Old 12-23-2012, 01:54 PM   #4336
john_aero
john_aero's Avatar
Oddometer: 1,166
have few issues still with hot start and idle
was aware of ti when got bike, so would let settle for 15mins and workaway after that
other day had it out and even after an hour sitting off it still wouldnt idle
i did the actuator removal and clean.valves are ok, 1 exhauts was bitbig but not bby much
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 12-24-2012, 05:50 PM   #4337
dantroop
dantroop's Avatar
Oddometer: 173
I finally filled the new tank with gas and took it out for a test run. 2.3 gallons. It seems the cap is not vented so I'll get one in the next few days. After opening the aux cap after 16 miles there was gurgling then the level of gas went down. Only ran about 38 miles today.
dantroop screwed with this post 12-26-2012 at 05:06 PM Reason: typo
dantroop is offline   Reply With Quote
Old 12-27-2012, 01:19 PM   #4338
Travlr
Oddometer: 76
Question Instrument cluster issue?
I had posted this in the garage section, but this is probably the better location. Help!
http://advrider.com/forums/showthread.php?t=851205
Travlr is offline   Reply With Quote
Old 12-27-2012, 04:41 PM   #4339
August West
Wharf Rat
August West's Avatar
Oddometer: 553
Open the ignition switch (cylinder the key goes into) and make sure the solder joints are not degraded. This sounds like my symptoms. Solder joints were toast. i bypassed the key switch with a rocker switch.
Good luck!
August West is offline   Reply With Quote
Old 12-28-2012, 08:18 AM   #4340
Travlr
Oddometer: 76
xchallenge instrument woes
Tried that, they are soundly attached. The bike never dies out when the lights go off, and it always has power to the ignition system for starting.
I have also noticed that when the key is turned but the engine not started that the problem does not occur.
thanks for the response.
Old 12-30-2012, 07:35 PM   #4341
Royal Tiger
Pz VI B, Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,380
I bought the Trackside clutch lever for a Suzuki RM250 at Cycle Gear for $11 and it fit perfectly.
2013 Yamaha XT250 * 2012 Kawasaki Ninja 250 {SOLD} * 2007 BMW G650X XChallenge {SOLD} * 2005 BMW R1200ST {maybe FOR SALE} * 2003 Yamaha PW80 {FOR SALE}
Royal Tiger is offline   Reply With Quote
Old 01-01-2013, 01:18 PM   #4342
The Jester
The Jester's Avatar
Oddometer: 834
voltage check
Anybody able to do me a favour? Pop out to your bike switch on the ignition but don't start the motor. Switch the display to voltage and tell me your reading. Mine is showing 11.8V steady with the headlight off but drops down towards 11 once the headlight is turned on. The bike has developed a habit of cutting out on idle during the last few weeks and I'm thinking the battery might be on the way out but don't want to replace it if it is still good.
Cheers
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 01-01-2013, 02:51 PM   #4343
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 314
Cheers
12.5 volts, headlight on.
ridepjride is online now   Reply With Quote
Old 01-01-2013, 02:58 PM   #4344
The Jester
The Jester's Avatar
Oddometer: 834
Thanks. New battery ordered.
The Jester screwed with this post 01-01-2013 at 03:30 PM
Old 01-01-2013, 03:05 PM   #4345
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 314
Thought I'd start the year out right. A little cool this morning, mid 30's. Recent rain caused a rare submersion of the bridge to Reiff Road.
Headed over to Bartlett Springs Road for lunch in Clear Lake Oaks. Ran into some snow and ice between 3 and 4 thousand feet.
Old 01-04-2013, 08:14 PM   #4346
dantroop
dantroop's Avatar
Oddometer: 173
My new bash plate
Incorporating the BMW engine gards
Old 01-04-2013, 09:14 PM   #4347
khpossum
poster
Oddometer: 473
Do you have a part number?
khpossum is offline   Reply With Quote
Old 01-04-2013, 10:09 PM   #4348
Royal Tiger
Pz VI B, Sd Kfz 182
Oddometer: 1,380
Not on me. I'm sorry. I looked up the RM250 in their book that was on the shelf by the levers and took a shot based on the table in the first post in this thread. I know it was Trackside brand.
Old 01-06-2013, 01:15 PM   #4349
mcgarrett
mcgarrett's Avatar
Oddometer: 150
Ohlins adjustability
I'm close to pulling the trigger on an X-Challenge that was just fitted with an Ohlins rear shock. For most folks this might be good news, but I'm inseam-challenged (30") and have concerns about being able to lower that shock. I sat on Butters' bike with the stock air shock lowered a bit with no issues, and I've already bought the BMW low seat to help even more. The dealership is willing to swap out the Ohlins for another shock that I'd buy (maybe a Hyperpro), and they won't charge labor. Also, I'd have a practically new Ohlins to sell.
I don't really know much about suspensions and I'd be dependent on a shop for any tinkering. That being said, any guidance or suggestions would be greatly appreciated.
Michael
mcgarrett is offline   Reply With Quote
Old 01-06-2013, 02:45 PM   #4350
The Jester
The Jester's Avatar
Oddometer: 834
Michael
A suspension specialist will be able to deal with adjusting the shock but my advice would be to try the bike first for a few weeks and see how you cope with it. What may seem high initially will soon feel normal and the low seat does make a lot of difference.
Should you consider the airshock, I wouldn't recommend lowering the pressure to lower the ride height though as the shock will still go to full extension whenever you unweight the suspension, including on braking resulting in the bike pitching forward. It does work well but only with the pressure set correctly for the weight of the rider giving the correct amount of sag.
Times are GMT -7.   It's 07:52 PM.
