Old 04-14-2008, 02:29 PM   #1
airheadpilot OP
Le Poulet du Désert
airheadpilot's Avatar
Oddometer: 286
Disc brakes on /2 Earls Forks
I'm screwing around with a project bike - basically building an airhead entirely from parts. Since it was never a whole bike, I don't feel too obligated to stick to anything that could be described as "original." I had planned on using 1981-1984 forks with heavily modified internals because I'd like to run wire wheels but I want the stopping power of the Brembos. But then I stumbled across a good deal on a straight /2 Earls front end - missing the shocks and the wheel. I love the way my stepdad's R60/2 rides with the Earls fork, and am thinking that might be fun to play around with, but I still want the braking power of dual Brembos. I've seen them in the past so I know it's been done. Anyone out there have good photos of a BMW Earls fork front end modified to run dual calipers? Better yet, has anyone done it and can give me an idea of the level of fabrication required, beyond just welding the tangs for the calipers on the bottom of the swinging arm? Maybe nothing comes of it, but I'm having fun thinking outside of the box.
Andrew
1970 BMW R50/5 project bike
1971 Moto Guzzi V750 Ambassador
1972 BMW R75/5
2000 Honda XR650R dual sport
2003 Suzuki Burgman 400 wife's bike
2005 Yamaha FJR1300A
Big Ass Titties!
airheadpilot is offline   Reply With Quote
Old 04-14-2008, 03:15 PM   #2
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,724
perhaps not the solution you are looking for, but see this?
http://www.bmwgs.com/forums/showthread.php?t=330310
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 04-14-2008, 04:56 PM   #3
airheadpilot OP
Le Poulet du Désert
Oddometer: 286
Actually, that's very helpful. I was thinking of using Brembos from a post-1980 airhead, but it's basically the same idea. What that shows me is that the Earls will fit up to a /5 headstock and that a later wheel (I'm thinking a /6 hub with dual discs) will fit, albeit it with possibly some futzing (technical term) with the axle and bearing preload.
Andrew
Big Ass Titties!
Old 04-14-2008, 07:34 PM   #4
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
I've got a single disk on mine, and the wheel just barely fits. You really only need one, but if you're dead set on 2, check these guys out;
http://autos.groups.yahoo.com/group/slash2conversions/
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 04-14-2008, 09:45 PM   #5
RocketJ
Oddometer: 674
Wire and bremo f08s
Andrew
The calipers will hit the spokes, unless you find a rare 100CS wire wheel, some R65(?) hubs or those from a G/S. The /6 and 7 hubs won't work.
RocketJ is offline   Reply With Quote
Old 04-15-2008, 06:42 PM   #6
Hennepinboy
Have battery will travel.
Hennepinboy's Avatar
Oddometer: 453
Check with Nathan from Boxerworks
http://boxerworks.com/message.phtml
They have set up for disk on Earls Forks and everything else you may need.
Hennepinboy is offline   Reply With Quote
Old 04-15-2008, 08:32 PM   #7
JohnTM
I suck toes
JohnTM's Avatar
Oddometer: 29,206
JohnTM is offline   Reply With Quote
Old 10-29-2013, 03:47 PM   #8
Tony Collett
Oddometer: 2
Andrew
Have just completed doing this Disk Brake conversion. Not that difficult, just not to be rushed. If you need some pointers, I can help as there are many ways to skin this cat. Happy Trails, My email is : tony.collett@shaw.ca
Tony Collett is offline   Reply With Quote
Times are GMT -7.   It's 04:20 PM.
