Old 04-24-2008, 05:58 PM   #1
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,717
BMW G650X Challenge Thread Index
Let's see if we can get the wealth of information, expertise, tips and suggestions compiled into one organized easy to access thread. If you have any links to add to the index thread, please add them here. If you have questions "how to" questions, add it to the existing XChallenge threadfest or start a new thread.
If you see a broken link, please PM me so I can investigate it further.
The aim is to gather all the relevant links here:
G650 X Challenge Index Thread
Suspension setup
Front Suspension setup
Rear Suspension setup
Rear shock mudguard discussion: The G Spot
Brake pads: EBC Brake pads
another link
Brake pads from other bikes that will fit the X Challenge
Rotors and Brake pads from other bikes that will fit the X Challenge
Foam air filter:
Airfilter: Unifilter NU7309
Unifilter installation tip
TwinAir filter cover kit
TwinAir Part number
Non-OEM Parts spreadsheet
MUST DO MODS:
1 Replace stock cast shift lever to protect transmission shaft. (see below in Modifications section)
2 To avoid rear shock bladder from rubbing on inner mudguard:
Option 1: More clearance between mudguard and rear shock
Option 2: Modifying the inner mudguard
3 Tail tidy: Tail section is detachable for hard enduro riding. There are a few after market tail tidies, some listed in the Mods section below, or you may want to fabricate your own mod, but cutting off most of the tail section.
Caution!
Broken subframe: How to prevent it
Blowing fuses constantly? Here's the cure
SPROCKETS:
Front sprockets from other bikes that will fit the X Challenge:
BMW F650, Aprilia Pegaso
Touratech sells 14T front sprockets
Lots of sprockets supplier for the G650X Challenge
More Rear sprocket suppliers
Sprockets, speed and RPM chart
Stealth Tri Metal Sprockets
Titanium Sprockets for G650X series
TIRES/TYRES:
Tires/Tyres 1
More knobbie tire options
ENGINE OIL CHANGE
Engine Oil Change Procedure 1 post
Engine Oil Change procedure thread
Engine stalling when running: pinched vent line and remedy pics
Torque specs for oil drain bolts
Transmission smoothness and synthetic oil
BATTERY:
Replacement Battery: Odyssey battery PC310
Pics of the Odyssey PC310 installed
Yuasa battery for G650X bikes
SPEEDOMETER:
Speedometer: Change from MPH to Km/h and vice versa
Recalibrating the speedometer
A simpler way to recalibrate the speedometer
SWINGARM:
How to remove teh swingarm to grease the bearings
MODIFICATIONS:
Airbox:
Airbox modification
Too many fasteners to remove to get to the air filter? Check out this mod
Brake lever:
After market brake lever: Front Brake Lever. Available from Parts Unlimited. Part # 0614-0080 (Lever RH-BMW) OEM # 32727655208
Chain guide: Touratech sells a chain guide for the G650X bikes
Another chain guide option
Clutch lever replacements:
A list of clutch levers from other bikes that will fit the G650X
Evaporative cannister:
Removing the evaporative cannister on G650X US models
Exhaust silencer:
Exhaust silencer discussion thread
Footpegs:
Pivot Pegs mounted to X Challenge
Front fender replacement:
Acerbis TechNik fender installed with adapter plates
Handlebars:
Pro Taper ATV Hi Bars
Renthal Fat Bars
Heated grips wiring:
How to wire heated grips on the G650X
Lighting:
Rally bike lighting
Low cost lighting mod
Touratech auxiliary lighting for X Challenge
Mudguard:
More clearance between mudguard and rear shock 1
More clearance between mudguard adn rear shock 2
Radiator:
Cheapo mesh radiator guard
Risers:
Risers
Risers and handlebars
Rox Risers installed X Challenge
Shift lever:Touratech's F650 steel shift lever works well.
