Old 12-16-2009, 07:17 AM   #9211
simmons1
simmons1's Avatar
Oddometer: 1,567
The Symtec heaters work great for what they cost. I am using them on several bikes. The set on my ST1300 now has 70K miles on them and they work great still. The set on my ZX11 has almost 50K on them.
The only failure I have had with the Symtec heaters is on my KLR. I was riding through some heavy brush in Arkansas and a branch hooked the wire on the throttle side and ripped it off.
I just a bought another set of them to put on my recently purchased WRR. That will be one of my projects over the holidays.
Headed to Harbor Frieght after work to purchase the low buck windshield.
simmons1 is offline   Reply With Quote
Old 12-16-2009, 11:07 AM   #9212
Roam
If you want to
Oddometer: 1,059
Originally Posted by skierd
I think I'm going to order a set of the one's BigDog is using so I never have to mess with them again...
I just installed a set on my RX. I would recommend getting their epoxy also. I didn't so I used expoxy which was supposed to be good to 300 degrees but after using the heat for a few days the grip is now completely detached from the throttle tube.
I've also found the low setting to be pretty useless so I might try to find a smaller resistor or just get an on off switch.
http://www.twowheelsgood.net
Roam is offline   Reply With Quote
Old 12-16-2009, 11:52 AM   #9213
skierd
Wannabe Far-Rider
Oddometer: 2,970
I'm not too worried about them being hard, and I welcome the larger diameter. The ProTaper pillow top's that were on it wore out kinda fast and I always felt like I was gripping onto a tooth pick after 30-45 minutes in the saddle. They should be here by this weekend I hope...
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 12-16-2009, 12:45 PM   #9214
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,259
Tpi
A quick way to mount up a power outlet. Mounts to your handlebars.
http://www.tpimotorcycleparts.com/ Click on Electrical/Lighting.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 12-16-2009, 02:16 PM   #9215
10Cup
10Cup's Avatar
Oddometer: 2,667
No problem at all.
Originally Posted by boogn1sh
In a few months it will be interesting to compare Krabill's PD chain and sprocket wear against my PD chain and Supersprox. Also be interesting to check wear on HF's $mart Ti $etup. I gave $69 for the Supersprox. Not bad, but that would buy 3 PD sprockets.
I filled the cuts in my swingarm with Quicksteel before installing the new swingarm guard. It is super sturdy now.
I finaly decided to remove the "boat anchor" tonight. This setup seems to work great. No CEL yet. Someone said something about getting less fuel with this setup. I am using the FMF PP, so does it matter?
Boogn1sh, I have mine set up like you show and I get about 62-65 with the attitude programmer set at 2.5,3.0,3.0,8.0,4.0,4.5 Gearing is 13/46 with GYTR pipe. Not a problem in my book, I do have the big tank though.
I also use the same rear sprocket you have and have yet to see any wear on it. Supersprox is very very good. Love it.
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup screwed with this post 12-16-2009 at 03:58 PM
10Cup is offline   Reply With Quote
Old 12-16-2009, 05:07 PM   #9216
ABHooligan
The Flying Mythos
ABHooligan's Avatar
Oddometer: 1,156
torque specs
Hey Guys,
I've been searching for a while, maybe I've overlooked...
I was swapping some wheels, sprockets, and rotors, and haven't found torque specs on this or other forums yet. I saw an incomplete list she-wolf had on her site; anybody have a fairly complete list of this info somewhere? Linky??
Thanks,
Brent
ABHooligan is offline   Reply With Quote
Old 12-16-2009, 05:34 PM   #9217
Nice_Rumble
Oddometer: 2,259
Originally Posted by ABHulgan
Hey Guys,
Thanks,
Brent
Front fork axle nut M16 1 63 Nm (6.3 m•kg, 46 ft•lb)
Front brake disc bolt (WR250R) M6 6 12 Nm (1.2 m•kg, 8.7 ft•lb)
Front brake disc bolt (WR250X) M8 6 23 Nm (2.3 m•kg, 17 ft•lb)LT
Rear wheel axle nut M20 1 125 Nm (12.5 m•kg, 90 ft•lb)
Rear wheel sprocket nut M8 6 35 Nm (3.5 m•kg, 25 ft•lb)
Drive sprocket nut M18 1 95 Nm (9.5 m•kg, 69 ft•lb)
Rear brake disc bolt M6 6 12 Nm (1.2 m•kg, 8.7 ft•lb)
2013 KTM 500EXC
Old 12-16-2009, 06:56 PM   #9218
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,902
Speaking of Shewolf, is it too soon to post a list of the other sites now available that focus on the WRR? High Five doesn't check in too often any more and I'm afraid we lost BigDog forever. But they're all still out there somewhere on the interwebz thingy.
montesa_vr is offline   Reply With Quote
Old 12-16-2009, 07:39 PM   #9219
mbabc
Curmudgeon trainee
mbabc's Avatar
Oddometer: 1,979
Eastern 3C kit...
I'm going to order the 3C pretty soon and was wondering if most also get the grounding kit. Also is the PTA1800 posilock the one for the WR?
I'm getting the 1 unswitched for my GPS, the other 2 for grips and my electric vest.
"I have never seen a Kentuckian without a gun and a pack of cards and a bottle of whiskey." - Gen. Andrew Jackson
'08 WR250R - '12 Super Tenere - '64 CT-Frankentrail
Little Blue goes looking for Orange
I don't know what time it is, I've switched to kilometers
mbabc is offline   Reply With Quote
Old 12-16-2009, 10:12 PM   #9220
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,741
I'd get the ground with it.. it will come attached and ready to install, no worries..
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 12-17-2009, 05:02 AM   #9221
Nice_Rumble
Oddometer: 2,259
WR250R Forums
http://www.thumpertalk.com/forum/forumdisplay.php?f=384
http://wr250rforum.forumotion.com/
http://rickramsey.net/WR250R.htm
http://www.wrrdualsport.com/
http://www.bigdogadventures.com/WR250R.htm
2013 KTM 500EXC
Old 12-17-2009, 07:08 AM   #9222
montesa_vr
montesa_vr's Avatar
Oddometer: 1,902
Alternate WR250R forums
Well done sir, thank you!
Old 12-17-2009, 08:03 AM   #9223
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
The Rick Ramsey site has some sick, sick mods.
I want to see more of that Athena big bore kit.
Hate gets you nowhere.
Old 12-17-2009, 08:35 AM   #9224
svr700
wrrider
svr700's Avatar
Oddometer: 201
What would you like to know?
svr700 is offline   Reply With Quote
Old 12-17-2009, 09:26 AM   #9225
emerson.biguns
All idiot, no savant
emerson.biguns's Avatar
Oddometer: 10,427
Will people stop telling me I have a girls bike if I do that to mine?
emerson.biguns is offline   Reply With Quote
Times are GMT -7.   It's 02:46 AM.
