Old 06-27-2008, 04:37 AM   #91
RV8Pilot
Blue,Green,Blue,Gree.....
RV8Pilot's Avatar
Oddometer: 213
Originally Posted by johnnydanger
Looking at the other recommendations and have a question. Isn't the "99-06 MSR YZ250 shift lever (PN 34-2148)" a stronger aluminum replacement, NOT a bendable stell one? Let me know, thanks.
I bought the MSR shifter and it's a pretty hefty chunk of aluminum. I drilled if full of holes to weaken it some. Guess I won't know how well it works until I throw it down.
1200 GSA-DR650-1961 BSA Gold Star-Moto Guzzi 1100i Sport-Victory Vision Tour-CL77
Vans RV8
RV8Pilot is offline   Reply With Quote
Old 06-27-2008, 05:29 AM   #92
toofast4uu
adventurer
toofast4uu's Avatar
Oddometer: 971
I have the 34-2148 mounted on my X. At first look, it appears thicker and much stronger then the steel version, and I was reluctant to install it..but after my stocker finally broke off, I did go ahead and install it...
Soon after, I slid out in a grassy field and bent the aluminum shifter quite badly...but I took out a wrench, and bent it right back...I think it bends where it needs to...
So I don't know what the exact answer is, however it's not as strong as it looks, and they are quite pliable....
For extra safety, i installed a "Brake Snake"...When I fell and bent the MSR, the fall caused the brake snake to break off!! (This pic is with the stock shifter, I can take another of the MSR aluminum one if required.)
http://picasaweb.google.com/MrChrist...33007367733538
toofast4uu is offline   Reply With Quote
Old 06-27-2008, 02:54 PM   #93
johnnydanger
Dangerous!
Oddometer: 62
toofast: So the MSR shifter end is in virtually the same place as the stocker? The moose one sticks out much further than stock and looks like if I installed it it'd be annoying. Thanks.
www.johnnydanger.net
2007 BMW XChallenge
2007 Ducati GT1000
2006 BMW K1200R
2006 Aprilia SR50
johnnydanger is offline   Reply With Quote
Old 06-30-2008, 08:55 AM   #94
kres
Arrrrrrrrr!
kres's Avatar
Oddometer: 1,197
FYI - the Touratech F650GS shifter works just fine, and is really bendy.
-Kres
"...he wondered if a God subtle enough to invent quantum mechanics would really be intrested in having people deliver rote prayers and swing incense pots in His direction." - Jack McDevitt
kres is offline   Reply With Quote
Old 06-30-2008, 04:50 PM   #95
Trailace
Dumb Ass
Trailace's Avatar
Oddometer: 1,158
Do you have a part number?
Trailace
MotoCampers.com
Shouldn't You Be Riding/Camping?
2007 G650X Challenge
2002 R1150GS ADV
Iron Butt # 7362
Trailace is offline   Reply With Quote
Old 07-01-2008, 09:04 PM   #96
kres
Arrrrrrrrr!
kres's Avatar
Oddometer: 1,197
041-0702
Folding Shift Lever F650GS (orig length) <-Click Me.
-Kres
Old 07-01-2008, 09:27 PM   #97
Bert Fox
Casual Adventurer
Bert Fox's Avatar
Oddometer: 455
So I purchased a steel shifter replacement and decided to go with the Moose shifter as recommended by Bert Fox (The Thumpertalk Part# 1602-0015 for WR250/450). Upon receiving it I decided not install it for a couple reasons:
1) The shifter sticks out about 1" further than stock, hence increasing the likely hood of it hitting the ground and potentially breaking the shaft.
2) The shifter is uber thick steel and in my opinion wouldn't easily bend in the event of a touchdown.
So back to the drawing board for me. I'll be trying one of the others soon.
Here's a pic of my experience:
You're right. After using it, I have thought about drilling it to make sure it bends instead of breaking the shaft, but then what's the point, you have to do that to the stocker. I may end up drilling the stock one for use and packing the Moose as a spare if the stock drilled one doesn't survive a bending bak or simly breaks. My apologies!
Bert
Wells, NV
"Riding with one leg is waaay better than not riding!"
GNATSASS Great Basin Dualsport/Adventure Bike Tours
www.gnatsass.net
Find us on Facebook. GNATSASS
Bert Fox is offline   Reply With Quote
Old 07-01-2008, 10:57 PM   #98
oggi
oggi's Avatar
Oddometer: 69
for changing the front sprocket, how do you guys keep from simply spinning the wheel with the torque needed to losten the bolt? It is not reverse thread right? im somewhat worried to fully force it loose not knowing the thread pattern
oggi is offline   Reply With Quote
Old 07-02-2008, 03:32 AM   #99
Bike#8
Location: Socal=Mt. Laguna & Palomar Mtn.> Now in Idaho Yea!
Oddometer: 176
First time I took sprocket off it was kinda tough, it was on there tight. I jack the bike up to comfortable working level, remove 3 bolts on front sprocket cover (8mm). Lower bike back down so wheels are weighted (by me leaning over bike from left side to put my weight on it), loosen front sprocket bolt (14mm? from memory) and rear axle bolt (26mm), to provide chain slack. Lift bike back up to work on it. BTW, I've been swapping between 14, 15, and 16 tooth front sprockets. I have the speed vs rpm charts made up if anyone wants me to post them. Or you can go here...
http://www.cosportbikeclub.org/misc/SpeedCalc.html
to calculate them your self. The BMW manual has all the data you'll need to input.
Bike#8 is offline   Reply With Quote
Old 07-02-2008, 06:44 AM   #100
Winter Hill Gang
sex.wax.poetic
Winter Hill Gang's Avatar
Oddometer: 50
May as well post them up. it'd be another nice thing to have in the index I'd say.
Winter Hill Gang is offline   Reply With Quote
Old 07-02-2008, 10:24 AM   #101
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,848
You post and I'll add it to the Index.
Old 07-02-2008, 01:41 PM   #102
oggi
oggi's Avatar
Oddometer: 69
do x-moto and x-chal share the same exhaust? can a leo slip on that is spec'd for the x-moto fit on the x-chal?
Old 07-02-2008, 03:07 PM   #103
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,848
all three G650X bikes share the same exhaust.
Old 07-03-2008, 10:29 AM   #104
Bike#8
Oddometer: 176
RPM vs Speed for 14,15,16 tooth front sprocket on XChallenge using stock rear tire (Metzler Enduro 3, 140/80x18). Please NOTE: I'm using a calibrated Vapor speedometer on my bike. The inaccurate stock speedo unit will not give you true rpm's unless you know how much error it has.
Old 07-03-2008, 04:14 PM   #105
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,848
Thank you.. this chart has been added under "Sprockets".
Times are GMT -7.   It's 07:05 AM.
