Old 06-13-2010, 12:52 PM   #1351
SCflyer
SCflyer's Avatar
Oddometer: 1,657
What temp to program to a Vector dash?
I'm replacing the stock speedo with a trail tech Vector and it will read engine /coolant temp and give a yellow warning for high temp and a second red for a "danger" temp but those temps need to be programmed into the computer. Anybody know what max temp makes the stock temp light come on and that I should program to give the computer a reference # for the lights?
SCflyer screwed with this post 06-14-2010 at 07:51 PM
SCflyer is offline   Reply With Quote
Old 06-14-2010, 05:33 PM   #1352
SCflyer
SCflyer's Avatar
Oddometer: 1,657
Bump for question
Old 06-14-2010, 05:38 PM   #1353
Bora20
Oddometer: 855
Originally Posted by SCflyer
I'm replacing the stock speedo with a trail tech Vector and it will read engine /coolant temp and give a yellow warning for high temp and a second red for a "danger" temp but those temps need to be programmed into the computer. Anybody know what max temp I should program to give the computer a reference # for the lights?
100 degrees?
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 06-15-2010, 02:55 AM   #1354
Muddler
Muddler's Avatar
Oddometer: 797
Replacement keys?
Yep, I lost my key. Wifey searched high and low for a local locksmith to do a copy. Eventually she got someone who could do it. Finally got one, but although it looks like an identical cut, it wont go in.
Anyone else had success with this?
How much for a BMW replacement?
Muddler is online now   Reply With Quote
Old 06-15-2010, 05:22 AM   #1355
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 2,020
Maybe if you just clean your copy up a bit with a wire brush or some wet n dry to get it a little more rounded it might work
http://cgi.ebay.com/ebaymotors/2007-...Q5fAccessories
dirtsurfer is online now   Reply With Quote
Old 06-15-2010, 06:50 AM   #1356
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,280
Had a replacement cut at a supermarket with no problems. Alittle bit rough to put in the first time so give it a bit of a rub like DS suggested to take sharp edges off.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is online now   Reply With Quote
Old 06-15-2010, 07:36 AM   #1357
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,721
keys
On my 1150GS I had keys cut by a hardware store no problems. The keys are same type (cuts on both outer edges). My HP2 only came with one key (totally different key flat on the outer edges cuts in the center) and I just ordered a key from my BMW dealer $50. They just needed the Vin# and it came and it works. So unless the Xchallenge keys have some electrical component the key you had made should work just double check it and clean it up a bit. If that dosnt work take it back to the guy who cut it and make a new one. OR the dealer can order a factory key for you with a VIN#.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 06-15-2010, 12:52 PM   #1358
MizzouRider
MizzouRider's Avatar
Oddometer: 1,800
I'm replacing my rear tire on Saturday.. Anything unusual about the XC I need to be aware of? I have ABS..
Otherwise it's just off with the oold and on with the new right?
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 06-15-2010, 01:26 PM   #1359
SCflyer
SCflyer's Avatar
Oddometer: 1,657
Originally Posted by Bora20
100 degrees?
Found it...you were close - 100deg C for the fan
105deg C for the light
Old 06-15-2010, 02:06 PM   #1360
Hotmamaandme
Oddometer: 2,721
yes
Old 06-15-2010, 02:22 PM   #1361
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,457
Originally Posted by AZ-Twin
So I did a little looking around on the BMW parts list. I took some screen shots and posted the pic below. Both the Xchallenge and the Dakar have the same pic, but a few minor differences in the parts list. The primary being the part numbers on items #1 and #10.
Look at the price of #1.
Guess I will take it easy on my charging system. Wonder if Rotax sells a kick start kit.
What is the charging system on the Xmoto and Xcountry like? Same as the Xchallenge?
I could be wrong, but (1) looks like the entire assembly of parts 2 through 10. Looks like a few of the big pieces are not available separtley.
What about having the stock one rewound for more power? This guy use to rewind all the stuff for Baja teams http://www.rickystator.com/catalog/i...hp?cPath=24_36
Did you see the 3 lbs difference between the Dakar & XCH? I guess we know where a big portion of quicker revving came from.......3 lbs.!!!!
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 06-15-2010, 03:56 PM   #1362
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,991
I had one cut for my XC in a Russian market, Works perfectly. Cost me almost nothing
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 06-15-2010, 07:15 PM   #1363
dirty boar
OZ BOAR
dirty boar's Avatar
Oddometer: 293
risers
i am 6 foot 2 and find i need better control when standing and in the sand.
looking at the 20mm risers from touratech.
or are there better ones out there .
dale
dirty boar is offline   Reply With Quote
Old 06-15-2010, 07:19 PM   #1364
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
dale
If you don't have ABS, I'd get the ROX so you can move the bars fwd or back as well (I'm the same height)...I have ABS, so was limited to the 20mm and would have preferred going for more...
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 06-15-2010, 07:28 PM   #1365
dirty boar
OZ BOAR
dirty boar's Avatar
Oddometer: 293
no abs on my bike, well have a look at some rox.
thanks
dale
Times are GMT -7.   It's 06:59 AM.
