Old 04-18-2008, 04:17 PM   #16
The Jerk OP
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,651
OK I replaced this:
with this:
Looks like rectifying technology has really shrunk down in the last 36 years.
Big difference right away. I had previously bridged the yellow & white wire in the headlight bucket to get full charging capability all the time. With the old rectifier, that didn't change anything. With the new rectifier I'm now getting about 14v at idle with the light off. Very nice.
When I turn the headlight on it goes less into "recharge" mode and more into "break-even" mode. I didn't check charging current, just volts this time. It's about break-even at idle and gets better as revs increase.
I did a 7-mile or so ride around the neighborhood with the headlight on and using turn signals as normal. Some revs in the idle - 5000 rpm range and some idling at stoplights. Bike ran great, no electrical weirdness, and when I got back and put the meter on the battery after shutdown I had the same voltage as when I started. Break-even indeed.
I've been told that break-even is reallly the best I can expect with the stock charging system and the headlight on. The other difficulty with that is partly of my own making in that I replaced the stock piss-poor 25W headlight with a standard 55W sealed beam from an auto parts store. Doing the math according to W = V * A, a 55W bulb at let's say 13v draws 4.2 amps while the stock 25 watt job at 13v draws only 1.9. This seems to be a significant difference when the shop manual specifies a charging current with the low beam on of only 1.6-2.6 amps at 3000 rpm, assuming the stock 25W bulb. This certainly cuts some of my charging capacity.
Clearly I'm not gonna be running a GPS or heated vest off this bike!
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 04-18-2008, 04:26 PM   #17
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,866
I've been told that break-even is really the best I can expect with the stock charging system and the headlight on. The other difficulty with that is partly of my own making in that I replaced the stock piss-poor 25W headlight with a standard 55W sealed beam from an auto parts store. Doing the math according to W = V * A, a 55W bulb at let's say 13v draws 4.2 amps while the stock 25 watt job at 13v draws only 1.9. This seems to be a significant difference when the shop manual specifies a charging current with the low beam on of only 1.6-2.6 amps at 3000 rpm, assuming the stock 25W bulb. This certainly cuts some of my charging capacity.
I think there's some apples/oranges sorting going on here.
Sorry, I mean I dont think you can fully judge the battery's state of charge from the voltage its at. Although its certainly an indicator. And charging current has little to do with current draw off the battery... they are different things. Unless there's something I'm totally misunderstanding about this, which is eminently possible
edit what i mean is: only a portion of your alternator's current output in amps is devoted to battery charging. Other output is devoted to ignition spark, and others to extras like lights and such.
Unintentional psychokinesis.
Stagehand screwed with this post 04-18-2008 at 04:58 PM
Stagehand is online now   Reply With Quote
Old 04-18-2008, 05:18 PM   #18
The Jerk OP
The Jerk's Avatar
Oddometer: 2,651
Tomorrow I'm gonna check the charging current properly. But my thoughts on charging current and current draw are thus: please correct me if my understanding is wrong.
The charging system can charge the battery with so many amps at whatever given rpm. If you use electrical equipment on the bike that draws more current than what the alternator can provide, you are discharging the battery by whatever number of amps you are overdrawing it. Is this not a correct statement?
2000 Kawasaki W650
Old 04-18-2008, 05:28 PM   #19
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,866
It sounds correct to me, I would add that the battery never gets charged with more than an amp or two at 14v, in order not to cook it- the battery gains a state of charge at a much slower rate than it can lose charge.
They say you have a break even system. Curious: does your manual say what the max alternator output(w) is, and at what RPM?
Old 04-18-2008, 06:55 PM   #20
The Jerk OP
The Jerk's Avatar
Oddometer: 2,651
The owner's manual says:
0.11 kW/4000 rpm
My question is, why did they choose to list the spec in kilowatts when it maxes out at a tenth of a kilowatt?
2000 Kawasaki W650
Old 04-18-2008, 07:13 PM   #21
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,866
0.11 kW/4000 rpm
heh good question. quite possibly they list horsepower in Kw also.
