Old 05-02-2008, 07:23 PM   #121
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,742
Nice job Markus !!! There will be a lot of happy HP2 owners..
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 05-02-2008, 07:34 PM   #122
configurationspace
delooper
configurationspace's Avatar
Oddometer: 8,920
Dude, we were all happy before the tank. This is just a bonus to our already blessed lives.
configurationspace is offline   Reply With Quote
Old 05-02-2008, 07:43 PM   #123
Renazco
Renazco's Avatar
Oddometer: 4,742
(Fixed) Happier'er HP2 owners
Old 05-03-2008, 02:09 AM   #124
alfaris
MOTERO TORERO
alfaris's Avatar
Oddometer: 1,155
congrats
looks absolutely fit for the bike. When seat is mounted none will know the tank is there.
please let us know when units are available.
thanks
09 KTM 530 EXC
07 XR650R
alfaris is online now   Reply With Quote
Old 05-03-2008, 04:23 AM   #125
bavarian_markus
bavarian_markus's Avatar
Oddometer: 166
Originally Posted by Poolside
Very nice work Markus. Super.
What are you using for a pump? You mentioned a "pump controller". Are you using a solenoid piston pump?
Hello Poolside - thank you
I use a sliding vane pump. To start it, you have to push a button, and than the programmed time begins to run and the pump is pumping till the time is finished (the underseat tank is empty)
bavarian_markus is offline   Reply With Quote
Old 05-03-2008, 06:53 AM   #126
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,754
Looking good
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 05-03-2008, 09:53 AM   #127
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
tank support
Marcus: Is the tank supported on the bottom by the aftermarket passenger footpeg crossbar? Bruce
funhouse is offline   Reply With Quote
Old 05-03-2008, 10:29 AM   #128
bavarian_markus
Oddometer: 166
Hello Bruce,
the tank is fixed by both sides in the geometry of the frame and on the bottom by the footpeg crossbar - correct
Old 05-03-2008, 12:15 PM   #129
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
You earned the praise. An 'automatic time out' for the pump is a great idea.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 05-03-2008, 12:22 PM   #130
bavarian_markus
Oddometer: 166
This is because Im very forgetful
and Im electronic engineer
Old 05-03-2008, 06:33 PM   #131
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
crossbar support
Hello Bruce,
MARCUS: Thank you for clarifying this -- I will now need to contact the maker of the passenger peg assembly and see if he will build the cross bar without the passenger pegs! Bruce
Old 05-03-2008, 10:53 PM   #132
crash a-ron
mmm...burnt steel
Oddometer: 328
Heh. Damn! Now I wish I hadn't sold the factory BMW passenger footpeg kit I had...since der factory makes the only one around.
Marcus- Any chance you'll be selling you tank without the fancy pump setup? I'm more interested in the tank with just a fuel line fitting at the bottom. Looks pretty great BTW. Let me know when you've tested one offroad!
Aaron "It is all fun and games until Shoulder Surgery."
Seattle, Washington
crash a-ron is offline   Reply With Quote
Old 05-03-2008, 11:02 PM   #133
GSMarc
GSMarc's Avatar
Oddometer: 1,105
Hi Marcus, some questions :
1) do you need to take off the saddle to fill the tank (seems yes) ?
2) have you already a Ver 2.0 prepared to avoid this ?
3) will the pump be inside or outside the tank (for maintenance or
replacement) ?
4) if the pump is 'time controlled', what happens if the tank is only
half filled, will the pump run some minutes pumping nothing ?
thank you,
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 05-03-2008, 11:11 PM   #134
configurationspace
delooper
Oddometer: 8,920
replacement) ?
thank you,
If you read the thread you'll notice questions 1 and 2 have already been answered. (1) yes, (2) he's considering it.
Old 05-04-2008, 06:47 AM   #135
SteveRed
Adventure Mojo
SteveRed's Avatar
Oddometer: 2,681
Love to know if this will fit the MegaMoto Marcus!? Fantastic by the way!!
Agito ergo sum - I ride therefore I am!
http://www.adventuremoto.com.au
Your ride.. Your adventure!
SteveRed is offline   Reply With Quote
Times are GMT -7.   It's 01:33 PM.