Compatible replacement steel shift lever 1
Other compatible replacement steel shift lever 2
More compatible steel shift levers 3
Transmission shaft precaution
Shock: (after market replacement shock)
Wilbers shock installed
Steering Dampeners:
Emig Racing X Challenge installation pictorial thread
Emig Racing BMW X Challenge Steering Stabilizer Kit,
Forks and steering dampener
Rallemoto steering dampener
Wheels:
Excel wheels built by Woody's
SM wheel conversion 1
SM wheel conversion 2, part A
SM wheel conversion 2, part B
Custom wheels and steering damper
Total bike mod:
X Country bike mod
Gaspipe's X Challenge adventure touring complete conversion
SteveRed's X Challenge Adventurised
X Challenge Adventurised for long distance riding
X Challenge Adventurised for long distance riding with Touratech luggage and tank
X Challenge panzer camouflage paint job
X Challenge with Tail Tidy, Pivot Pegs, TT Tank, Emig damper, Tuono mirrors, Rizoma LED blinkers
Total bike mod: G650X Challenge Rally Bikes thread
Jack Splash's Rally bike mod
X Challenge Touratech Rallye kit and TT fuel tank installed
X Challenge bike mods by inmate HP2
X Challenge bike mods by Captain Spiros
Round the World X Challenge mods by Colebatch
Rade's X Challenge 690 Adventure
RACKS, BAGS & PANNIERS:
Aluminum tail rack for G650X bike
Detachable top case
Dirt Bagz for all three G650X bikes
Dirt Bagz mounted to G650X Country
Dirt Baz mounted to G650X Challenge (pictorial guide)
Hepco Becker pannier racks with Wolfman soft panniers
Hepco Becker racks with aluminum cases and touring windshield
Pelican case mounted to luggage rack
SW Motech luggage rack
Wolfman Luggage for the X Challenge
Wolfman Luggage tank bags: mounted pics
SEATS:
Renazco custom seats for X Challenge
X Moto low seat on X Challenge
Hoots Magoon's Pics of the Low Seat Comparison
EXTRA FUEL:
Touratech tank 1
Another Touratech Tank install with external links to lots of pics
Max Kool 7 liter tank
Aux Fuel Tank -Build it yourself
Jack Splash's Acerbis 1.4 Gal aux tank with a siphon kit
MSR 1 liter fuel bottle
Baja designs fuel tank add on
Acerbis add on fuel tank on home made mount
Rotopax 2 gallon add on tank
PROTECTION:
BMW OEM Handguards installation procedure
BMW OEM Handguards part numbers
BMW OEM Engine Guards 1
BMW OEM Engine Guards 2
BMW OEM Engine Guards 3, installation pictorial
Cycra Pro handguards installation pictorial
More handguard options
KTM handguards mounted on the X Challenge
Kutch's hardpart protection for side stand frame and rear brake pedal
Kuthc's hardpart update: Now, obtain the design file from Kutch and make your own
Touratech skiplate
Hyde Racing skidplate
Rear rotor fin
Various Touratech Protection Farkles
Sidestand protection hardpart
Windshield 1: Hyde Racing
Windshield 2 for all G650X bikes: Cee Bailey's
Windshield 3: Slip Streamer Spitfire
Windshield 4: Cee Bailey's installed on X Challenge
Windshield 5: Brittannia Composites Lynx Screen and headlights
MOUNTS:
Accessory socket: Here
Accessory Socket Wiring
Accesory Socket Pic
GPS:
GPS mount, RAM based
Links to a better on bike tool kit
Centerstand
Centerstand Video demonstration
Frequently Asked Questions
Electrical
Fuel Tank
Oil change procedure
NHTSA recalls
SPECIFICATIONS, PARTS LIST:
http://www.maxbmwmotorcycles.com/fiche/fiche.aspx
Torque values and specifications
Wallpapers: X Challenge for your PC screen
RIDE REPORTS:
1850 miles around the Pyrenees on an XChallenge
Two-up on an XChallenge camping at Mount Rainier for a week
2,581 miles, 8 days, on an XChallenge
3 days of riding in Baja
Bruce Lee Rides Again - Summit to Sea in Central Mexico...
Seattle to OR, ID, NV, and CA on a X-challange. 2 days, 1,700 miles
Two Day Moruya Area Ride
Flo Evans First X Challenge Ride
Millican Plateau Kicked my A**
An X-Challenge, Husky and 640 go to Tahoe
Bayley-Hazen Military Road ride
Desert Racing! Vegas to Reno 2008, chasing a dream...
A Flinders Ranges Blast
Riding my XChallenge to Canon de Guadalupe and Baja 1000
X(C)Mas break ride..... (from Australia)
Baja Fools
Day Trip From Karratha via Pyramid Stn (Australia)
Warning - XXX Rated Pics Inside!
GB screwed with this post 03-22-2012 at 03:41 AM
Old 04-24-2008, 05:59 PM   #2
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,717
We will fine tune the categories and add or delete links as we go along. Please add your own links below!
Old 04-24-2008, 06:03 PM   #3
jamesdemien
jamesdemien's Avatar
Oddometer: 609
Looks like my prayers have been answered.
