Old 07-03-2010, 12:37 AM   #1411
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,929
12v under seat cig outlet,
I want to set up some power accessory outlet. My local dealer tells me that BMW dont make a part which connects the acc power socket to the wiring loom.
I believe there should be something available to connect to this terminal
Is such a BMW part available? If so can somebody tell me the number? If not does anyone know where I a can get the terminal that connects with this one so I can wire something up
dirtsurfer is offline   Reply With Quote
Old 07-03-2010, 01:06 AM   #1412
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,031
Can't help with the outlet as I couldn't find any over here in stores either. Ended up just connecting to the battery with a fuse inline and a waterproof male/female fitting so that it can be easily disconnected at any time.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 07-03-2010, 02:59 AM   #1413
Muddler
Muddler's Avatar
Oddometer: 773
I did a similar thing. Straight off the battery with a fuse inline. Only difference is I just ran a basic 2 pin connector. Because it stays under the seat it doesnt need to be waterproof. I hook this up to a trickle charger every now and then. I also bought a cheapo 12V outlet from an auto store, for my gps. I set this up so it also plugs into the 2-pin connector, but can be completely removed when not in use. I created a plug for the connector when not in use by sacrificing a female end & blocking one end with silastic
Muddler is offline   Reply With Quote
Old 07-03-2010, 04:09 AM   #1414
The Jester
The Jester's Avatar
Oddometer: 838
The ABS bikes come with an accessory socket as standard. For those without, they will supply a socket for about 50 and a plug for 8.
Alternatively I went to an auto accessory shop and bought an accessory socket and plug for 5 which fits straight in the mounting hole by the shock. I soldered wires to the back of it, sealed it up with hot melt glue, chopped the plug off the connector under the seat and joined there. The socket has a rubber plug to seal the front when not in use.
The connector under the seat is permanently live so you can use it to trickle charge the battery or charge a phone in camp without leaving the ignition on.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 07-03-2010, 06:02 AM   #1415
Trailace
Dumb Ass
Trailace's Avatar
Oddometer: 1,151
Part number 24 should be what your looking for.
Trailace
MotoCampers.com
Shouldn't You Be Riding/Camping?
2007 G650X Challenge
2002 R1150GS ADV
Iron Butt # 7362
Trailace is offline   Reply With Quote
Old 07-03-2010, 11:27 PM   #1416
Rev Kiecker
Rev Kiecker's Avatar
Oddometer: 729
Or go click here and get whatever you want: http://www.powerlet.com/shop-by-product and put them in other locations too.
Rev Kiecker is offline   Reply With Quote
Old 07-04-2010, 05:43 AM   #1417
dirtsurfer
dirtsurfer's Avatar
Oddometer: 1,929
You mean my teminal pictured plugs straight into the back of the power outlet?
Old 07-04-2010, 11:46 AM   #1418
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Get a few of these:
http://www.sailgb.com/p/12v_16a_p_mo...n_socket__cap/
or a panel of these:
http://www.sailgb.com/p/12v_din_sockets__panel_of_3/
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 07-04-2010, 12:01 PM   #1419
The Jester
The Jester's Avatar
Oddometer: 838
Just the job. The 1st one will fit straight into the mounting hole by the shock.
Old 07-04-2010, 04:03 PM   #1420
dirtsurfer
dirtsurfer's Avatar
Oddometer: 1,929
It looks like I'm going to have to replace my battery. I have heard people refer to the odyssey battery but I don't know why. Are they better? in what way?
My bike would not start after a few hours continuous riding yesterday. I couldnt even get the startermotor to crank the engine. I trailered it home and charged the battery overnight an it started no problem this morning
Old 07-04-2010, 10:56 PM   #1421
The Jester
The Jester's Avatar
Oddometer: 838
If it wouldn't start after a long ride but started after being charged I would suspect the charging system. Does the battry hold charge once charged up? What voltage does the dash show when the bike is running?
Old 07-04-2010, 11:09 PM   #1422
olyflyer
olyflyer's Avatar
Oddometer: 1,201
you shouldn't have upgraded the latte machine, the new one is sucking too much juice from the battery, throw the old one back on (do you really need the The Dalla Corte Evolution 3-Groups Latte Machine??)
What else are you running electrically on the bike?
Oly
'Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living.' Miriam Beard
olyflyer is offline   Reply With Quote
Old 07-04-2010, 11:35 PM   #1423
dirtsurfer
dirtsurfer's Avatar
Oddometer: 1,929
No coffee machine , nuthin. I haven't connected the power outlet yet
Well usually around 11.3 when I check it but yesterday, it dropped away to 7.7 and even lower when trying to start it.
When I tried to start it in would make the most pathetic sigh on the starter and then the dash would reset like the power had been completely cut off, sometimes I got a flickering temp light. Very strange!
There was no indication that it was not charging prior to turning the motor off (else I wouldn't have done it)
Would the plug in fault finder , thingy tell me whats wrong?
Old 07-04-2010, 11:51 PM   #1424
olyflyer
olyflyer's Avatar
Oddometer: 1,201
I'd say the batttery is buggered as mine died when I left my GPS on too long when I stopped the bike and never recovered, BMW replaced the battery free
Is yours the original battery? if so BMW should cover it
Oly
Old 07-04-2010, 11:58 PM   #1425
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
I am no electrical expert but from experience I would say ...
For starters it should "usually" be about 14 .... my volt reading is about 14.4 ish when riding without much load on the system. If I load it up by turning on lights and crap it goes down to 13.5 ish.
If its below about 12.5 during normal riding you are probably using more power than you are generating.
If it reads 11 or something with no load, then 7.7 as soon as the starter is tried, then I think your battery is rogered. If you are on the factory battery, then there is a good chance its fu@ked ... BMW have had a lot of problems with their OEM batteries in recent years (not sure who the supplier is but it must be someone crap). See Oly's post above. I would put in a new battery and check the system ... it needs to be a lot higher than the 11 you are used to seeing. If its not, even with a new battery, then either your voltage regulator or generator are also fu@ked.
If the clocks reset when trying to start it, then you battery is 100% flat.
Does the battery hold charge when you charge it? i.e. you charge it, and then the bike starts, but what happens if you turn the bike off, then leave it for 30 minutes, then try to start it again?
Plug in fault finder? the GS911? It doesnt tell you much at all on an X-Challenge. The bikes computer is not able to diagnose if your battery is fu@ked or not.
Colebatch screwed with this post 07-05-2010 at 12:16 AM
Times are GMT -7.   It's 11:52 PM.
