Old 10-06-2010, 07:35 AM   #1666
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,706
Ditto
Originally Posted by tbarstow
They just replaced my mud flap under recall when I took it in for the roller recall.
Mine has ABS so I got a new ABS junction box bracket on the steering head colum and a new roller pin thingy and a new rear mud flap all on one recall shot.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 10-06-2010, 07:48 AM   #1667
MizzouRider
MizzouRider's Avatar
Oddometer: 1,759
I'm taking mine into the dealer tomorrow. Was just hoping for the mudflap and roller thingy.
Will let you know..
Then I have to take the GSA in for new brake lines.
Did Toyota take over BMW? Just kidding I have more Toyotas than BMWs.
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 10-06-2010, 05:17 PM   #1668
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,538
It does just fine. You will need to loosen the header pipe up front and push it up higher to create a bit of space between the header and the coolant line. Check it every few rides. Mine has needed to be adjusted once in the 2 years its been on my bike.
gsstampeder, I also loosened the header pipe per everyone's suggestion. The strap is strong enough but that 2-bolt connection that can rotate to adjust the muffler position... well on my first off road trip it let the exhaust rotate down, even though I had loctite'd it and torqued it down. And this can make it get really close to the coolant hose further up the pipe, some guys have had their hose sear so it can be serious.
So I added a small aluminum strap from that connection point around the nearby grab handle (or tail rack arm) about 1-2" away. It is clean and simple and gives me more confidence in it. Love the Leo.
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~
FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar!
snooker is online now   Reply With Quote
Old 10-06-2010, 05:22 PM   #1669
slide
A nation in despair
Oddometer: 21,122
Snooker,
How much louder over stock? How much less weight to you think?
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 10-06-2010, 07:16 PM   #1670
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,298
Originally Posted by slide
Snooker,
The Leo pipe with the quiet insert is maybe as loud as the stock pipe.
tbarstow is online now   Reply With Quote
Old 10-06-2010, 08:09 PM   #1671
snooker
snooker's Avatar
Oddometer: 1,538
Snooker,
You mean the Leo Vince?
Well before I bot it I read a 2 yr old post from Max Kool comparing the LV to stock as:
"Stock: soft wet fart
LeoVince with legal insert: fruity clear bark, but still legallish."
It *may* be louder than stock by a bit, IMHO, however to me it is definitely NOT loud at all. I did not want loud! It just sounds healthy like a thumper should sound, I love the sound. And this is with the quiet inserts with the spark arrestor, described as Long and Skinny in this exhaust thread post with pictures.
Just getting rid of the cat and all that frickin' heat is reason enough to buy it. I don't know the exact weight difference, but the bulk, weight difference and power improvement are substantial.
Old 10-07-2010, 03:06 AM   #1672
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,229
.. while in the meantime I've sold my LV.
I found it still a bit too loud (needed repacking maybe?), and during time the stock one has become less wet-fartish.
Im happy with a quiet bike.
Max Kool is offline   Reply With Quote
Old 10-07-2010, 03:31 AM   #1673
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
Hey Max, did you open the oem one up a bit from the end pipe? Makes it breath a lot better and runs cooler. Makes it a lot more responsive and less engine braking on deceleration.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 10-07-2010, 07:08 AM   #1674
gsstampeder
gsstampeder's Avatar
Oddometer: 1,066
I installed the LV the way it came, I will put the spark arrester in tho, but I haven't found any noticeable performance improvement since installing....in fact, I think I may have lost some top end power. Not sure if I'm connected properly. I'll play with it some more. The LV did not have a gasket in the connector pipe or the silencer and I questioned that too....but I am no bike tech, so I just assumed it was as it was meant to be.
gsstampeder is offline   Reply With Quote
Old 10-07-2010, 01:33 PM   #1675
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
Amazing how marriage changes a man!
What was once a "wet fart" is now something you are "happy with".
I hope you arent planning on giving up motorcycling altogether Max, on the grounds of it being socially irresponsible!
Oh how the wild man of the Eastern Europe Rally has been tamed!
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 10-07-2010, 01:43 PM   #1676
slide
A nation in despair
Oddometer: 21,122
I think my stocker has gotten louder. I have gotten to enjoy the quiet so much, especially out in the wooded mountains, that I'm very reluctant to give the bike any more bark. Yet I would like a smaller / lighter can.
thanks for the reply. I'm mulling it now.
Old 10-07-2010, 08:18 PM   #1677
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,656
Colebatch emerges in a non-Colebatch thread! And tells us secrets about Max Kool! Walter, can you post us a pic of married-man Max driving his new Ford Fiesta?
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 10-08-2010, 02:06 AM   #1678
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,229
think so?
(btw you were on the wedding, hope you agree we're not "the average model couple")
Old 10-08-2010, 02:27 PM   #1679
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
it was a cool wedding ... very dutch in its informality and innovative concept. I liked it :)
Old 10-11-2010, 07:32 AM   #1680
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
Does anyone know if GS1200 (and 1200A) clutch and front brake levers will fit straight onto the X Challenge?
xronly
Times are GMT -7.   It's 01:52 PM.
