Old 11-05-2010, 12:12 PM   #1771
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,191
Send a message via MSN to mxchamp Send a message via Skype™ to mxchamp
Talking
Originally Posted by Ogre_fl
Update. Fixed ???
Last Saturday I removed the idle actuator and cleaned it and its port in the throttle body.
Upon first start up it stalled and idled funky so I figured it did not work.
After that, it started and did not stall, but still had a pretty lumpy idle.
I rode it every day since, cold starting the bike at least 3 times a day and it has not stalled, including today with temps in the 40's.
The idle seems to be smoother and more consistent now as well.
FWIW I did this with only removing the side panel and disconnecting the battery.
I did not remove the airbox nor the throttle body.
It was very easy to do, but care should be taken to clean all around the actuator before removing it.
It was filthy and crap could have got into places you wouldn't want it.
Now I will say that I "think" the cleaning did the trick, but it might have also simply been that I disconnected the battery for 15 mins while I did the cleaning and that supposedly re-sets the ECU.
I would like someone with the stalling problem to try simply disconnecting the battery for 15 mins and see if over the next few days if it fixes the problem.
If not, simply cleaning the actuator on the bike is really easy and seemed to fix it for me.
When it comes time to check the valves and the airbox has to come off I plan to look at the throttle body itself and clean it and the actuator again, but hopefully this quickie actuator only cleaning will last for the next 4000 miles.
Please post pictures of the actual job that you did.
If it doesn't work for me, a boosterplug is in my next farkle addition.
Ride safe!!!!
J
There are 3 kinds of people in this world:
Those that make it happen-
Those that watch it happen-
And those that stand around sayin---WHAT HAPPENED?
2001 KTM 640 Adventure R (back home in my garage with a fresh brand new engine! She is purring like a kitten!
2002 KTM 520 EXC (plated)
BMW MOA #137435
mxchamp is offline   Reply With Quote
Old 11-05-2010, 12:38 PM   #1772
Ogre_fl
Ogre_fl's Avatar
Oddometer: 1,743
Sorry, I didn't take pictures as I did it.
Remove the right side "tank" cover and the idle actuator is on the right side of the throttle body.
Its a little tight but you can get to it and remove it.
I used the BMW REPROM as a reference, maybe this will help, bear in mind the airbox is still on.
Ogre_fl is offline   Reply With Quote
Old 11-05-2010, 03:58 PM   #1773
The Jester
The Jester's Avatar
Oddometer: 711
I did this at the weekend as well, except I did it as part of a service where I was also checking the valve clearances, so had the airbox off. I lifted off the throttle body while I was in there and was able to flush the whole thing out with carb cleaner. There was a lot of muck on mine, built up in the idle circuit.
The throttle butterfly effectively closes off the whole of the main airflow path. The idle circuit is a small passageway which bypasses the butterfly. The idle actuator is a small electro magnet which moves a plunger back and forth to open and close the passageway. Undo 2 screws on the side of the throttle body and there it is. Definitely not rocket science.
I wouldn't say I had a major stalling problem but it would cut out from a cold start. After reassembly the bike started first touch of the button, more easily than normal, and settled down to a really smooth idle, much smoother than before. I also replaced the plugs with platinum ones so this may have helped but the amount of muck in the idle circuit would not have helped the situation.
Yet to get out and ride it though as I have been walking around like c3po all week with a bad neck.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 11-05-2010, 04:36 PM   #1774
MrMike
No self control
MrMike's Avatar
Oddometer: 781
What I did
OK so I've been trying to get my stall problem fixed too for the 7 months I've owned it. Mine used to do this: I would start it cold, or having let it sit for 1 1/2 hours so pretty cold, I don't touch the throttle when starting, after about 1 minuet it would stall. I could put a clock on it as it was that consistent. Sometimes just a stall and sometimes with a screeching sound. After reading all the threads about how to start it nothing worked. So I bought the higher volume injector that is talked about in the how to richen you Challange thread and installed it along with cleaning the idle actuator. It's been 3 months now. It does not stall during the idle period any longer, but if I try to ride the bike before about 4 minuets of a cold/semi cold start it will die as soon as I crack the throttle. But if I wait the 4 minuets it will burble a little but not stall, then when fully warm no problems in the way it runs. Also I find that if I do the turn the key on, turn the throttle full twice, and turn the key off every few days it seems to help with the off Idle coldish burble slightly. This still tends to piss me off if I'm in a hurry as I have to just sit there waiting for it to come alive so I can ride off. So I've just ordered the booster plug to see if it will allow me to do what every other fuel injected bike and car I've owned did and that was to start it dead cold and ride/drive right off. I don't do that but it should. So we'll see if the booster plug helps my cold start problems.