So like 110w, max. With 25w for charging, and originally 25w for original headlight, and about 40-50w or so for ignition, i think, yeah- you're about break even on alternator power. Most of the batteries current is going to go towards pushing the starter motor, unless you add gizmos and bigger lights. With your big headlight, I suspect you're constantly stressing the system.
I'm curious about your "neutral" setting on the switch, as well, and am trying to follow the wiring to see what it connects and where, to find out what it does. Weird.
Sorr yIm no real help, I only am familiar and only partly at that with the BMW charging systems, but I assume they all work generally the same.
Old 04-18-2008, 07:19 PM   #22
The Jerk OP
The Jerk's Avatar
Oddometer: 2,651
Lucky for my battery, the electric start doesn't work. The starter motor works OK but the starter clutch is shot. I have a spare but haven't gotten around to installing it yet because it's kind of a pain. So I've been keeping the system stress-free by using only the kicker.
I don't get the N thing either. According to the wiring diagram it looks like it sends power to the high beam & taillight and bridges the 2 charging circuits as the switch does on L. In other words, what the wiring diagram describes as position "N" is really just the high beam position. According to the diagram, H position just powers the high beam and taillight but doesn't bridge the charging circuits. However that's not how it works really.
My switch, which is definitely the original switch, has no "N" position but the H position on the switch does what the N position on the wiring diagram suggests. Maybe it's some non-U.S. thing but then why would they put it in the U.S. wiring diagram?
2000 Kawasaki W650
Old 04-18-2008, 11:51 PM   #23
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
As far as i know any honda of that era discharges at idle, you dont actually get any charging effect until 3k rpm or so.
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 04-19-2008, 04:09 AM   #24
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,866
I think thats true for any bike that has a crank driven alternator, rather than one that's got its speed stepped up by a belt. Older BMW's dont see any decent juice until then, either.
Old 04-19-2008, 09:56 AM   #25
markjenn
Oddometer: 10,457
Great find on the guy producing alternative rectifiers and regulators for our old bikes. This is very cool. I've had no trouble with the charging system on my 71 CB750, but I'm tempted to replace the rectifier and possibly the regulator just as a preventative measure.
- Mark
Old 04-19-2008, 12:16 PM   #26
The Jerk OP
The Jerk's Avatar
Oddometer: 2,651
OK I'm gonna consider my charging system problem solved. I reversed my previous mod that bridged the split charging circuit all the time and returned it to stock - where 2/3 of charging capability is available normally and when you activate the headlight the other 1/3 comes on line.
Checked charging current today. With no headlight at idle, around 0.5 amp. At around 3000 rpm a solid 3 amps, right on spec.
Headlight on, battery is discharging at idle by about 2 amps. However, above idle, in the 2000-3000 rpm range charging current is about 1.7 amps, right on spec.
So basically the old crappy original rectifier caused all this headache. I should have just replaced it as a matter of course upon acquiring the bike in the first place.
2000 Kawasaki W650
Old 04-18-2013, 04:23 AM   #27
41716
Oddometer: 2
Greetings from Germany
Hi,
I have the same problem like Jerk and indead this was the reason why I deregistered my CB450K1, MJ. 1968 in 1985. Now, while I'm nearly 60 years old and the CB450 45 years, I' m reactivating it. 30 years ago there was no time to find out the defect.
Yes, 110W is very low power for such generator, but what I found out until now is as follows:
The circuit diagram with that pretty colored pathes is helpfull, but also faulty. Instead of the red line to the regulator I have a green one, which is connected to ground! I have two regulators with this wiring (Y, G, Bl) !
Today I made a bench test with a variable AC power supply, using a simple welding transformer, potentiometer, rectifier, and a dummy-resistor. Findings were two defective regulators! One of them (originally from the sixties) I disassembled/destroyed carefully (the few electr. components are casted with 2K-plastic material in an alloy housing) The findings after that was a defective Z-Diode with very old design.
