Old 05-23-2013, 06:33 PM   #4786
mcgarrett
mcgarrett's Avatar
Oddometer: 150
Originally Posted by mcgarrett View Post
I'm going to give the Fandango a try. I do like the waterproof aspect and the other features.
I ended up getting the Diablo because of its lower profile. Not mounted yet.
For those of you with the Fandango or Diablo, has anyone sealed the seems?
mcgarrett is offline   Reply With Quote
Old 05-23-2013, 07:37 PM   #4787
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
I did on my Fandango, but I'm not sure it was necessary... No leaks though, used in several heavy downpours...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 05-24-2013, 03:31 PM   #4788
mcgarrett
mcgarrett's Avatar
Oddometer: 150
I'm having some difficulty getting the bag set up on the bike. If you have any photos of how you've routed the straps, I'd really appreciate it.
Old 05-27-2013, 12:46 AM   #4789
Noillek
Nomada Portugues
Noillek's Avatar
Oddometer: 24
Hi all,
Need your advises, recently did a 2000km trip in 3 days, that include riding on the autobahn... got to excited and when for a long time at speeds higher than 140km/h... result oil leak from carter and loose screws and one missing.
What can I do, as simple fix. As I'm not very handy guy. To avoid this to happen again.
My solution so far is buying a new screws use loctite and put as well a bit on the others, there's anything else that I should do?
Sent from my GT-N7000 using Tapatalk 4 Beta
Noillek is offline   Reply With Quote
Old 05-27-2013, 03:42 PM   #4790
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 558
Originally Posted by Noillek View Post
Hi all,
Replace the shift lever with a more pliable one immediately. Touratech make one that works well.
jjmead1 is offline   Reply With Quote
Old 05-28-2013, 07:55 AM   #4791
john_aero
john_aero's Avatar
Oddometer: 1,168
just keep an eye on your bolts.
my old dakar used do same. singles vibrate and bolts get loose.
i had all my clutch cover ones come loose before
just replace bolt, loctite it and make sure rest are all snug fit.
they will and do loosen up just have keep eye on them.
think thats bad. some the older ktm 640's uses vibrate so much nearly have bring fulls et bolts when go trail riding (ok bit exagerated there)
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 05-28-2013, 08:18 AM   #4792
john_aero
john_aero's Avatar
Oddometer: 1,168
Enduro Exhaust
Has anyone retrofitted an mx or enduro exhaust to their bikes
cant afford a new xch specific one
was thinking the crf exhaust as they are common and not a tiny unit so should be quiet compared to some pipes
happy with current one, just i plan getting 2 exhaust and fitting one to the right hand side same as the TT rally bike and making it into a fuel tank
Old 05-28-2013, 10:36 PM   #4793
Noillek
Nomada Portugues
Noillek's Avatar
Oddometer: 24
Thank you John, I think that there's no other option than check the screws every now and then.
Sent from my GT-N7000 using Tapatalk 2
Old 05-29-2013, 07:33 AM   #4794
john_aero
john_aero's Avatar
Oddometer: 1,168
i do this all the time on the bike and now and again few always have to be tightened up
Old 05-31-2013, 12:51 PM   #4795
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 285
Hyde Racing Windshield-
I have a Hyde Racing Windshield for sale on the Flea Market thread.
Blue. Looks sweet on the bike. Pics on the Hyde Racing website.
JB
jonb is offline   Reply With Quote
Old 06-01-2013, 02:42 AM   #4796
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,976
I have seen a KTM 625 SXC can fitted to the standard header and also a 530 can modded with mounts moved to the opposite side fitted. Guy said he had to repack the 530 can fairly often.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-01-2013, 12:47 PM   #4797
Antti
Antti's Avatar
Oddometer: 183
Question
Would 8cell Antigravity battery be enough for Xch?
Anyone using?
It has higher cca value and ah. But for some reason their importer is recommending 12 cell. My old battery is already four years old, still working but might be time to change it.
R1100GS, 690 Enduro, R80G/S project bike.
Antti is offline   Reply With Quote
Old 06-01-2013, 01:05 PM   #4798
an13
Oddometer: 36
I have 12 cell Antigravity and at least it works great. No more hot start issues, 13.2 volt idle voltage is nice, plenty of voltage for ecu to start even when warm and hard start situation.
an13 is offline   Reply With Quote
Old 06-01-2013, 04:27 PM   #4799
pampaX
pampaX's Avatar
Oddometer: 420
Anyone using?
PM sent. I'm pleased with the battery and the service.
I have the 8cell and it works ok, the first cold days are upon and still starts first crank. however, I believe they recommend the 12 cell one now which clearly is going to be better.
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX is offline   Reply With Quote
Old 06-01-2013, 04:32 PM   #4800
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,576
Anyone using?
I actually went with an EarthX-18. The cca and Ah values are kind of like comparing apples and oranges. Especially in Finland, the Li battery is going to have reduced cca in the cold. Likely it will be fine once you warm it up (headlight on for a few seconds or a crank or two). But I would err on the side of extra cca. I had no loss in cranking performance even at freezing temps.
The Ah values are also "Pb-acid equivalent", not true Ah. Unless you plan on using the extra space in your battery compartment for something, I would go as big as possible. The difference between an 8, 12, or even 18 or 24 is only ounces with Lithium batteries. Regardless which Li battery you get, it will be several pounds lighter than the stock battery, even if it has the same dimensions.
Or the short answer - I would definitely get at least the 12 cell.
Here's a link to pics of my install: http://www.advrider.com/forums/showp...postcount=4379
Marc
07 XChallenge
Butters is offline   Reply With Quote
Times are GMT -7.   It's 01:42 PM.