'09 KTM 530 EXC
'10 BMW R1200GS
MrMike is offline   Reply With Quote
Old 11-05-2010, 10:17 PM   #1775
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 2,655
MXChamp--every time I see a post from you I'm reminded of how much I miss your old avatar. Could you put it into the body of a post somehow for all to be mesmerized?
WUMPA!
Goot-Z
4XKPN - sold
DRONE is offline   Reply With Quote
Old 11-06-2010, 03:44 AM   #1776
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,794
Stolen XC
My heavily customied XC was stolen overnight in Holland. Anyone in Europe seeing unusual XC bits, or bits they recognise from my bike on places like ebay and the dutch equivalent maarkplaats, please let me know
Sibirsky Extreme 2009 BOOK and DVD available HERE
Moroccan Extreme 2011 DVD available HERE
www.sibirskyextreme.com
Colebatch is offline   Reply With Quote
Old 11-06-2010, 04:10 AM   #1777
MizzouRider
MizzouRider's Avatar
Oddometer: 1,434
I'm sure sorry to hear this.. Colebatch, I hope you get it back soon, and in one piece..
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 11-06-2010, 05:31 AM   #1778
Alcanara
's not me occifer
Alcanara's Avatar
Location: Harrogate (UK) and Murcia (Spain) Trail Heaven
Oddometer: 122
Amazing isn't it... you go all over Eastern Europe with it and it is fine.... get back home and some scroats swipe it. Makes your blood boil.
I hope you get it back soon.... It has so many non std bits on it...It has to be recognisable
Good Luck Colebatch
G650 XChallenge Feb 2008, R1100S 2003, F650CS 2003 (My Wife's)
Retired Young and broke:- but in Spain where the sun shines and the beer is cheap... what more could you want
Alcanara is offline   Reply With Quote
Old 11-06-2010, 06:15 AM   #1779
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 181
Its a lot of quite unique piecies in your machine Walter - will keep an eyes on ebays and local market...
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 11-06-2010, 06:23 AM   #1780
DrWatson
DrWatson's Avatar
Oddometer: 428
Just put the TT tank on, however without connecting fuel lines as yet.
Am thinking of connecting via a T piece to the main tank air breather rather than drilling holes in main tank.
Those that have done this method, could you please advise if you had any issues with air leaks, fuel leaks etc?
Did you use the breather hose supplied for the connection to the T piece?
When filling up, do you fill the main tank 1st, then the TT tank? Any filling or draining issues?
Thanks (btw I have read all the threads, however just want up to date info from those who have personally done this method)
DrWatson is offline   Reply With Quote
Old 11-06-2010, 07:37 PM   #1781
kpie
Oddometer: 126
Question on Seat
Hello all .... Is the seat supposed to fit (black indentations on seat pan) down under the aluminum clips welded on the subframe, or are they to sit on top of the clips? Cannot get them down under the clips so I don't know if the damn thing is really on correctly or not! Help!
kpie is offline   Reply With Quote
Old 11-06-2010, 08:18 PM   #1782
DiscoDino
DiscoDino's Avatar
Oddometer: 1,812
As far as I know & manage to do so, under
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 11-06-2010, 08:19 PM   #1783
mxchamp
Registered Lurker
mxchamp's Avatar
Oddometer: 1,191
Talking
Thanks for the helpful info.
And a nice little gift for Mr. Drone!
Ride safe!!!!
J
BMW MOA #137435
mxchamp screwed with this post 11-07-2010 at 10:34 AM
Old 11-06-2010, 08:28 PM   #1784
kpie
Oddometer: 126
Yes, thanks. I must be getting old. tabs were pushed down from sitting on top. pulled them back into position and the seat is now on correctly. Thanks.
Old 11-06-2010, 08:33 PM   #1785
kpie
Oddometer: 126
Ran it through the breather vent. No problems. Tried the Touratech way and had leaking from the stock tank (drilled holes). Got a replacement stock tank and routed through the breather vent. I would recommend this is the best way to run it. Use Motion Pro Tyvek fuel line as the Touratech supplied line is junk.
Times are GMT -7.   It's 01:13 PM.
