10-08-2009, 05:10 AM
#7666 | |
Bike-aholic
Oddometer: 2,064
He makes a living at it....I don't. So I figure I've had it backwards too. After hanging around his shop for several days and experiencing the benefits of his workmanship firsthand, I'm throwing in with him. Call me a Stinkbug Convert. I think the important point is obviously the handling characteristics, not the name. Out of balance either direction can wreck havoc on the handling & stability qualities. Both scenarios are bad for a bike, but front high and rear low is definitely the worse of the two (IMO). Its creates a handling nightmare, and its the most common due to rider height issues (i.e. lack of inseam). Many just lower their back-end so they can reach the ground, and wind up with a bike significantly out of balance....creating too much Rake for their frame geometry, and get poor handling in return. Whatever its called, its a major no-no. HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 BMW F800GS, '71 Honda CL70 Bergs Over the Rainbow Texas or Bust! BigDog/Highfive--Fall Colors in Missouri 2011 Athena Big Bore Project The Other Side of Nowhere Highfive Goes Dragon Hunting WRRDualsport.com |
10-08-2009, 05:30 AM
#7667 | |
Off the road again..
Oddometer: 2,130
For Sale: 2008 Suzuki VStrom DL650 in Bozeman, MT. |
10-08-2009, 05:57 AM
#7668 | |
Oddometer: 2,009
'13 KTM 500 EXC, '08 Yamaha WR250R, '08 Kawasaki KLR650 (Sold), '04 CRF250X (Sold) Member AMA, NETRA, MVTR, CCCOFVT Stealth is good! Noise annoys! |
10-08-2009, 05:58 AM
#7669 |
Wow, that broke easy
Oddometer: 912
More on chain guides
Getting back to the discussion of chaing guides from several pages back.
Are there people who don't have any wear on the lower surface of their chain guide? I feel like there has to be something else at work here other than just a bunch of us with loose chains. A lot of the photos that I see on here have the characteristic shine on edge of the chain sideplates. If the inside edge of your chain is shining up like that then that means it's wearing a groove in your chain guide, and as an FYI it's not going to stop there. Looking at my guide and several photos on here it seems that the wear pattern is deepest at the front of the swingarm, so if you see any grooves at the back end of that guide then the front is probably already gone. I'll be replacing my guide with 7000 miles on the bike and watching my chain tension more closely. I felt like I was running it in a good range before, but now I'm going to have to go a little tighter than I wanted to. |
10-08-2009, 06:19 AM
#7670 | |
used to be -MiamiUly
Oddometer: 1,833
Same here, always known stinkbug to mean rear high. My friend who was a champion hare scramble racer even called it stinkbug when I told him that the rear was high after going to d606s and before lowering the rear. Probably a brain fart/ typo on Travis' part. Good info though beyond that.
Okay it's a sportbike... but riding is not a sport, it's a necessity. Same goes for the Dual Sport.
10-08-2009, 01:59 PM
#7671 |
Smiles when says dat
Oddometer: 12,710
Related to the chain guide question--I do have some polishing on the chain and some wear on the guide Copa.
I'm trying to line up the countershaft, suspension/swingarm linkage bolt hole and the rear axle. It never looks even, no matter how high I jack it up or how low I put it the swingarm connector is always out of line with the countershaft and the rear axle. Pic coming....
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid |
10-08-2009, 02:05 PM
#7672 |
Oddometer: 12,710
10-08-2009, 02:07 PM
#7673 | |
10-08-2009, 02:46 PM
#7674 | |
Oddometer: 12,710
10-08-2009, 03:32 PM
#7675 |
Oddometer: 12,710
Murphy.
I only have questions when I'm all torn down and stalled. I suck. BTW, sidewinder 13T Front and 46T Rear.
10-08-2009, 04:04 PM
#7676 | |
In my Pajama pants
Oddometer: 681
Bikes I own 2008 Yamaha WR250R 1992 Yamaha XT225 |
10-08-2009, 04:25 PM
#7677 | |
AARP Bad Boy
Oddometer: 3,380
Hope this helps.
2009 Yamaha FZ6R for sale. Clean bike, Good price. PM me for details. |
10-08-2009, 04:40 PM
#7678 | |
Oddometer: 12,710
What you wrote helps, yes--first times always suck for me. I'm not intuitive this way. I was trying to line up the linkage bolt and not the swing arm pivot...so good to go now. Now, I'm measuring 1'' on top of the swingarm because the bottom has the rear guid in the way, and 1" scares me as too tight. BUT, I'm all ears brother.
10-08-2009, 05:07 PM
#7679 |
Oddometer: 12,710
I'm tracking now, this is where the chain is tightest, so 1" is fine.
I'm gonna button up.
10-08-2009, 05:58 PM
#7680 | |
Oddometer: 2,130
