01-05-2009, 03:43 PM
#166 | |
Oddometer: 623
it's hard out here for a pimp. i'm just tryin to get the money to pay the rent. 2000 valkyrie interstate |
01-05-2009, 03:46 PM
#167 |
Oddometer: 623
[quote=benp1981]Seems pretty light rolling it around the garage... Will have to weigh it sometime, But the stock VTR1000F had a dry weight of 425 lbs and curb of 474 lbs
Unfortuneatly, the DR Big wasnt available on this side of the pond... 18" Harley wheels are a dime a dozen, But no cush drives. Was hoping for a cheap metric cruiser wheel with one, But finding an 18" is proving challenging. I suppose I could lace something, But how are you supposed to find spokes for something like that?[/quote i think there was some guys using these bikes for flat tracking and they would have probably made that kind of a change. i know tl's were used and i am sure superhawks were to. check it out!
01-05-2009, 03:56 PM
#168 |
The Spoad Warrior
Oddometer: 2,168
I've been thinking about an I-4 adventure bike conversion, and I think a big problem is going to be the countershaft sprocket spacing with these bikes that run a 180 or larger rear tire. Fine for sumo stuff, but for dirt I really don't want a 180 (Dunlop 616 is closest thing available, and I'd want something more aggressive).
I need to do some actual measuring, but it seems if you were to run a skinnier wheel it might have to be offset to the left a fair amount. Probably not good for handling Maybe a custom "long" cush drive
none of us are as dumb as all of us |
01-05-2009, 04:03 PM
#169 | |
Oddometer: 623
01-05-2009, 04:24 PM
#170 |
I'm Mr. Crabtree
Oddometer: 3,061
My plan B is to see how badly a 150/70-17 TKC80 looks on the rim thats meant for a 180
01-05-2009, 04:39 PM
#171 | |
Oddometer: 2,129
.....or check out for a wee-strom wheel... |
01-05-2009, 04:47 PM
#172 | |
I'm Mr. Crabtree
Oddometer: 3,061
It may be a bit childish, But I really want a 18"... Just because they don't make the Terraflex in a 17" THAT is just one badass mofo
01-05-2009, 08:03 PM
#173 |
Oddometer: 37
I'm in the same boat right now on my Multi. I'm doing the Dempster this summer, and I really don't want to roll down 1500km of gravel on street tires. I'm stuck with a 5.5" x 17" rim, and the 150/70R17 TKC 80 is meant for a 4.5" x 17" rim.
What would be the downsides of running this combo other than the obvious problem of the tire profile being a bit flatter accross the contact area? This has been done before. Not sure about the results though, they were riding in the desert on Karoos. I found that Conti also makes a 120/90R17 TKC 80 that will fit the front. It's a rear that can be flipped around, so I don't have to run such a lame tire as this bike http://www.multistrada.net/modules/m...&pic_id=102012
Can you teach someone common sense? |
01-05-2009, 08:45 PM
#174 | |
All bikes are dirt bikes
Oddometer: 1,431
Also not so good on snow.
And what are you planning to do with your one and only life? |
01-06-2009, 04:02 AM
#175 | |
Perplexed
If I return before I get back, tell me to wait I'll be right there. There are three kinds of people in this world, those that can count, and those that can't. |
01-06-2009, 12:55 PM
#176 | |
Oddometer: 623
01-06-2009, 01:25 PM
#177 |
Oddometer: 1,431
i need some suggestions for my 1981 gs1100e
I got my progressive springs and shocks at bikebandit.
The lowest setting is better than the highest stock preload. I suggest getting the spring and shock together. Here is a link for your bike. The price should be for the pair but ask online to make sure. http://www.bikebandit.com/product/12...=3576&t=1&td=1
01-06-2009, 01:29 PM
#178 |
Oddometer: 1,431
Well well well! there's even fork springs for your model bike.
They don't make them for mine. I have to cut and add spacers to stiffen them up. http://www.bikebandit.com/product/13...=3576&t=1&td=1
01-06-2009, 01:41 PM
#179 |
Oddometer: 1,431
Front suspention work
I decided to cut the soft portion of my front springs and add a spacer to help the front end.
I was also looking at having an extension machines to fit inside to top of the fork to extend it about two inches. But then I thought of an even better idea. Lose 50 lbs for spring. Before ![]() After ![]() Unfortunately, I gained 25 of those since the accident.
01-06-2009, 08:09 PM
#180 |
Oddometer: 623
thanks denis, the link is great. i was going to shim my front springs but the progressives seem to be relatively affordable and i know how well worth it they are. one last question, the gaiters where did you get those? i know of guys who use off road shock covers is that what you used?
