Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 4.92 average. Display Modes
Old 10-09-2008, 07:05 PM   #811
nostatic
i drank what?!?
nostatic's Avatar
Oddometer: 462
I can't get my 60CS to be seen by my Mac. I have installed RoadTrip, MapInstall, MapManager and WebUpdater. From reading other posts it seems that I need to upgrade the firmware in the 60CS, and I was hoping that WebUpdater would accomplish that. It looks for it but never finds the device. This is with different known-good USB cables and a known-good USB port. When nothing is connected the WebUpdater goes immediately to the not found message. With it connected it spins for awhile, then gives the not found message.
Ideas? My windoze box is DOA so going that route isn't an option.
new album | book | nostatic site
nostatic is offline   Reply With Quote
Old 10-09-2008, 08:58 PM   #812
Brent4ADV
Enjoying empty roads...
Brent4ADV's Avatar
Oddometer: 1,006
Can you see the device on the system profiler? What do you mean by "different known-good USB" cable? Is this the one that came with your Garmin?
01 KTM LC4-E
02 KTM 520 EXC
My TAT Ride '08
Brent4ADV is offline   Reply With Quote
Old 10-09-2008, 09:03 PM   #813
nostatic
i drank what?!?
nostatic's Avatar
Oddometer: 462
There wasn't a usb cable with the gps. It does show up on the system profiler:
vend_device:
Version: 0.01
Bus Power (mA): 500
Speed: Up to 12 Mb/sec
Product ID: 0x0003
Vendor ID: 0x091e
Old 10-14-2008, 06:34 PM   #814
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,492
Okay, Roadtrip seems to work pretty well for the last few weeks. It took quite a few times to get my Topo 2008 to convert to Mac (oddly enough while everyone recommends to NOT compress it only worked for me if they WERE COMPRESSED) and that led to the problem I'm having now which I haven't been able to work out.
I can't get my 276c to load BOTH the Topos and the City Navigator maps. I can get it to load either one but it won't load both. When I try to load both the status bar says it will take 30 minutes, then 40 minutes, then 50, 60, 80... etc and if I leave it long enough, like overnight, it will at some point say there was a problem - most likely my GPS ran out of battery after 12 hours. Now my Edge 705 managed to load both the City Navigator (2009 for it and 2008 for the 276c) and the 2008 Topo with no problem.
Any advice?
I know you need to be careful to uncheck any other maps that aren't unlocked for the selected GPS but I did that. This is the Topo 2008 and not the older Topos that require the patch update. I'm not sure if anyone else has had luck loading both but if you did I'd like to know how.
Gregor
sakurama is offline   Reply With Quote
Old 10-16-2008, 06:21 AM   #815
nyc_gs
Lurker
nyc_gs's Avatar
Oddometer: 241
Similar problem
Hey Gregor,
I had a similar problem when I first purchased a new memory card for my 276c. For some reason the maps would just not load. I had the same experience as you in terms of time to finish and then it just crapping out on me.
For me the fix was to re-install the MapInstall software. Does not make much sense as the version I installed was the same as the version I had, but it did fix the problem. You might want to give that a try to see if it helps any.
-- Jason
nyc_gs is offline   Reply With Quote
Old 10-17-2008, 04:05 AM   #816
deepfreeze
Oddometer: 32
How to organize POIs in Zumo
With Roadtrip Im able to collect my POIs inside folders. Thats fine.
But when I export a folder to Zumo I lose the name of the folder and therefore cant choose what POIs I would like to search.
Example: I have campsites and fireplaces in different folders. Sometimes I would like to check if there are just campsites near me, but Im unable to see only them.
Is there a workaround to export POI-folders so that the foldernames stay there. Just like the pre-installed hotels / food /gazoline etc..
sami
deepfreeze is offline   Reply With Quote
Old 10-17-2008, 05:26 AM   #817
DennyIndy
Old F@rt
DennyIndy's Avatar
Oddometer: 349
Export the folder to a GPX file, and use POI Loader to send it to the Zumo.
DennyIndy is offline   Reply With Quote
Old 10-17-2008, 06:28 AM   #818
deepfreeze
Oddometer: 32
OK, that did work!!!
Is this possible to integrate straight to RoadTrip in future?
Would be a nice feature.
Thx,
Sami
Old 10-17-2008, 06:54 AM   #819
husky123
Oddometer: 1,454
Hopefully you'll (we'll) get an answer from someone on this as I was about to pull the trigger on a new 60csx!
husky123 is offline   Reply With Quote
Old 10-17-2008, 08:22 AM   #820
Brent4ADV
Brent4ADV's Avatar
Oddometer: 1,006
I've got a 60csx that I bought about a year ago and never have had a problem connecting to my mac.
01 KTM LC4-E
02 KTM 520 EXC
My TAT Ride '08
Old 10-17-2008, 10:43 AM   #821
husky123
Oddometer: 1,454
Thanks Brent!
Here's another GPS/Mac map situation I'm trying to wrap my head around. I have RoadTrip and say I buy another GPS (Garmin 60csx) with a new set of maps. I still have to fire up the PC and 'convert' all the new maps over for RoadTrip right? Same with topo's and such too?
Old 10-18-2008, 04:16 AM   #822
realdeal
dream
realdeal's Avatar
Oddometer: 11
Lat/Long Bar in Roadtrip?
Hey guys this is a great thread. I've been a Mac user for years but still deal with windoze at work. I didn't jump in on Bobcat but I now have Roadtrip up and running. What I miss most in Roadtrip is the bar which shows latitude/longitude as you move the pointer over the map. I used this feature on my PC to map waypoints from my TAT rollcharts. Is this something we will eventually see in Roadtrip?
realdeal is offline   Reply With Quote
Old 10-20-2008, 05:49 PM   #823
Brent4ADV
Brent4ADV's Avatar
Oddometer: 1,006
Thanks Brent!
Well, the 60csx doesn't come with any maps so you'd have to buy them seperately. As I understand it, the new maps are mac compatible so converting them is not necessary. Check here for the Mac Topo maps. The same goes for City Navigator 2008 and later.
01 KTM LC4-E
02 KTM 520 EXC
My TAT Ride '08
Old 10-20-2008, 06:46 PM   #824
husky123
Oddometer: 1,454
Said in my best Yoda voice, "So much knowledge have you."
Thanks again.
Old 10-30-2008, 11:17 PM   #825
mkfs
Oddometer: 38
POI Loader?
I just tried the Mac POIL loader with my 76CS and I was told "none has the necessary capabilities.." This with Ver 2.0.1.
The 76CS Interface page says Connected, Garmin data format.
Does this mean I need to respond to one of the 200+ Viagra ads in today spam, or...?
mkfs is offline   Reply With Quote
Times are GMT -7.   It's 12:35 AM.
