Old 04-13-2008, 10:25 AM   #1
klm4755 OP
Oddometer: 575
KLR650 DID "X-ring" chain (riveted master link) install step-by-step walk thru
Enclosed is a walk thru install of the DID 520VM rivet style chain on the KLR650. The DID 520VM is the top of the line chain and is rated at 8,120 lbs tensile strength, where as the stock chain is rated at 6,200 lbs. The stock KLR650 uses 106 links. The chain is also an “X” ring style where as the stock is an “O” ring style. It is recommended that any replacement chain master link not be the “C” clip style.
This master link is the rivet style. A rivet style master link is abit more difficult to install. However the likelihood of unintentional disconnect is highly remote if the master clip is installed correctly. The chain and extra masterlinks can be seen here:
http://www.tpimotorcycleparts.com/ for $112.50. Extra “X” ring master links sell for $7.95
Kawasaki recommends the chain be inspected and replaced at an interval of 7,500 to 20,000 miles. This walk thru will consists of 3x
parts:
1. Review of tools needed
2. Removal of the OEM chain.
3. Master link plate and rivet install
Start of part 1...tools needed
packaging of the chain to install
master link included
chain pin press and master link plate press
chain puller, if needed, this tool helps pull the links together to get the master link installed
master link rivet upset squeezer
tool out of kit
new chain weight ~3lbs 10.5 oz
master link pin to squeeze upset on installation, closeup
X ring close-up
X ring side view
need 4x for master link install
grease for master link install...Don’t eat this!
pin removal tool diameter = .177 inches, This part gets installed on the master link install tool to either drive the master link pin out, or the thick end is used to upset the master link rivet on install.
master link pin diameter = .205 inch
with X ring installed
closeup of link
work area, bike on center stand, pannier off for access
Part 2 Remove OEM endless chain
Since the OEM chain has no master link...endless style...a pin head needs to be removed and a pin pushed out...get out the Dremal kit
metal cutting wheel
get out Dremal rotary tool
get proper collet
attach cutter
any link will do....keep on rear sprocket to help stabilize the link pin head
and cut from the side...fast dremal speed....no issues...cuts thru in 20 seconds
like so
use this pin removal tool to push the pin thru the link
now the chain can be removed
old and new side by side
small overall stretch after 7,500 miles
OEM dirty Chain weight 3 lbs 10.5 oz
closeup view of O ring and X ring
another view
Now for part 3 rivet master link install
Configure the rivet tool master link bucker to this configuration
add 2x X rings and lube pins with the grease
re-thread chain on drive sprocket and place ends on rear sprocket, install master link pins thru chain link
add more grease, remaining master link X rings, and add outer plate
rotate assy till master link is between sprockets
use this tool to press fit the link cover on the pins
Measure distance between non master link plates = .678 inches
Master link press fit distance = .675 inches
need to buck, by squeezing, the pin ends as shown here in un squeezed state
will use this upset mandrel tool to form the driven head
backing plate, kinda like a bucking bar
engage tool
apply co-linear forces with crescent and socket wrench to squeeze the master rivet pin head
keep going till totally squished down like in this view-
measure non-master link rivet distance =.791 inches
measure master link rivet 1 distance =.781 inches
measure master link rivet 2 distance =.782 inches
master link pin bucked head should look like this!
off set view of properly installed master link pin bucked head
chain view
as installed on bike
ready to ride!
Keithm
klm4755 is offline   Reply With Quote
Old 04-13-2008, 10:52 AM   #2
waltermitty
Oddometer: 55
That's the cleanest KLR I ever seen. You a protologist?
waltermitty is offline   Reply With Quote
Old 04-13-2008, 12:26 PM   #3
klm4755 OP
Oddometer: 575
Is this the view of the bike you speak of??
left side view?
or right side view?
or front view
hehehehe
Keithm
Old 04-13-2008, 03:45 PM   #4
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,826
This belongs in thumpers
JJ
and when it's sufficiently played out, if you want, I can add it to the HoW
Let me know…
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is online now   Reply With Quote
Old 04-13-2008, 04:49 PM   #5
Oly
Deadlines whooshing by
Oly's Avatar
Oddometer: 8,099
so why did you replace the OEM chain after only 7500 miles?
and why not at least replace the front sprocket at the same time?
