Old 11-11-2009, 07:20 PM   #811
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,373
Originally Posted by Bert Fox
This past summer, I sent an old sprocket to Sprocket Specialists. They now offer one for XCh in aluminum for around $50. They sent me a free one in exchange for the pattern one.
Bert
Thanks for that. I see that they now sell them on thier website
ex X phile
Avoid the Gavel, travel by gravel
dirtsurfer is offline   Reply With Quote
Old 11-12-2009, 05:26 AM   #812
Happycamper
Have bikes, will travel
Happycamper's Avatar
Oddometer: 529
Wicked
Originally Posted by dirtsurfer
I am looking for an instrument cluster for the X challenge as mine has been damaged. I think X Country and X Cross are the same also aprillia pegaso. Please PM me if you know where I may be able to find one. thanks
I could have sworn someone was selling one on the flea market. I'm too lazy to look, but you should
Happycamper
2007 G650 Xchallenge
2009 F800GS
Happycamper is offline   Reply With Quote
Old 11-20-2009, 01:08 PM   #813
Butters
Butters's Avatar
Oddometer: 2,069
Oil Consumption
I have a bit of a concern with oil use on my X . . .
I generally try to check the oil at least every other fill up. I bought the bike new. At some point prior to it's first service, I checked the oil level (after having checked it several times previous) and it was WAY down - like nearly a quart. I was concerned but figured since it was a new engine breaking in, some consumption was normal. Kept checking it every/every other fill up and never saw any further use.
Fast forward to today (1700 miles). I probably hadn't checked the oil for at least 250 miles, but it was WAY low again. I checked it cold, but it was barely visible in the resevoir and not measuring on the dipstick. Put in maybe half a quart (what I had left on hand) and that got it measuring, but not topped off.
I have never seen any smoke out of the tailpipe.
I have no leaks.
It has lived a very mild life (the vast majority being backroad riding). Very little interstate and the only off road is fire/gravel roads.
It has never overheated and never had a temp light on.
Sounds normal and performs normally.
Is this normal? I just think it's weird that it doesn't steadily burn oil, but will hold steady for awhile and then lose quite a bit over a few hundred miles.
Marc
07 XChallenge
99 VFR
Butters is offline   Reply With Quote
Old 11-20-2009, 01:22 PM   #814
MaxThePanda
Psycho Panda
MaxThePanda's Avatar
Oddometer: 12
It's a dry sump. Check it when the oil is hot (very hot). Bike should idle till the fan comes on for a minute. You've probably way overfilled it. Made that mistake too...
MaxThePanda is offline   Reply With Quote
Old 11-20-2009, 01:25 PM   #815
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,303
Send a message via Yahoo to bloochdog
yet another new shifter
just got new mx boots .. first real boots for off road work. i have been spoiled by the balance boots... I know we have a shifter link here but need better input. I would like to know what shifter is working for you guys.. size 12 foot here. what length peg and what is good placement?
thanks and happy riding..
"Never trust a man what's made of metal!
BWDR
Cat Herders
SMIBS
BaldEagleBastards
bloochdog is offline   Reply With Quote
Old 11-20-2009, 02:15 PM   #816
Butters
Butters's Avatar
Oddometer: 2,069
Thanks MTP. I knew it was a dry sump, but I guess I got a little freaked when I visually saw how low it was (I had run it a minute or two).
Definitely not overfilled as I checked it after my ride. But I will definitely only check while warm in the future. Both times I checked it when it was low it was a cold check at the start of a ride. I usually check at the end of a ride or a fill up so it is warm. So it probably is an overreaction on my part.
Marc
07 XChallenge
99 VFR
Old 11-20-2009, 02:44 PM   #817
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,303
Originally Posted by Happycamper
What model tank bag was that? The enduro or explorer? I will most likely be sourcing a tankbag from Wolfman and any feedback would be appreciated.
I have the wolfman tank panniers . Good placement and are water proof . From the inside.. Water in , none out.. I still like the extra payload they offer,, Install a couple eyelets in the lowest points to allow drainage.. Ziplock or dry bag your gear..
That is Banshee next to bike on Canaan Valley loop trial.
Any input on my shifter question yet?
BWDR
Cat Herders
SMIBS
BaldEagleBastards
Old 11-20-2009, 09:03 PM   #818
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 4,559
For longer reach you can use a Yamaha 250-450 WR shifter from early 2000 ish to at least 2007.
For shorter lever us a Yamaha YZ 250-450 of same vintage.
Buy either in steel and bend a little bit where necessary.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
Cruz is offline   Reply With Quote
Old 11-20-2009, 09:31 PM   #819
kiwiAdventure
kiwiAdventure's Avatar
Oddometer: 1,379
I like the TT shifter very user friendly with the adjustments you have.
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
09 g450x
08 g650X Challenge
kiwiAdventure is offline   Reply With Quote
Old 11-20-2009, 09:32 PM   #820
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,303
the balance boots are quite flexible. the new mx boots not at all. I guess the long one will get it way out in front
thanks
BWDR
Cat Herders
SMIBS
BaldEagleBastards
Old 11-20-2009, 09:36 PM   #821
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 4,559
Longer works better with the stiff boots.
Old 11-20-2009, 09:44 PM   #822
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,303
going that route
BWDR
Cat Herders
SMIBS
BaldEagleBastards
Old 11-21-2009, 11:20 AM   #823
pampaX
pampaX's Avatar
Oddometer: 354
Hi butters, I've noticed the G650X is really picky with the oil if the procedure on the manual is not followed carefully you'll get very different levels.
In my experience with 27000Km (16700miles) on the bike it doesn't connsume any oil (almost any). Since last service at 20000K have added 100cc at most ... same between 10-20 thousand
Good luck
PampaX
pampaX is offline   Reply With Quote
Old 11-21-2009, 07:01 PM   #824
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,303
looking into the TT
That might work too.. Knowing TT they are probably out of stock.. they make most of their parts out of unobtainium. the rarest metal on earth.
BWDR
Cat Herders
SMIBS
BaldEagleBastards
Old 11-23-2009, 05:38 AM   #825
Happycamper
Oddometer: 529
Question Question
All,
I dropped my Xchallange yesterday on the right side. When I picked her up I did not see any damage other than the mirror poping off at the breakway mount. When I got back in the saddle I notice the handlebar was crooked.
The bar was not bent but the right handle bar mount was no longer lined up properly (it was closer to me than the left mount) The Mount was no longer level (i.e. the gap to the trippleclamp was higher on one side than the other. Has this happened to anyone?
I cannot tell if all I need to do is unbolt everything and remount the bar or if the bolt is bent? Or the mount needs replacing. If I can learn from someone elses experience I would appreciate it.
Happycamper
2009 F800GS
Times are GMT -7.   It's 07:14 AM.
