Old 07-05-2010, 02:27 AM   #1426
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,954
Originally Posted by Colebatch
I...
For starters it should "usually" be about 14 .... my volt reading is about 14.4 ish when riding without much load on the system. If I load it up by turning on lights and crap it goes down to 13.5 ish......
I charged the BNW battery overnight last night and the bike started instantly when I hit the button, with headlight brighter than usual.
I checked it again tonight 14.1 when i first turned it on , started it and it was 13.2 with motor running
I have a multimeter , will that tell me if the bike is not charging the battery at the correct rate.
According to my reprom
Maximum output rating of alternator - Voltage 14 V -- 280 W
Maximum output current of alternator - at engine rpm 6000 min-1 = 20 A
I have to get on top of this before my outback trip
dirtsurfer screwed with this post 07-05-2010 at 02:50 AM
dirtsurfer is online now   Reply With Quote
Old 07-05-2010, 02:37 AM   #1427
Lankbrown
No Pain No Gain
Lankbrown's Avatar
Oddometer: 63
Originally Posted by dirtsurfer
It looks like I'm going to have to replace my battery. I have heard people refer to the odyssey battery but I don't know why. Are they better? in what way?
My bike would not start after a few hours continuous riding yesterday. I couldnt even get the startermotor to crank the engine. I trailered it home and charged the battery overnight an it started no problem this morning
G'day from OZ. I changed my battery to a YUASA YTZ10S 7 months ago and it has been great. Done nearly 10,000 k's and starts really easy every time. Price is about $80AUS. I also chose to recently put a headlight switch into the low beam circuit to take some of the strain off the electrical system especially when the cooling fan is operating. Cheers
Lankbrown is offline   Reply With Quote
Old 07-06-2010, 01:07 PM   #1428
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 284
My X won't idle! Need some advice.
The bike had been sitting for a couple months. It started right up. I drove it to work. I went out at lunch and came up to the first traffic light and it stalled. First time ever. I pulled into the next gas station and put some new fuel in without adding anything else and it didn't help. Still won't idle for more than a second and it smells a little stinky and there might be a little more of a sputtering exhaust note on decelleration, not a true backfire. Runs fine at 70mph.
Should I add some "Heat" additive? Is there a fuse that runs this part of the operation? I don't remember there being one. Got any ideas for me? Is there a air line that i need to reconnect that works with the idle circuitry?
Thanks.
JB
jonb is offline   Reply With Quote
Old 07-08-2010, 07:14 AM   #1429
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 284
I treated the gas
and I added clean fuel. I added SeaFoam and some Heat. Every time the bike returns to idle it stalls. I am going to run this tank of gas through and if its still runs like this I will move to my next theory. Sure hope its this simple or it could be a big pain in my backside.
JB
Old 07-08-2010, 08:49 AM   #1430
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 284
Rebooting the ECU
Seems like it might be a good idea to do a reset. Whats the best way to accomplish this? Can i disco the battery and reconnect it and will that reset the codes for me? Is there a formal reset process that can be accomplished at home in the garage without being subjected to the dealership? Thought i would give it a try.
Thanks.
JB
Old 07-08-2010, 09:08 AM   #1431
bigdon
Oddometer: 2,627
Got rid of Air Shock
Guys I had Rick @ http://motocd.com/ get me an Ohlins shock for the X. He set it up for my weight and height and did it with a discount price. It is awesome. I highly recommend this mod !
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 07-08-2010, 06:39 PM   #1432
Trailace
Dumb Ass
Trailace's Avatar
Oddometer: 1,160
Thanks.
Does your bike still have the charcoal canister or was it removed? If it's was removed maybe your plug came off located near the throttle body. This will cause the bike not to idle and is a real quick fix.
Trailace
MotoCampers.com
Shouldn't You Be Riding/Camping?
2007 G650X Challenge
2002 R1150GS ADV
Iron Butt # 7362
Trailace is offline   Reply With Quote
Old 07-08-2010, 06:54 PM   #1433
dirtsurfer
dirtsurfer's Avatar
Oddometer: 1,954
Seems like it might be a good idea to do a reset. Whats the best way to accomplish this? Can i disco the battery and reconnect it and will that reset the codes for me? .....
This seems to reset everthin' but I am not sure about CPU codes
Old 07-08-2010, 07:00 PM   #1434
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,602
Question Clutch cable
Been on the MAX BMW website looking for a new clutch cable to use as a spare if needed.
Will any other cable work for our bike?
I have searched with no luck.
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 07-08-2010, 07:36 PM   #1435
olyflyer
olyflyer's Avatar
Oddometer: 1,201
It's under 'Steering' on the fiche, not sure if any others fit it
#Part NumberDescriptionlbQtyEach
0132737696788ACCELERATOR CABLE - L=890MM0.26 1 $33.49[IMG]CartView.aspx?PartNumber=32737696788&qty=1 &description=ACCELERATOR+CABLE+-+L%3d890MM&weight=0.26[/IMG]
0332737696787CLUTCH CABLE0.37 1 $36.65[IMG]CartView.aspx?PartNumber=32737696787&qty=1 &description=CLUTCH+CABLE&weight=0.37[/IMG]
0534327707996GUMMIMANSCHETTE
Oly
'Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living.' Miriam Beard
olyflyer is offline   Reply With Quote
Old 07-09-2010, 09:41 AM   #1436
bigdon
Oddometer: 2,627
I need a new chain.
It is a 520 is it not?
How many links for stock sprockets?
Thanks Guys.
Ride Pooie Ride
Old 07-09-2010, 06:46 PM   #1437
mxchamp
Registered Lurker
mxchamp's Avatar
Oddometer: 1,602
Talking
Thanks Oly!
Ride safe!!!!
2014 KTM 690 Enduro
Old 07-09-2010, 09:53 PM   #1438
Mtrain
free range
Mtrain's Avatar
Oddometer: 440
Originally Posted by bigdon
I need a new chain.
Thanks Guys.
Yeah 520 chain and I think its 112 links for standard 15/47 combo count the links on your old chain if you still have it and its the same set up.
Mtrain is offline   Reply With Quote
Old 07-16-2010, 06:19 AM   #1439
Hill Billy
Part-time Adventurer
Hill Billy's Avatar
Oddometer: 1,150
Timing chain noise
My Xc has developed what sounds like a timing chain noise when cranking and when it first starts up. the noise disappears as soon as the oil pressure comes up. The bike only has 10,000 k's on it.
Is this a common complaint.
Any ideas or advice appreciated.
Hill Billy is offline   Reply With Quote
Old 07-16-2010, 06:47 AM   #1440
toofast4uu
adventurer
toofast4uu's Avatar
Oddometer: 972
Motion Pro just shipped me a couple cables I had made for my X_Challenge. But please note that I had them made to fit japanese (or any aftermarket) clutch perch. (The cable "bung" on the perch side of the stock BMW cable is too large to fit into any other perches.)
Call motion pro, and they should be able to help you.
I can post the part# at some point over the weekend.
toofast4uu is offline   Reply With Quote
Times are GMT -7.   It's 10:28 PM.
