Old 12-04-2009, 04:43 AM   #841
Muddler
Muddler's Avatar
Oddometer: 797
Originally Posted by Max Kool
The paint on ALL the panels of my Xchallenge has scratched and flaked off here and there. I doubt if BMW will cover it. They will most likely blame it to the way I use my bike...
What's the best way to touch up the plastics?
Is there a special type of paint I should use?
Muddler is offline   Reply With Quote
Old 12-04-2009, 01:24 PM   #842
Bert Fox
Casual Adventurer
Bert Fox's Avatar
Oddometer: 455
Originally Posted by Ham-Bone
When I purchased my X-CH the PO had upgraded the sub-frame with the Touratech frame, mounts, and boxes. However, I never received all of the leftover parts and he had already given them away.
So, does anyone want to sell their brackets?
They have the part #s on Max's BMW.
Wells, NV
"Riding with one leg is waaay better than not riding!"
GNATSASS Great Basin Dualsport/Adventure Bike Tours
www.gnatsass.net
Find us on Facebook. GNATSASS
Bert Fox is offline   Reply With Quote
Old 12-04-2009, 03:53 PM   #843
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,096
Yeah, the two clamps and the bracket are about $37. Diagram 16 on this page.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 12-08-2009, 11:31 AM   #844
backyardorganics
Dubletruble
Oddometer: 59
xmoto wheels
Do other model wheels (rims) fit xmoto ?
it's rumored the Aprilia Pegaso Strada share the same front and can be swapped with no special fittings needed.
What about the rear wheel are they interchangeable ?
any other bikes using the xmoto wheels ?
just wondering!! - cheers
backyardorganics is offline   Reply With Quote
Old 12-10-2009, 04:50 AM   #845
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,109
Very handy thread GB........ nice job.
Timpo.
The Rave Generator......
Timpo is offline   Reply With Quote
Old 12-11-2009, 05:36 PM   #846
motobone
Free for all!
Oddometer: 222
Thanks for the link. One more ?, It looks like there are two different sized brackets. If a person were to order two brackets, is there one that holds an MSR bottle better than the other?
Thanks again.
Every time you eat meat, a hippie drops his hacky sack.
2007 BMW G650X Ch
2012 Husqvarna TE310
motobone is online now   Reply With Quote
Old 12-11-2009, 05:39 PM   #847
Bert Fox
Casual Adventurer
Bert Fox's Avatar
Oddometer: 455
Brackets
Yeah, actually the bigger one works better. t's been so long since I did it, that I can't remember which one that is. If anyone still has their cannister around they might be able to chime in here and tell you if it is the upper or lower one.
Wells, NV
www.gnatsass.net
Old 12-11-2009, 06:20 PM   #848
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,925
Thanks again.
put the bigger on on the top. I found that if you cut a little of the rubber gasket out it fits better. Also if you reverse the bolts and use wing nuts and lock washers you will find it eaiser to use the bottle when needed. good luck .. I will take picks tomorrow.
" You need a new sig line."- H14
"I despise you and want my refrigerator magnet back!" - VB Divers ex-girlfriend
bloochdog is offline   Reply With Quote
Old 12-11-2009, 11:11 PM   #849
Muddler
Muddler's Avatar
Oddometer: 797
Rear brakes
I'm going to pull off the rear pads to investigate a loud squeal that has developed. The setup on the x is different to what I'm used to, does the pad retaining pin punch out? Do I have to remove the wheel?
Any advice would be appreciated
Old 12-11-2009, 11:37 PM   #850
ONYERBIKE
LE Rosbeeeeef!
ONYERBIKE's Avatar
Oddometer: 356
The retaining pin punches out from inside the wheel in the direction of outside the wheel, if that makes sense! Right to left as you look at it from the back of the bike, it needs a gentle tap to get it moving, and yes you will need to remove the rear wheel.
I had the same problem with my rear brake squeeling pretty loud, it seemed to be whenever the bike had been anywhere near wet mud.
When I fitted new rear pads I put a dab of copper grease on the back which in all honesty didn't make a great deal of difference.
ONYERBIKE is offline   Reply With Quote
Old 12-12-2009, 12:08 AM   #851
Muddler
Muddler's Avatar
Oddometer: 797
Thanks Onyer
the caliper hole sizes had me thinking left to right. I'll try the reverse!
Love this forum!
Old 12-12-2009, 05:23 AM   #852
mcgiggle
Oddometer: 272
I did mine last week and the pin pushed out into the centre of the wheel and I didn't take the wheel out!
Perhaps the UK bikes are different to the USA's
Pete
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 12-12-2009, 07:09 AM   #853
Muddler
Muddler's Avatar
Oddometer: 797
Pete
thanks Pete
I'll just have to try both sides
Either way, I need a hammer!
Rob
Old 12-12-2009, 08:14 AM   #854
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
Pete
Im also not removing wheel to exchange brake pads. Pin should be removed by using some pinch and hummer in smaller hole (as far as I remember - from outside into wheel hub)
Regards
Luc
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 12-12-2009, 02:44 PM   #855
ONYERBIKE
LE Rosbeeeeef!
ONYERBIKE's Avatar
Oddometer: 356
Thanks Onyer
Love this forum!
Shit, sorry man, I was giving you wrong advise from memory, I have checked my bike today and you take the circlip off and then give it a tap from the left side (must have confused retaining circlip position and direction of pin)
I took the rear wheel out as I couldn't work out how to get the new pads into the caliper without damaging anything else.
Times are GMT -7.   It's 03:37 AM.