A well maintained OEM chain should go at least twice that mileage and if you are running the same front sprocket then you will shorten the life of your new DID.
nice write up and great pics by the way.
Oly is offline   Reply With Quote
Old 04-13-2008, 05:00 PM   #6
El Guero
V4 Whore
El Guero's Avatar
Oddometer: 9,727
+1 on replacing the chain early. I can understand your excitement about your new chain, but what kind of KLR owner are you? I got 15000 miles out of the stock chain and sprockets, and that was even after 2000-odd miles of riding it completely taut after me and GSbiker tightened the shit out of it
Very good write-up though. Was the Dremel tool removal of the old chain so you could save it for later? I might have missed that.
El Guero is offline   Reply With Quote
Old 04-13-2008, 05:11 PM   #7
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,774
damn dude. you made rocket science out of cave man job! thanks :)
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 04-13-2008, 05:41 PM   #8
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,076
Great write-up
Instead of removing the pin in the old chain I have heard of people just cutting it off since it's toast anyway.
Ironically I replaced the chain on the XR today for the first time - same chain actually.
I have a Q for you - I didn't use the link that came with the chain (i.e. the same one you installed) but instead used a clip type master link since that what was on the chain I replaced. Curious as to why you recommend the link you used over a clip type ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 04-13-2008, 08:12 PM   #9
Bad Company
Don't call me Shirley
Bad Company's Avatar
Oddometer: 1,319
Great writeup!!
“An adventure is only an inconvenience rightly considered. An inconvenience is an adventure wrongly considered.”
― G.K. Chesterton
Bad Company is offline   Reply With Quote
Old 04-14-2008, 08:31 AM   #10
klm4755 OP
Oddometer: 575
Originally Posted by Mercury264
Great write-up
The chain was delivered with a rivet style X ring master link. I don't believe you can get an X style 520 style C-clip master link. I installed the master link that came with the chain.
Keithm
Old 04-14-2008, 08:46 AM   #11
Mercury264
Mercury264's Avatar
Oddometer: 22,076
Keithm
I originally ordered this for my XR:
http://www.sprocketcenter.com/p/4786...50l-93-06.html
and it would appear you can get a clip master link with an X ring chain.
Unfortunately (or fortunately) they sent me this:
http://www.sprocketcenter.com/p/3105...50l-93-06.html
so like you I got the rivet style link.
I am going to remove the clip link and install the rivet link.
Again, great write-up.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 04-15-2008, 05:31 AM   #12
svwayne
Oddometer: 945
Great write-up. Thanks for taking the time.
I usually measure the distance between the insides of the plates since some master links have a different side plate thickness than the rest of the chain. I also repeat this measurement after riveting the link pins. Too much compression on that X ring will contribute to early failure of the master link.
svwayne is offline   Reply With Quote
Old 04-18-2008, 11:05 PM   #13
klm4755 OP
Oddometer: 575
this master link plate = .080 inch
real chain plate gage = .080
They seem to be of the same thickness.
Keithm
Old 04-19-2008, 01:41 AM   #14
Doghouse_Riley
Wannabe Adventure Tourer
Doghouse_Riley's Avatar
Oddometer: 2,019
Am I the only one that doesn't do all the measuring done here?
Ciao
Doghouse
Canis meus id comedit.
Doghouse_Riley is offline   Reply With Quote
Old 04-19-2008, 07:26 AM   #15
dancolin
Weeeehaaa!
dancolin's Avatar
Oddometer: 1,004
I never even seen half of those tools..I think the cost of those tools alone is worth more than my KLR..but great right up!
http://picasaweb.google.com/dancolin/TheBikes
06 KTM 950 Adventure
dancolin is offline   Reply With Quote
Times are GMT -7.   It's 03:01 AM.
