Old 01-18-2010, 01:26 PM   #961
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,926
sorry about getting off subject Steady..
How friendly is your area to tourists Roof?
just to keep from hijacking the XC thread Steady , I will now ask a thread related question.
Which valve stem cap is better to run on the XC's tires? Plastic or metal?
" You need a new sig line."- H14
"I despise you and want my refrigerator magnet back!" - VB Divers ex-girlfriend
bloochdog screwed with this post 01-18-2010 at 01:58 PM
bloochdog is offline   Reply With Quote
Old 01-25-2010, 05:06 PM   #962
Redbull Addict
I need another one...
Redbull Addict's Avatar
Oddometer: 1,263
Originally Posted by evoluzione
i'm just playing with my bike at the moment. unfortunately the stock cartridge is non-serviceable so what i would have to do is modify your cartridges (requires machining of the cartridges) and install my valves. once that is done, you will be able to do all the adjustments (shim stacks) yourself since it will be fully servicable.
the real question is whether there is enough interest to make a run of the valves worthwhile.
Interest?? YES!!!
Redbull Addict is offline   Reply With Quote
Old 02-01-2010, 06:58 AM   #963
Big Den
always looking
Big Den's Avatar
Oddometer: 53
Hi Guys few questions
Got my X Challenge a week ago, its got 2K miles on it and some toys mostly TT (Touratech) stuff.
I have read 40+ pages of posts and picked up on all the essential mods
I have an issue with the rear brake lever, its too high and too close to the crankcase, its got the TT extender on the end but i want to lower it, checked the BM Reprom and manual but no mention of how to adjust it, tried winding the threaded rod up and down but this only adjusts the gap between the rod and hydraulic piston. Any ideas how to lower it ?
Went for 1st ride yeaterday and welded my new Arlen Ness's to the Scorpion can so i have put the original back on for now.
The Scorpion is very loud so i am looking at the Leo Vinci, does it come with the black heatshield as seen in a few photo's on this great site ? or is that an extra.
cheers
Big Den is offline   Reply With Quote
Old 02-01-2010, 07:11 AM   #964
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
Use stopper part #6 - you must loosen #8 and then move around part# 6 to get lever down
http://www.maxbmwmotorcycles.com/fic...png?v=12272009
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 02-01-2010, 07:12 AM   #965
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,519
Adjust the round piece at the rear of the pedal. The one with the allen screw that is offset from the center. Then adjust the threaded rod.
tbarstow is offline   Reply With Quote
Old 02-01-2010, 07:23 AM   #966
Big Den
always looking
Big Den's Avatar
Oddometer: 53
I take it that it works on a cam system ? not come across that before
Saw something on the Reprom about using a feeler gauge on #6.
Awesome guys thanks, I will give it a go when i get home.
Old 02-01-2010, 07:39 AM   #967
toofast4uu
adventurer
toofast4uu's Avatar
Oddometer: 971
Go
cheers
I too recently installed a Scorpion exhaust on my bike. It was obsecenly loud!!! (I was surprised to find that it basically was a "straight" pipe, with no baffling...
Luckily i'm a "hoarder" and I had some old parts laying around the shop...
I then installed a stock spark arrestor that came out of my old 2002 Yamaha 660 Raptor quad...
It slipped right in, and lowered the sound to a real nice rumble, only slightly louder then stock...
Part#18 "PIPE, OUTLET" 5LP-14752-00-00
http://www.mrcycles.com/fiche_sectio...2002&fveh=1072
If your cheap, and not in a rush, I bet you can find these used online somewhere...Most quys remove this the minute they buy the machines...
(You will need to make a little flat tab to hold the silencer in place...)
toofast4uu is offline   Reply With Quote
Old 02-01-2010, 07:44 AM   #968
Big Den
always looking
Big Den's Avatar
Oddometer: 53
Mine has the baffle in, dearn't take it out I will probably sell it to someone who rides in less delicate areas
Old 02-01-2010, 07:48 AM   #969
Bert Fox
Casual Adventurer
Bert Fox's Avatar
Oddometer: 455
Leo Vince
Yes, the Leo comes wth the carbon heat shields and it has several core options. I used the quietest one w/ the spark arrestor and have been happy for 2 1/2 years. You may need a bit more than the carbon shield depending on how your bags fit.
Wells, NV
"Riding with one leg is waaay better than not riding!"
GNATSASS Great Basin Dualsport/Adventure Bike Tours
www.gnatsass.net
Find us on Facebook. GNATSASS
Bert Fox is offline   Reply With Quote
Old 02-01-2010, 08:15 AM   #970
Big Den
always looking
Big Den's Avatar
Oddometer: 53
Asked my local dealer for a price
Old 02-01-2010, 12:44 PM   #971
Roof of Africa
Roof of Africa's Avatar
Oddometer: 24
If anybody is looking for a place to dump noisy exhausts, I will gladly supply my postal address!!
Roof of Africa is offline   Reply With Quote
Old 02-01-2010, 12:58 PM   #972
ONYERBIKE
LE Rosbeeeeef!
ONYERBIKE's Avatar
Oddometer: 356
cheers
Good move getting a Leo Vince for the XC, great sounding without being offensive, unless you put the race baffle in that is, jaysus!!
I ordered mine from www.racespec.co.uk after struggling to get anyone to supply me with one and yes it is supplied with the carbon heatshield
ONYERBIKE is offline   Reply With Quote
Old 02-01-2010, 01:52 PM   #973
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,661
Plastic caps tend to leak air more readily than metal caps.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 02-01-2010, 02:38 PM   #974
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
I use the NATO caps...on my buggy I run them without valve cores...no leaks...
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 02-01-2010, 03:37 PM   #975
olyflyer
olyflyer's Avatar
Oddometer: 1,201
might be a bit late, but works out a bit cheaper from here
Oly
'Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living.' Miriam Beard
olyflyer is offline   Reply With Quote
Times are GMT -7.   It's 09:39 AM.