Now, my intention is to rebuilt a new regulator with new parts from an electronic parts dealer and than to make some further tests.
The original rectifier should be replaced anyway, due to the no resistance to vibrations.
Michael
41716 screwed with this post 04-18-2013 at 04:29 AM
41716 is offline   Reply With Quote
Old 04-18-2013, 07:33 AM   #28
Prmurat
Prmurat's Avatar
Oddometer: 1,033
I had the same, exactly, problem with my 71 ( owned since 78) when my wife decided it was hers: she did not rev it up enough and after 40 years a couple of things were old.
I even had a stator rewinded ( but never installed) but found this:
http://www.regulatorrectifier.com/ca...1bef9ba9fe2be0
I do not have a 55w headlamp but I have electronic ign ( and there is no way for my wife to not use the ES!) and this gadget is always in the green now:
Ebay item: 190401283689
And of course all my wiring is stock: I do not have the knowledge nor the foolishness to think I can do better than Honda R&D !!
Prmurat is offline   Reply With Quote
Old 04-19-2013, 10:52 PM   #29
41716
Oddometer: 2
Regulator Circuit Diagram
Hi Prmurat,
there is one thing I must say here. It seems to me, that the early CB450's had different alternators. I have two of these alternators here and both show the same electrical power and resistance values, ---and, this is the most important thing, both are too weak to drive a 55W halogen headlight!! The max. output at may be 3000 rpm of the alternator with rectified current is 110W!!!!!! Ignition needs about 30 to 40 Watt, taillight min. 5 Watt. So, the batterie will be discharghed at all using a 55 W headlight bulb. These alternators were installed, as far as I know, on CB450's from 1965 until 1969, which were equipped with only a 25 W headlight.
After 1970 there was a stronger alternator installed, as far as I know.
What I did was to install a 25 Watt headlight bulb, which is working together with two high power LED mini headlights which needs only some few mA's. Otherwiese, with only a 25W headlight, I wouldn't like to drive drive this motorcycle!
Hopefully this link works on US pages:
it shows the original CB 450 K1 regulator circuit diagram which a crazy guy drawed using CAD. I constructed it yesterday with suscess, --works perfect, but it might be better to use a potentiometer for the R 460 Ohm. So the limited voltage was only round about 13,7 Volt. With a variable 500 Ohms resistor the generator output can be adjusted to 14 Volts.
http://img191.imageshack.us/i/ladereglerjens.jpg/
So far, I think or I'm sure that only the electrical problems with the alternator, rectifier and the regulator are the reason why only few CB450K are still existing. The electronic solution for the ignition system is also a good thing, but here were the 2 condensers the problem of the original system. After few years they had only poor capacity. On my CB450K I replaced them now and have a pretty good spark.
Greetings also to all who drives such a nice motorcycle all over the world
Michael
41716 screwed with this post 06-03-2013 at 11:08 PM
Old 07-25-2013, 08:26 AM   #30
Gene Parmesan
Oddometer: 2
1970 CB450 charging issues
So I'm going to piggy back on Jerk's thread because I'm suffering from the same malady that he seems to have cured. Other than the issue of voltage not rising with the RPMS, I also apparently have an issue of the previous owners jerry rigging the electrical system. I can't say exacty what's going on (I have a mech wrenching for me because I am not mechanically inclined enough, plus no space to work in) but it seems some things are bypassed and hardwired. I should see it tonight and will snap some pics. Hopefully the nice color diagram will clear things up. As you can probably tell I don't own a repair manual either.
Does anyone know what voltage the generator is supposed to put out at idle and at 3000 rpm? What about once it's rectified? This way I (we... ok, the mech) can test the system piecemeal to isolate the malfunctioning component. Thanks a lot guys!
Jerk, I see you are in Brooklyn. I am too. If you are inclined to drop some wisdom on me regarding the charging system - the beer is on me. Let me know.
Gene Parmesan is offline   Reply With Quote
Times are GMT -7.   It's 05:13 AM.
