Old 01-27-2013, 06:28 AM   #4396
slide
A nation in despair
Oddometer: 21,122
Originally Posted by Geoffster View Post
My X-Country's fuel light failed to come on last week, and I ran out of gas. Never before, and not since.
Ambient temps were in the low 30s when it malfunctioned.
Anyone else have low-temp transient failure(s)?
May be something else than temp. Mine has been fine. I always use trip odo rather than relying on the light anyway.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 01-27-2013, 06:34 AM   #4397
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
Tee Bee's Fuel Filter Mod
Tee Bee was able to get a Mahle filter ($15 at Motobins) to work on his X. He did a writeup on his smugmug account which can be found here: http://teebee20.smugmug.com/Motorcyc...5520&k=ctN3cDf
I'm cutting and pasting it here (with Tee Bee's permission):
"First remove the fuel pump, being careful when you take the fuel pipe off, the pipe is pressurised to 50lb/sq in. with petrol
Take the pump assembly ,wiring plug ,filter(keep the little o ring ,from inside the filter, safe) etc. apart, that should leave you with just the plastic pump assembly, top.
Remove the top hose fitting.
File the original filter "nipple"I used an electric file, flat.
Drill the hole out,i used a 9mm drill bit.
Use a larger drill bit, or preferably a countersink to rebate the hole ,to allow for the original filter rubber o ring.
Grind off the top hose connector mounting, to allow room for the hose clip.
Put the o ring on the new filter and mount into the original filter position, refit the clamp making sure that the new filter fits tight against the housing, you will need a new hose clamp 10/11mm
Refit the pump and wiring,
Refit the pump assembly into the tank.
The new filter pipe connection is slightly larger than the injector hose, but it will fit ,use a new narrow clip ,a 13mm one is fine.
Start the engine and go celebrate ,you,ve just saved over 200 ($320)."
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 01-27-2013, 06:41 AM   #4398
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
Here's the only pic I could find of the stock fuel pump/filter setup, for reference:
Marc
07 XChallenge
Old 01-27-2013, 07:03 AM   #4399
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
at aprox ODO 38.000km my fuel level led stoped to signal fuel reserve.
In my case I removed fuel pump unit from tank and founded out that one of cables at connector was broken causing problems. Easy to fix and works since then without any further problems.
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 01-29-2013, 12:31 AM   #4400
Pine Sol
Pine Sol's Avatar
Oddometer: 498
Lowering foot pegs on an XChallenge?
hello,
has anyone ever seen brackets that lower the foot pegs for XChallenge? (to help lower me while im standing on the pegs)
something like 2 or 3" closer to the ground?
thanks
ed
Pine Sol screwed with this post 01-29-2013 at 07:58 AM
Pine Sol is offline   Reply With Quote
Old 01-29-2013, 07:47 AM   #4401
ebnelson
Frozen rider
ebnelson's Avatar
Oddometer: 233
Fastway's on low position will get about an inch lower. A Renazo Racing seat will increase the distance to the pegs another inch or so.
ebnelson is offline   Reply With Quote
Old 01-29-2013, 08:03 AM   #4402
Pine Sol
Pine Sol's Avatar
Oddometer: 498
cheers for that, i edited my question to be a bit more exact....
i couldnt wait the extended wait time for a renazo, so i went with an XPC, and had them make it as tall as possible, i think its just a bit above 40" seat height. but my problem is when i stand while riding off road.... my bike has ABS so im limited as to how high i can raise the bars, currently they have 2" rox risers, but i need more......
so, before i get a bracket made up to lower them, im wondering if there is anything out there already made....
Old 01-29-2013, 03:41 PM   #4403
shagginwagon
Oddometer: 9
hey all, nice to be here...! I wish I could convert the bike to look x-country/challenge, that is more my style aesthetically speaking.. but here is my x-moto.
shagginwagon screwed with this post 02-17-2013 at 09:47 AM
shagginwagon is offline   Reply With Quote
Old 01-30-2013, 08:42 AM   #4404
BigHairyYorkshireman
Oddometer: 8
Front Axle Dimensions
Hi. I'm new to the forum but, having joined many such fora in the past, I have dutifully searched to find the answer to my question before posting it. I figure this thread would be the best place to stash the answer, so can anyone please tell me the dimensions of the front floating axle (part number 36317696636), including the bore measurments for the XChallenge/XCountry? The corresponding ones for the XMoto, which I know are different, are 13.5mm and 19mm.
Cheers.
BigHairyYorkshireman is offline   Reply With Quote
Old 01-30-2013, 12:48 PM   #4405
lewiss66
lewiss66's Avatar
Oddometer: 369
Originally Posted by Butters View Post
...I pushed a piece of hose (fuel line size) onto the plug through the access hole...
Do you know the inner diameter of this hose?
http://g650forum.forumactif.org/
http://buyvintage1.files.wordpress.c...porteur_01.jpg
G650 Xcountry 2007 / Beta evo 4T 2011
lewiss66 is offline   Reply With Quote
Old 01-31-2013, 01:28 AM   #4406
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 921
Eh? remember to greas it up...
Originally Posted by mikeysduck View Post
Can anyone comment on Hiflo air filters for the X bikes? I pulled the air box covers, on my new to me X Challenge, a new looking stock paper filter. Great! Not really. I removed the filter and found the inside of the air box coated in fine dust. I greased the sealing surface hoping that will help. I need a better filter.
Is the Hiflo foam or paper?
I found this comparison Uni vs Twin Air. Are either of these still available? They do not readily pop up on a google search. It looks like they both retail for $50 to $100. The Hiflo is available for $10 to $20.
http://www.advrider.com/forums/showthread.php?t=508841
I have 2 of the Uni's and love them (nice to have a ready to go clean one).
http://www.touratech-usa.com/Store/2...able-for-G650X
(FYI: make sure you take off the air box and put some greas around the rubber grommit on the throtel body, I even pulled the grommet and put sum around the top that seals agains the airbox [found a lot of dust in there as well].)
jonnyc21 is offline   Reply With Quote
Old 01-31-2013, 01:54 AM   #4407
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,538
The Uni foam filter is the only foam one I know of. You may be able to find it other places than TT. I also use a sheet of Uni foam above it as a prefilter.
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~
FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar!
snooker is offline   Reply With Quote
Old 01-31-2013, 05:10 AM   #4408
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
I don't recall as it was just a remnant I had laying around. Probably 3/8" or 10mm.
Marc
07 XChallenge
Old 01-31-2013, 12:26 PM   #4409
oothef
Grownup
Oddometer: 32
Xchallenge front spindle dimensions: large O/D 24.92mm large I/D 20.85mm sml O/D 19.95mm sml I/D 14.00mm
Overall length 265mm length to shoulder (sml dia) 178mm
Dia taken with good vernernia, length with cheap tape
oothef is offline   Reply With Quote
Old 01-31-2013, 12:47 PM   #4410
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
That Tee Bee is a resourceful son of a gun!
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Times are GMT -7.   It's 03:26 PM.
