Old 09-29-2013, 01:48 PM   #5326
cobrakai
Oddometer: 83
Originally Posted by SteveDennehy View Post
When I fitted the UniFilter PreFilter, I found, as has been reported here a few times, that the supplied bracket does not fit. It's easy enough to modify, but I prefer stuff that actually fits.
So I sketched out a bracket, and got one cut out of aluminium.
Everything lines up.
Sandblast, paint, and I'll be happy.
I contacted UniFilter, and they has no idea that there was an issue with the bracket. They now have my sketch, and hopefully will use it to modify their design.
You can download the DXF from http://www.wilddog.za.net/forum/inde...209#msg2597209 (I can't figure out how to attach it to this post). You are welcome to use it to cut your own. I used 3mm aluminium, which is probably too thick.
Wow excellent work! I love when people make things from scratch.
cobrakai is offline   Reply With Quote
Old 09-29-2013, 04:34 PM   #5327
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 578
Originally Posted by motorrat View Post
I used longarmed steering damper clamps with a Ram ball.
If you have more pics that would be sweet!
Any issues? Regrets? Or is it perfect?
jjmead1 is offline   Reply With Quote
Old 09-30-2013, 07:03 AM   #5328
motorrat
Oddometer: 97
Support Light attachment
54mm clamp
doubles as a actioncam support too
Pro`s ; very versatile in usage, switches between bikes easily, and is removed in seconds, doubles as a cam support
Con; with the 10wtt Led monster it sags a bit during offroad during daytime, at night my speed is much lower and it won`t move (not at all with this small LED light)
As said they are made for steering damper support, on this side of the Pool I got them from SW Motech
motorrat screwed with this post 09-30-2013 at 12:50 PM
motorrat is offline   Reply With Quote
Old 09-30-2013, 07:14 AM   #5329
werner747
Oddometer: 30
Question
Nice, Where do you get such a bracket?
werner747 is offline   Reply With Quote
Old 09-30-2013, 07:50 PM   #5330
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,899
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 10-02-2013, 04:58 AM   #5331
tommyvdv
tommyvdv's Avatar
Oddometer: 420
are the OEM bars on an xchallenge 22mm?
They don't taper so they're 22mm on the ends as well as in the clamps?
tommyvdv is offline   Reply With Quote
Old 10-02-2013, 08:11 AM   #5332
Scalex
Scalex's Avatar
Oddometer: 44
Hi Motorrat. I can't recognize your bashplate but I quite like it, would you mind sharing it's origin (sorry if it's a very popular one and just me not realizing...)
Scalex is offline   Reply With Quote
Old 10-02-2013, 10:50 AM   #5333
motorrat
Oddometer: 97
Hiya Scalex,
It has been made by Touratech, the small tool compartment is great, protection of the engine and shifters is good due to its width, and still fully offroad capable.
(don`t know if it is still available though)
Only drawback is it covers a lot of the engine, so the fan jumps on regulairly, but the Scheffelmeyer oilcooler works well too, so it didn`t overheat at all last september in Southern France when trail riding in 30 degrees Celcius.
@Tommy,Tapered bars!
Old 10-02-2013, 12:06 PM   #5334
tommyvdv
tommyvdv's Avatar
Oddometer: 420
I'm not sure I'm interpreting this right but here goes. bar ends are under 25mm and middle section is under 30mm? is that right?
tommyvdv screwed with this post 10-02-2013 at 12:15 PM
Old 10-02-2013, 12:40 PM   #5335
MJS
MJS's Avatar
Oddometer: 1,927
28mm at the clamp, 22mm ends. Same as regular tapered bar.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 10-02-2013, 07:19 PM   #5336
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 578
I desperately need a wiring diagram. Any ideas?
Can't find one on REPROM...but I have been known to miss stuff.
Old 10-02-2013, 07:35 PM   #5337
chokozip
Oddometer: 209
What part are you working on?
I will meet you on the long road to the middle.
Colorado/Utah 2014 ride report here:
http://advrider.com/forums/showthread.php?t=1019732
chokozip is offline   Reply With Quote
Old 10-02-2013, 08:04 PM   #5338
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 578
My running taillights do not work nor my running headlamp. My guess is ignition areas as they have re soldered many times.
Old 10-02-2013, 09:12 PM   #5339
chokozip
Oddometer: 209
Solid plan.Always start with known problem areas.
If the issue is not found there start cleaning ground points.
I dug through the reprom and ill be danged if I can find a diagram.
Good luck!
Sean
Old 10-02-2013, 09:17 PM   #5340
Square1
Square1's Avatar
Oddometer: 146
wiring diagram
That is the only version of XC wiring diagram I found.
http://www.swartzwelder.net/public/G650XWD/
M
Square1 is offline   Reply With Quote
Times are GMT -7.   It's 12:55 AM.
