Old 02-02-2009, 08:03 PM   #256
ropedrag
ropedrag's Avatar
Oddometer: 313
Originally Posted by JimC
Try adjusting your clutch lever play. I used to laugh when people started complaining about their bikes stalling because my X never stalled. Then one day after about 4000 miles it stalled on me, the problem got worse. I tried several things and nothing seemed to work. One day I adjusted the clutch lever free play (reducing the play) and my bike stopped stalling. It stated stalling again a couple thousand miles later, I adjusted the clutch again and it stopped. I am guessing the bike runs so lean at idle that the slighest drag on the clutch caused it to stall. This would also explain why it is not an issue when the bike warms up, as the oil has thined out reducing the drag.
Give it a try, it worked for me, and you can't beat the price.
Jim in Sacramento
Their is a switch connected to the clutch lever, it's a position switch actually. And yes it can stall/kill the motor. No theory involved as steel is shrinking at temps less then 68 degrees (I use to know the formula to calculate the contraction over a known distance at the known temp but I can't recall it right now) anyway on a cold day steel will shorten/shrink and if the free play is not correct it can kill the motor. This should be a likely candidate if you are experiencing this issue. Go look at that position sensor electronic switch coming out the back side of the clutch lever.
I also spoke with a service tech about this very subject and he stated the clutch free play is the first thing they look at for cold temperature stalling issues.
Do not mistake for wisdom the fantasies of your sick mind
ropedrag is offline   Reply With Quote
Old 02-03-2009, 03:54 AM   #257
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 379
Clutch lever & gear lever switch bypass how-to?
... Go look at that position sensor electronic switch coming out the back side of the clutch lever.
Speaking of which:
I'm not sure if someone has made a step-by-step guide on bypassing the clutch lever switch, and also the switch on the gear lever?
I know this has been done, would anyone care to elaborate how the bypass should be done? Remove switch, connect some wires, do this/ don't do this -kind-of-thing. I've been meaning to do this, and now that my guarantee is over anyways, I'd be willing to go ahead with it.
Stable: BMW R 80 GS -90, KTM 690 Enduro R -12 // finnduro.com
FinnDuro is offline   Reply With Quote
Old 02-03-2009, 04:05 AM   #258
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
I did.
Clutch: just remove the switch and solder the two wires together
Sidestand: remove the switch and connect the red and the white wire together.
Max
Max Kool is offline   Reply With Quote
Old 02-03-2009, 04:11 AM   #259
FinnDuro
FinnDuro's Avatar
Oddometer: 379
Purrfect!
Simple & effective, thanks Max.
Old 02-03-2009, 05:41 PM   #260
MTDewX8
MTDewX8's Avatar
Oddometer: 506
Hard Parts
Check the vendors thread for those that have ordered the "Hard parts"
I need address for most of you guys.
thanks
Bike-less at the moment
MTDewX8 is offline   Reply With Quote
Old 02-04-2009, 04:10 AM   #261
robbiedobbie
Robbiemyboy
robbiedobbie's Avatar
Oddometer: 250
Sprocket
Hi Chaps, i'd like to fit the 14 tooth sprocket to my bike. Does anyone have the part #? Or where i can buy one in Australia .
Robbie
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
robbiedobbie is online now   Reply With Quote
Old 02-04-2009, 05:06 AM   #262
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
JT Sprockets JTF 402, available in 13 - 16 teeth
(same type as on the F650 Funduro/ and Dakar, or the Aprilia Pegaso)
Old 02-04-2009, 05:23 PM   #263
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,845
Risers and rad gaurd
Too chilly to work in the barn tonight so i snuck into the basement.. a couple pics of the work and a few needed tools.
and yes my air shock is showing wear...
" You need a new sig line."- H14
"I despise you and want my refrigerator magnet back!" - VB Divers ex-girlfriend
bloochdog is offline   Reply With Quote
Old 02-04-2009, 06:55 PM   #264
ropedrag
ropedrag's Avatar
Oddometer: 313
Damn, you must have some big ass vermin in that basement of yours!
Old 02-04-2009, 07:16 PM   #265
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,845
that is
thats is for tele marketers ..
ohhhh the phone?
that is in case my GF calls..
Old 02-04-2009, 07:50 PM   #266
MTDewX8
MTDewX8's Avatar
Oddometer: 506
Pump
OK, what is that little screw in presta size fitting that comes on out stock pump. you have to take that out to screw in the fitting to pump up the shock. is there a purpose? (I am missing something )
second where do you find floor (bike) pumps to keep in the garage? to make it eaiser to up the PSI before I ride. the under seat one works, but dam arm is tired. have a girl friend so its out of shape you know.
thanks
Old 02-04-2009, 10:51 PM   #267
Motor-110
...respect my Authoritah!
Motor-110's Avatar
Oddometer: 597
hehehehhe, his Glock is showing.
"Fresh BMW's and whisky for all my men!"
M-110
Motor-110 is offline   Reply With Quote
Old 02-05-2009, 03:29 AM   #268
robbiedobbie
Robbiemyboy
Oddometer: 250
Laugh Sprokets
Hi Max. Thanks
Old 02-05-2009, 05:41 AM   #269
ropedrag
ropedrag's Avatar
Oddometer: 313
thanks
Pump
http://www.performancebike.com/shop/...tegory_ID=4360
Old 02-05-2009, 06:17 AM   #270
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,845
Balistic' break free"
The Glock is also used to loosen stubborn nuts... from my property and this mortal coil...
Any of you guys gonna be at Laurel Fork in early May?
Times are GMT -7.   It's 04:27 PM.
