09-02-2010, 04:39 PM
#1561 | ||
Challenged Adventurer
Oddometer: 1,385
Max Quote:
I am feeling more energized now
ex X phile Avoid the Gavel, travel by gravel |
09-02-2010, 05:52 PM
#1562 |
"Moto Porn"ographer
Oddometer: 3,831
If its the sprag clutch ...
as a quick fix, you can just clean the pick up coil, change the oil and filter, but it will be only a matter of time before it happens again.
There are two bits to change on the sprag clutch ... 12117652871 FREE WHEEL HOUSING 12117687777 FREE WHEEL And they aint particulalrly cheap Why this happens on X-challenges but not on the F650 GSs I dont know
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE World Motorcycle Altitude Record video HERE www.sibirskyextreme.com |
09-02-2010, 06:48 PM
#1563 | |
Dusty and Thirsty
Oddometer: 1,305
I did like the feel of the air shock when I had it on the bike, but the ohlins is better. There are a few other options, I just went with ohlins. I did have to modify the reservoir bracket as I have the H&B bag mounts but that was relatively easy if you have drilling, cutting, and grinding equipment. If you don't have the H&B bag mounts there is no issue.
Rob Swartzwelder, Southern AZ I'm not real fast, but I do have a dog named Dakar! 97 M900, 07 G650 XChallenge,11 KTM 990 ADV R 2011 North up the CDR Sierra Vista AZ to Paonia CO and Back through Moab UT |
09-02-2010, 07:19 PM
#1564 | |
Oddometer: 538
I would prefer the ohlins too. Meanwhile, I have had to deal with the airbag. I noticed the rubbing had got worse on a recent trip (a long way from home...). I wrapped the airbag with a few rounds of duct tape. This doesnt interfere with its action, and provides a good sacrificial layer. After another 3K kms, I notice the tape is showing no wear. Quick and easy peace of mind.
09-02-2010, 08:03 PM
#1565 |
Oddometer: 387
p/n for chain guide
has anyone got the KTM part number which is molded onto the plastic part of the TT rear chain guide? I ordered one off the 640A thinking it was a guide; I got only a half guide so its only offering protection against a foot getting caught in the sprocket.
I need a full guide. thanks
2001 BMW F650GSR "Rallye" (work in progress) visit BMW F650GSR project thread here |
09-02-2010, 10:48 PM
#1566 | |
Oddometer: 714
Were you guys using the standard drain plug or the Touratech one? I was using the Touratech one because the stock one stood proud of the bashplate, but have swapped back now that I have Stephan's bash plate. I wonder if your problem was due to the lack of magnet in the touratech plug? Fortunately I have had no problems with swarf fouling the pickup yet (21k miles). |
09-02-2010, 11:02 PM
#1567 | |
Oddometer: 1,385
![]() I cant wait to get home and rip the cover off !
09-03-2010, 01:01 AM
#1568 | |
ENDURO Wanabee
Oddometer: 181
I'm using standard - as Touratech one has no magnet on it. So I would not suspect that as a cause. My drain plug normally looks like one shown above. My BMW F....ing dealer was repairing that issue for 6 weeks ! they even replaced a BMS-C in meantime (no comments). I think that real time sensor values should be displayed on diagnostic computer so for dealer finding that problem should take 30 minutes.
Regards Lucas ---------------- I have a new challange ..... X-Challenge .... www.vimeo.com/mtbiker http://picasaweb.google.com/lukasz.lechowicz/XChallenge |
09-03-2010, 01:08 AM
#1569 | |
Dirt Virgin
Oddometer: 1,595
It's: 546.07.066.100 Photo to follow.
"A girl riding a motorcycle?...................What is this, the Twilight Zone??" Why do people think bike riders all like rock'n'roll??
09-03-2010, 01:13 AM
#1570 | |
Dirt Virgin
Oddometer: 1,595
Rob, don't forget to get your rear splashguard replaced - it's a recall item. I think my dealer has tried to "pull a swifty" the "new" guard looks suspiciously like the original one. Does anyone know where the photo of the original and the replacement splashguard is?
09-03-2010, 01:16 AM
#1571 |
Dirt Virgin
Oddometer: 1,595
I hang my head in shame........I snapped an axle pinch bolt.
Now that I will be using a torque wrench for my nuts....... .......is there any reason why I can't use stainless from my fastener supplier??
09-03-2010, 02:15 AM
#1572 | |
Oddometer: 1,385
![]() I have used a toothpick to indicate a deposit of fine metal fragments. I am hoping that there was enough there to be the cause of my problem. I unfastened it from its housing and washed it. I will try and get a gasket and oil filter tomorrow - reassemble and test
09-03-2010, 02:20 AM
#1573 | |
ENDURO Wanabee
Oddometer: 181
09-03-2010, 03:45 AM
#1574 |
"Moto Porn"ographer
Oddometer: 3,831
thats the one ... and for the earlier question, I also only use the original sump plug. It collects the big chunky flakes of metal fine, but some of the finer stuff shorts out the pick up coil once the sprag clutch starts to go.
09-03-2010, 05:15 AM
#1575 | |
Oddometer: 2,088
Marc 07 XChallenge 99 VFR |
