Old 09-14-2010, 05:44 AM   #1621
bigdon
Oddometer: 2,616
If you buy your Ohlins from Rick at
http://motocd.com/index.php?option=com_contact&Itemid=3
he can set your ride height ,spring it for your weight, and do it all at a discounted price.
Just a very happy customer!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is online now   Reply With Quote
Old 09-14-2010, 10:40 AM   #1622
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Since we are on the subject of suspension I will pose this question to you all.
What is the best thing to do to the forks besides swapping them? I am about 200-210 LBS with gear. I put an ohlins shock on the rear and am happy with that but the frontend feels like a wet sponge. I don't really want to swap out the forks, will new springs and a different weight oil do the trick? I just want to firm it up a bit.
What is your experience?
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 09-14-2010, 11:16 AM   #1623
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,293
Do these bikes suffer from heat exhaustion?
I did some 1st & 2nd gear single track running for the first time this weekend.
The fan ran the WHOLE time, no other bike I have owned has done this.
Others will kick on now and then in the tight stuff, but not constant running.
Other than the fan, the bike ran OK for the first hour, but after that it developed a real bad stumble when trying to apply power out of tight corners.
I had to throttle and clutch every tight corner after the first hour to keep from falling.
Even after short rest stops and breif higher speed fire road runs it did not get better until I ran it on the road for several miles.
Anyone else experience this?
After the first hour this bike is NO FUN on the trails.
Of course there is no way to "duplicate" this for the dealer so I will get no where with BMW.
Ogre_fl is offline   Reply With Quote
Old 09-14-2010, 03:55 PM   #1624
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,513
Maybe the gearing is too high. BMW offered `enduro` gearing as an option when these bikes were new - 14/47, down from 15/47.
I have similar overall gearing, but a different combination on my bike, 15/50, this makes life a bit easier for the front sprocket.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 09-14-2010, 04:01 PM   #1625
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,696
Fan
My fan runs most of the time while off road single track. I've never had the hot water light come on. I figure the fan is doing its job. There is an after market BIG radiator for it.
QUOTE=Ogre_fl]Do these bikes suffer from heat exhaustion?
Of course there is no way to "duplicate" this for the dealer so I will get no where with BMW. [/QUOTE]
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 09-14-2010, 04:09 PM   #1626
plumber mike
Highdive Deepened
plumber mike's Avatar
Oddometer: 3,806
These bikes have a smallish electrical output. Is it possible they used a smaller fan on the X's.
That said, I've never overheated it ( Well except the time I put a hole in the rad )
2002 Yamaha PW80 don't break it dad!
1996 Honda XR250R just right.
plumber mike is online now   Reply With Quote
Old 09-14-2010, 04:24 PM   #1627
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,293
No overheat lights came on, nor did it boil over or anything like that.
It just changed from good throttle response/easy to ride to a bad stumble.
While lower gearing would not hurt, it was fine for an hour, so it would seem it is not "needed"
I beleive the stumble would still happen even with lower gears.
Old 09-14-2010, 05:39 PM   #1628
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,033
Something isn't right there Ogre, mine shows none of those points you mention. Going to a 14 front certainly makes takeup a bit easier/smoother in single track but that isn't your problem from the sound of it. Possibly running too lean????
After fitting a Boosterplug to my bike the cooling fan does not come on as often as before and I presume this is because the settings are made a little bit richer under throttle openings etc. Anyone???
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 09-14-2010, 05:55 PM   #1629
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,033
I have been exploring this for the past year to the extent of trying to fit a Honda CRF front end yesterday. It was just a few mm out each side in the fork clamp width to stop being bolted on.
I fitted Hyperpro springs (same weight as you) and 10 weight oil and it did make a big improvement over standard but still not a great set of forks for hard off road work. I found when fitting my springs that the left leg oil level was less than half what it should have been and my forks have never shown any signs of leakage.
This would be the springs you are after.
FRSP 405149 RT FRK SPR 39.5x508mm .49kg
http://old.racetech.com/evalving/eng...ngname=english
OR: Find some 45mm Marzocchis off of a Husky or GasGas and use the internal cartridges in you forks with a little bit of lathe work at the bottom. Marzocchi do not seem interested in selling the cartridges and would cost an arm and a leg anyway. Only other forks used so far appear to be WPs
xronly
Old 09-15-2010, 02:54 PM   #1630
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Thanks for the info, PM sent.
Old 09-15-2010, 08:01 PM   #1631
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,425
Send them to TrailTricks to have them resprung and revalved for your weight and riding style. Incredible difference in how the bike handles.
tbarstow is online now   Reply With Quote
Old 09-16-2010, 03:32 AM   #1632
Dukehunt
Dukehunt's Avatar
Oddometer: 759
All the comments on fixing the forks on the XC's seems to be a compromise so I have bitten the bullet and going for the 48mm WP forks, emig triple clamps etc, yep it aint cheap and if it still handles like shit then I sell her and get a KTM 690.
Dukehunt is offline   Reply With Quote
Old 09-16-2010, 05:46 AM   #1633
"A"
numbum
"A"'s Avatar
Oddometer: 377
I've done that and you will be pleased to know that it does not handle like shit . You will still need to have the correct spring rate of course. My WP's also had some valve work done at a suspension specialist. Interestingly my forks came off a 690 because the owner wanted better forks for it! It would appear that many are not satisfied with their suspensions no matter what the bike is- there is always something better.
"A" is offline   Reply With Quote
Old 09-16-2010, 08:55 AM   #1634
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,580
I might just do that with my stock XCountry forks. If they put in progressive springs and re-valve it do you think it will make a big difference? I'm not trying to achieve XChallenge perfection, but now that I have the Wilbers 642 shock on, the forks are the weak link, naturally...
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 09-16-2010, 08:59 AM   #1635
snooker
snooker's Avatar
Oddometer: 1,580
Can't comment on the stumble when hot, but for better cooling you could try some coolant additives like Redline's Water Wetter or maybe better is Engine Ice coolant. People seem to notice a big difference I've read.
Times are GMT -7.   It's 10:49 AM.
