01-27-2012, 05:36 PM
#1081 | |
Stuck @ Home! >=^(
Oddometer: 1,083
What would you like to know?I'm trying to understand the question.
Manic Cycles=My Facebook Page |
01-28-2012, 01:55 AM
#1082 |
Armature speller
Oddometer: 6,769
01-28-2012, 04:18 AM
#1083 |
Oddometer: 56
move the shock mounts towards the front of the bike by a couple of inchs, make sure the chain doesn't saw through the swingarm. cheap (cost of a cutting disc and two arc rods) but some point in the future you'll have to get stiffer shocks off some thing heavier (goldwing?)
![]() like a late twin shock motocrosser |
01-28-2012, 03:36 PM
#1084 |
Oddometer: 55
I was thinking about the rear suspension of MZ ES 250. They have a 110mm stroke, much more than CB400 FVQ's have.
And I can find them pretty cheap here, 10 to 25 Euros. BUT, 2 of them combined take upto 350 kilos of weight (it's a close call compared to my Honda). And about moving shock mounts, http://kestrelservicesllc.com/Alpina...ject%20Log.htm down to page, says : "A consensus evolved that twin shock design was close to ideal when the distance from swingarm pivot centerline to upper shock mount matched the distance from swingarm pivot centerline to lower shock mount. The eye to eye length of the shock absorbers should be somewhere in the same neighborhood, essentially creating an equilateral triangle." I must investigate that on my bike, but I think that triangle is allready there. So, probably no welding. Already, I want a screw-on-screw and no-welding-on-frame conversion. Goldwing and alike shocks are no go, rare and expensive here and not enough stroke. Maybe two new pieces of mono's from cheap chinese scooters ? |
01-30-2012, 06:47 AM
#1085 |
Oddometer: 56
well you seem to have figured out what your doing.
have a pic
01-30-2012, 12:58 PM
#1086 |
WANDRN
Oddometer: 235
That is a nice looking Triumph!
01-30-2012, 05:35 PM
#1087 |
1.5 Finger Discount
Oddometer: 20,075
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
01-30-2012, 07:16 PM
#1088 |
. . . thinks he likes it
Oddometer: 514
01-31-2012, 12:56 AM
#1089 |
Oddometer: 55
Me too
01-31-2012, 08:18 AM
#1090 |
Oddometer: 70
02-04-2012, 12:21 PM
#1091 | |
Oddometer: 9,781
Always remember air cooled engines are largely "oil cooled" plenty of air cooled bikes running around with large fairings, two up, with luggage. Think touring on a R100RT, there are louvers, but you're hardly letting the cylinders stick out in to clean unobstructed air. And you can more or less idle in traffic on hot days and still be OK. So if your oil cooler is unobstructed, I think you're doing alright. |
02-05-2012, 10:09 AM
#1092 | |
2 squeaky wheels
Oddometer: 609
02-05-2012, 12:49 PM
#1093 |
Tattooed White Trash
Oddometer: 1,652
Nuttin wrong with a little explodie
02-05-2012, 09:05 PM
#1094 |
been there done that
Oddometer: 108
02-06-2012, 02:53 AM
#1095 |
Oddometer: 55
It's 2T, not much of heat there.
