Old 10-13-2008, 12:08 PM   #136
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,544
Talking
Originally Posted by tudorSD
What tools are you guys carrying with you for tire repair?
Finding something that is small-ish for taking off the wheel nut (26MM) is pretty tough...
Any other good tool tips?
One of these:
http://www.denniskirk.com/jsp/produc...d=11906&mmyId=
Plus these:
Add this to your combo tire lever:
Then add your 26mm socket.
I didn't spend the extra $15 bucks and just use the 27mm combo lever. It doesn't fit on the front end though so I would recommend getting the adapter.
Your welcome!
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is online now   Reply With Quote
Old 10-13-2008, 12:13 PM   #137
tudorSD
Big Bike Basher
Oddometer: 53
Perfect answer. And quick too... Thanks.
tudorSD is offline   Reply With Quote
Old 10-13-2008, 01:07 PM   #138
oggi
oggi's Avatar
Oddometer: 69
transmission horror
the last weekend while running the pb300, I rea;ized how horrible the xchal transmission is, its less than 1000 miles on the engine and it was finding neutrals everywhere but where neutral should be, half-shifts with horrible cartoon like grinding noises searching for gears, landing on jumps and the momentum of landing shifting the lever down one... everything was shitty
I heard that switching to synthetic oil fixes a .lot of the issues..but why is it so bad to begin with, and does the oil change actually fix anything
oggi is offline   Reply With Quote
Old 10-13-2008, 02:02 PM   #139
Bora20
Oddometer: 854
I have a spare 21" tube, some small irons, the minimal amount of tools possible, and a Mastercraft Professional 1.25" adjustable wrench for the 26mm socket. It was expensive, but it doesn't mess up the nut.
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 10-22-2008, 08:59 PM   #140
atokad
wan⋅der⋅lust
atokad's Avatar
Oddometer: 2,620
Originally Posted by Gadget Boy
Let's list them here and then I'll copy them there:
There are the 3 listed in the Must Do Mods.
I also have the stalling issue which is from a pinched breather hose.
Some have reported battery failures, but that's the battery not the bike.
I've also listed the recalls.
what else could we add?
How about a "Nothin but Pics" link.
atokad is offline   Reply With Quote
Old 10-26-2008, 09:02 AM   #141
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,641
Coolant
Man, I must say that I'm thoroughly disgusted with the X Challenge owner's manual. I know this has been brought up before, but what was Gunter thinking when he built a bike, but didn't tell the rider/wrench how to perform basic level maintenance.
Was installing the Uni air filter and de-snorkeling the X when I noticed that the bike could use a little coolant. The manual has zip, nada, nothing on the coolant type or mixture ratio used in the bike. It obviously ain't a conventional "green" anti-freeze. CAN ANYONE TELL ME WHAT TYPE COOLANT AND MIXTURE RATIO TO RUN IN THE MY X CHALLENGE?
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler screwed with this post 10-26-2008 at 01:26 PM
Tarheel Wheeler is offline   Reply With Quote
Old 10-26-2008, 09:19 AM   #142
PacWestGS
Life Is The Adventure!
PacWestGS's Avatar
Oddometer: 10,866
Well, any motorcycle coolant would work, or use the universal (aluminium safe) and mix at 50/50.
Russ
The world is a dangerous place to live, not because of the people who are evil, but because of the people who don't do anything about it. (Albert Einstein)
PacWestGS is offline   Reply With Quote
Old 10-26-2008, 01:54 PM   #143
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,367
Check out the Ride Reports link in the Index thread, or start a show us your X Challenge thread..
Old 10-26-2008, 03:20 PM   #144
Daithi
Destination Unknown.
Daithi's Avatar
Oddometer: 176
And don't forget the bleed bolt for the Cooling System, an airlock caused us a lot of problems.
CCM404 & DRz1000
Daithi is offline   Reply With Quote
Old 10-26-2008, 03:46 PM   #145
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
Could you pls describe procedure for exchanging cooling unit? after loosing hose going to water pump - now I have an mixture which contains mostly water ... and I would like to switch to more normal cooling fluid as cold days are coming....
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 11-11-2008, 08:46 PM   #146
grandmasterlarry
Oddometer: 4
UPDATE on brake pads! (dont know if anyone had said anything on this i looked today for pads and the 209/hh where no longer avalible so i found this) also has rotor numbers!
EBC cahnged part numbers
Organic Pads / Shoes (Front)Sintered Double-H Pads (Front)OE Replacement Rotor (Front / Left)OE Replacement Rotor (Front / Right)Contour Rotor (Front)Custom Rotor (Front)Organic Pads / Shoes (Rear)Sintered Double-H Pads (Rear)Contour Rotor (Rear)Custom Rotor (Rear)
FA209/2FA209/2HHMD650LSFA213FA213HHMD651
picked them up from oemcycle.com for $30.94 front and $26.94 rear.
this is driectly from EBC part catalog.
http://www.ebcbrakes.com/catalogues.html
might wanna update the main index!
grandmasterlarry is offline   Reply With Quote
Old 11-14-2008, 12:28 PM   #147
Johnnyboxer
Oddometer: 1,035
I used some Shell Rad coolant, mixed @ 50/50 to top up mine and all seems ok
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 11-14-2008, 05:19 PM   #148
Firefight911
Firefight911's Avatar
Oddometer: 997
Thumb
Coolant capacity is 1.1 litres, mixed 50/50 for normal use. Can be run as high as 60/40 in really cold climates per BMW. Coolant used MUST be sulfate and nitrate free.
Just run down and grab a gallon from your local dealer - LINKY
Just went through this after I sheared the water pump cover off riding through a boulder field.
Ride Safe, Ride Often, RIDE!!!!
Firefight911 is offline   Reply With Quote
Old 11-16-2008, 03:44 PM   #149
dmcd
dmcd's Avatar
Oddometer: 570
I checked the oil in my xchallenge about 100 miles ago and it was in the middle of the hi-lo marks. It hadn't been started for about a month, so today I rode about 20 miles and when I checked it, it was just touching the bottom of the stick. I let it tick over with the fan on for a couple of minutes and made sure it was upright etc etc.
Has anyone else noticed a dramatic drop like this? Or did I not ride it far enough?
dmcd is offline   Reply With Quote
Old 12-23-2008, 02:51 AM   #150
Flying Doc
Flying Doc's Avatar
Oddometer: 12
Originally Posted by mxchamp
One of these:
Plus these:
Your welcome!
I think I have come up with a slicker solution?: http://www.advrider.com/forums/showp...postcount=2261
Tell me what you think?
Trick Cyclist
Flying Doctor
KTM 690 Enduro 2010
Triumph Thruxton 900 2005
Honda Z50JZ 1979
Flying Doc is offline   Reply With Quote
Times are GMT -7.   It's 02:13 PM.
