Old 02-16-2014, 12:14 PM   #40320
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
Yes please
oxygenrace is offline   Reply With Quote
Times are GMT -7.   It's 03:26 AM.
