Old 03-23-2014, 09:28 PM   #40891
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 1,098
Looking good!
Nice work Henry.
hey - love that rack. I've got one just like it
That sand is so white!!!
Reeksy is offline   Reply With Quote
Old 03-23-2014, 09:53 PM   #40892
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,621
Originally Posted by avc8130 View Post
Krabill,
WAIT A SECOND!!!
Did you put those friction discs in DRY?!?!?!?!
Unless the WR is an anomaly (edit: checked the service manual the WR is NOT an anomaly), you need to soak those frictions in clean oil BEFORE assembly!
ac
Curious about that also. However, the rest of the write up is confidence expiring. Thanks.
EDIT: See you did soak them, good job sharing.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX screwed with this post 03-23-2014 at 11:23 PM
Scott_PDX is offline   Reply With Quote
Old 03-23-2014, 10:28 PM   #40893
Bkblitzed
pinging
Oddometer: 6
Originally Posted by 4play View Post
The Edge 2 although it does look better has three major issues that kept me from going that route, it's no where near as bright as stock & I want to be seen, it's prone to water getting in and damaging it & third it doesn't protrude down or back far enough to keep the mud off of the light & more importantly you. I choose function over looks.
Look at the back edge of the tire, draw a line from the back edge of the tire & the lowest part of the tail light/license plate & that's the mud path.
I wacked off the lower section & cut out a piece of ABS to mount the plate on.
Then I used Highway Dirtbike turn signals where the stock signals used to be. Tucked in tight, should be out of harms way & they are very bright,
Im all for functionality over looks, but the actual plastic that holds my blinker is broken. Is there any other company that makes a whole new piece?
Bkblitzed is offline   Reply With Quote
Old 03-23-2014, 11:19 PM   #40894
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,377
Yamaha WR250R Mega Thread
Originally Posted by Bkblitzed View Post
after dropping the bike today, my left rear tail turn signal broke off the plastic. Im still deciding on buying the Edge2 Integrated Tail Light with the 12 oclock lab and for the front the drc type 602's. Anyone run these? How are the durability on the fronts? Or since i need hand guards, should i just buy the zeta handguards with the built in turn signals? I still have the stock bars and them being 7/8 I wouldn't think there would be a problem with the zeta handguards, or am i wrong?
The drc lights are junk, we t thru three of them before I finally got something that worked and worked well. First two got wet, muck in them, so third on I sealed up really good and still wet muck. I went to the chopped stocker route for awhile until I looped it out on the ice lat year and broke it off. So early last spring went to ktm exc300 tail light. Needed to form my own aluminum bracket but built it right from scratch, plate holder, turn signal mounts and tail light mount.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 03-24-2014, 04:01 AM   #40895
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,306
Nice write up Krabill.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 03-24-2014, 05:28 AM   #40896
avc8130
Oddometer: 1,630
Sewerat,
That tail light looks GREAT! Really modernizes the ass.
ac
avc8130 is offline   Reply With Quote
Old 03-24-2014, 06:17 AM   #40897
sieg
sieg's Avatar
Oddometer: 2,890
Originally Posted by Krabill View Post
Then you have to get the brake lever out of the way. There is a clip behind the bolt that holds the lever on that has to come off first. Then there is a washer. Then the bolt will screw right out with a 6mm allen wrench. Once the brake lever is loose, take the return spring off and disconnect the brake light switch. It doesn't need to come off completely, you just need to unhook it from the brake lever itself.
A little time and trouble saving tip: Spread the brake pads apart, then the pedal can be pushed full travel till it hits the foot peg, zip-tie it to the food peg in this position and you don't have to remove it.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 03-24-2014, 06:22 AM   #40898
Krabill
Krabill's Avatar
Oddometer: 4,893
Very good tip!
I would imagine, however, that very few people take the time to service the brake lever pivot very often. It needs to be greased every now and then and this was a great opportunity to clean and re-grease the pivot bolt since the tools were out. Getting as much preventative maintenance done with very little extra effort prolongs the life of your motorcycle.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 03-24-2014, 07:19 AM   #40899
coresports
coresports
coresports's Avatar
Oddometer: 319
great write up.
20,000 miles and my clutch gave up the ghost
What to do if this happens to you . . .
The first thing I do is get all of my parts and information ready. Got the parts, then I printed out the two pages from the Service manual dealing with clutch replacement. Don't worry if you don't have a manual. I'll tell you everything you need to know from those two pages. It's a very simple procedure.
Next, you drain the oil.
Brake lever hanging loose.
Here's a shot of the parts that come off.
Once that is out of the way, you can remove the clutch side plastic cover. It's just three 8mm bolts.
Nekkid clutch cover
Some more 8mm bolts need to come out. I keep them in order by placing them in their respective positions on a paper towel. This helps keep everything organized.