Thanks gadget.
If you don't fall you're not going fast enough?
Gateway BMW Motorcycles St. Louis | Vimeo
jamesdemien screwed with this post 04-25-2008 at 05:48 AM
jamesdemien is offline   Reply With Quote
Old 04-24-2008, 06:48 PM   #4
kutch
That fell off where?
kutch's Avatar
Oddometer: 583
Yes Yes Yes...finally.
As I find "stuff" I'll post here then....
This may be a nono...But F650 has been a very reliable storehouse of info for the 650GS/CS, which shares the same power plant as the XCh...So,
HERE:
Ride report: Here
Kutch
"Keep your front wheel down and your head up..."
kutch screwed with this post 04-24-2008 at 07:38 PM
kutch is offline   Reply With Quote
Old 04-24-2008, 07:19 PM   #5
kutch
kutch's Avatar
Oddometer: 583
No order what so ever...As I thought of things I pasted.
Pick and choose what you will!
Places that may have parts or a bike for sale:
Pelican
IBMWR
BikeBandit
Sprokets
RG Racing
Speedo recalibration:
Tank bags:
Wolfman
Fuel tank:
Bajadesigns
Acerbis
Wallpapers:
Dealerships sites:
ASC
Atlanta
MAX
SantaCruz
Other XCh specific forums:
Other threads:
Would anyone take a BMW X-Challenge RTW?
Rally Radio! To get pumped...
Shock rebuild:
Tools:
Windscreen:
Centerstand:
Stalling at idle?
Airfilter NU7309
Top rack:
Brake and Rotor:
Adjustable clutch lever: Wunderlich part... "Best.-Nr.: 8160656
Lighting:
Lighting 2:
Brake saver:
kutch screwed with this post 04-26-2008 at 10:17 AM
Old 04-24-2008, 07:25 PM   #6
650x
Oddometer: 1,158
Extra Fuel:
650x is offline   Reply With Quote
Old 04-25-2008, 04:39 AM   #7
smithy1
rally bike slut
smithy1's Avatar
Oddometer: 1,133
some book marks that I have:
Brake pads http://www.advrider.com/forums/showp...postcount=2992
Procedure for changing speedometer from KMH to MPH or vice versa http://www.advrider.com/forums/showp...postcount=2096
adjust their wheel size in the speedo http://www.advrider.com/forums/showp...postcount=1059
Shawn in PA
Pine Barons Enduro Riders Supporting south jersey enduro, hare scramble, and dual-sport riding since 1972! Please get involved and join a club. PM me for details.
smithy1 is offline   Reply With Quote
Old 04-25-2008, 06:33 AM   #8
Hoots Magoon
Hey ya'll, Watch this!
Hoots Magoon's Avatar
Oddometer: 1,252
How about a link to ride reports?
Hoots Magoon is online now   Reply With Quote
Old 04-25-2008, 07:23 AM   #9
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,717
Keep it coming guys!!
I have my own pile of printed links that I must type in manually, which will take a while, but I will give your links priority and will move them to the first post, and will use my Mod edit access to your post to mark it as "done" so I keep track of what I've done and what I haven't.
Old 04-25-2008, 02:24 PM   #10
Hoots Magoon
Oddometer: 1,252
How about some exploded parts diagrams?
Max BMW's Parts Fiche
Old 04-25-2008, 02:31 PM   #11
Hoots Magoon
Oddometer: 1,252
The G Spot
Old 04-25-2008, 03:20 PM   #12
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,717
When posting links, it would be preferable and easier to find the linked topic if you posted a link to the particular post within the thread you want to link us to.
You simply click on the thread number, and that post will open in a new window. You now can copy and paste the URL for that particular post within the thread
Old 04-25-2008, 04:29 PM   #13
Hoots Magoon
Oddometer: 1,252
Would you perfer this;
or this?
Low seat -vs- stock seat pics
http://www.advrider.com/forums/showp...&postcount=288
I'm all for trying to make it easier on you. Thanks for compiling all the information for us.
Hoots
Old 04-25-2008, 04:43 PM   #14
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,717
The top link looks better
Which reminds me... I gotta do a pictorial of the Xmoto low seat on the X Challenge.
Old 04-25-2008, 04:58 PM   #15
Hoots Magoon
Oddometer: 1,252
Acerbis will send out the tank with the siphon kit, which can be hooked up to the vent to siphon automatically.
Times are GMT -7.   It's 04:40 PM.