Once the cover is off, this is what you're looking at. From here, it's just (5) 10mm bolts. We're almost there.
Here's what it looks like with the (5) bolts loose. Don't worry, those springs won't come flying off or anything.
The cover will pull right off giving you access to the clutch plates.
Here are the parts that have come off all laid out and organized.
Pull the old clutch plates off.
The old stack. They're burnt.
New parts!!!! You can see I ordered new springs to go with the new clutch plates. I figured since I was in here, I might as well freshen it all up.
Here's a comparison of a really burnt disc and a brand new disc.
From there, it's a simple matter of stacking up the new ones. Clutch plate, disc, plate, disc, etc.
A note here, and the picture I took doesn't show it, but the clutch plates and discs need to be soaked in fresh, clean engine oil before assembly. Failure to do so can lead to very quickly burnt clutch plates, and you're back to square one.
This is what you need the manual for. The torque specs
The (5) bolts that hold the cover on and the springs are to be 5.8 ft/lbs - or 70 inch/lbs. Don't confuse the two. A 1/4" torque wrench is usually adjusted in inch/lbs.
Once that is done, it is a simple matter of replacing the cover. All of the 8mm bolts that hold the main clutch cover and the plastic cover over that are to be torqued the same according to the Service Manual. 7.2 ft/lbs or 86 inch/lbs. Again, don't confuse the two.
Re-mount your rear brake lever and fill the engine with oil.
Congratulations. You're done. Without stopping to take pictures every 3 minutes, it's probably about a 20 minute job if you take your time.
I hope very few people have this problem, but if you do, don't sweat it. It's a quick and easy fix.
coresports is offline   Reply With Quote
Old 03-24-2014, 07:36 AM   #40900
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,643
Krabill,
WAIT A SECOND!!!
ac
Edit:I Ok now I see you did....sorry I didn't read far enough down the page.
Good job.
That was going to be my comment I always soak the disk in oil before you assemble.
I guess you could fill with oil and lay the bike on it's side for a while??
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 03-24-2014, 07:49 AM   #40901
Krabill
Krabill's Avatar
Oddometer: 4,893
Good job.
Fred
I guess my "clean" pictures are causing a rukus I'll get the wet pics up tonight to clear up the confusion.
Loud Sucks!
Old 03-24-2014, 08:50 AM   #40902
Jäger
Osons
Jäger's Avatar
Oddometer: 803
Originally Posted by MeefZah View Post
Except that 120+ starts probably toasted my battery!!!!
Actually, the OEM battery is probably the most durable battery I have ever used. I think everyone I know with a WR, and me, are all still on the original with nary an issue...
Not me. Original battery gave up the ghost last year. Had the bike since '08 with over 50,000 on the clock, the riding seasons up here a few miles to the west of the Continental Divide are a little shorter than, say Florida, and it spent its winters on a battery tender.
Started getting weak starts, and then on one stop on a ride I forgot to turn the ignition off after I stalled the bike while stopping to take a quick picture. Just sat astride the bike for the two minutes or so to dig my DSLR out of the tank bag, set up, and take the pics. Wouldn't fire after that; wouldn't turn over fast enough to catch. Happily, I was on a grade and a good rolling bump start solved the issue.
I was about 50 miles from civilization at the time, so I took that as a hint and put a new battery - same as the original.
Not complaining about the original battery in the least; it didn't owe me anything after that many years and mileage. But it reinforced the reality that batteries do have a life span even with proper care and minimal demands put on them. I rolled the dice by heading into the mountains solo (as usual) with a battery that was telling me it was getting weak. At nearly 60 and with over 50 years of riding, you really shouldn't do stupid stuff like that. But I did, and nearly set myself up for potentially a long, long walk...
Batteries are cheaper than boot soles.
Jäger is offline   Reply With Quote
Old 03-24-2014, 10:34 AM   #40903
jon_l
jon_l's Avatar
Oddometer: 3,375
Originally Posted by Drannen View Post
After the Winter mod sessions
Cool bike Drannen!
It would look even better of you take those warning stickers off the tank and swingarm.
CBF1000 & PCX150
jon_l screwed with this post 03-24-2014 at 10:43 AM
jon_l is offline   Reply With Quote
Old 03-24-2014, 11:45 AM   #40904
Bkblitzed
pinging
Oddometer: 6
thanks for all the suggestions, and info. I can't fab my own stuff just because i dont own a welder, and my friends welder is shit lol. That being said, it'll be much easier for me to buy an already rear tail light assembly. Now is edge and the OEM the only ones that come with both the brake+turn signal?
Old 03-24-2014, 12:59 PM   #40905
camaroz1985
Oddometer: 172
I can't believe no one mentioned the blue elephant in the room. Nice Viper!! Makes me wonder who has the biggest contrast between their cage and their WRR?
camaroz1985 is offline   Reply With Quote
Times are GMT -7.   It's 01:48 AM.
