Old 06-06-2012, 03:41 PM   #601
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
The turn signal switch was a bit sticky, decided to pull it and clean it up. Not a big deal, I've dealt with the switches before and know to watch out for springs, balls, etc. Should have left this one alone cause when I pulled it out the switch housing was in pieces and the shaft of the toggle switch had busted off. Seems to have taken a hit at some point.
Managed to put it back together using a cutoff 4d nail and superglue, no improvement in function. Don't believe I'll be taking it out again...
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 06-06-2012, 04:48 PM   #602
Hannda
Short, fat, bearded, slow
Hannda's Avatar
Oddometer: 27,938
They make a replacement switch that's fairly inexpensive, has "push to cancel" for the directionals and, IIRC, has the high/low switch all in one unit.
Edit: There is an aftermarket switch available like I've described above, Kawasaki doesn't make it.
Post Edit:
http://www.angelfire.com/ut/moab/parts_frames.html
charging system is doing
Left Hand Plug n Play Switch PIC16-0030KLR650 Plug n Play87.95Push to Cancel Turn Signal, Head Light/ High-Low-Off - Parking - Passing, Horn, 16"wire, Nine pin connector Will also need Mirror Adapter sold below
Hannda screwed with this post 06-06-2012 at 04:55 PM
Hannda is offline   Reply With Quote
Old 06-06-2012, 06:15 PM   #603
8gv
Oddometer: 2,368
4d galv?
8gv is offline   Reply With Quote
Old 06-06-2012, 07:54 PM   #604
newcastleadam
Artful Tagger
Oddometer: 3,455
Originally Posted by 8gv View Post
4d galv?
Yup.
Yes, I am aware that there are both aftermarket and a huge plethora of used (since it share the same switch housing as the KLR650), but there is a hard deadline involved. Otherwise I'd be on eBay with a shopping list
Adam
Old 06-06-2012, 08:54 PM   #605
Fire Escape
Fire Escape's Avatar
Oddometer: 1,551
Current Residents
In your sig line, are those the bike you have owned or currently own? My wife thinks one is enough.
Those bikes, the wife's matching XT (no we didn't really need two) and an Mv7 currently share space here with a dozen boats (all small, most human powered). The downside to having a 'fleet' rather than one (can't imagine being that limited) or two bikes is that several haven't been ridden in the last year or two, don't know if I will ever get around to putting the Husky into shape - bought it broken and so it remains but it is just like the last dirt bike I owned back when I could claim to really be a dirt rider so ...
I maintain the premise that you 'need' different bikes for different rides, when did you see someone head out to play golf with one club? The process is made somewhat easier by being old, I have had years to collect this bunch and more importantly by having chosen to have toys rather than kids or a nice house. Perhaps I am fortunate, my wife has always been happy to have me spend money on a hobby rather than on drinking, gambling or ? I never planned on accumulating quite this many, the last two were somewhat accidental, I came across the Scram as a discounted leftover when in a weak moment, predicated by having been weeks accumulating the parts to fix the SuperGlide. My XT formerly belonged to my best friend who has passed away due to esophogeal cancer.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 06-06-2012, 10:47 PM   #606
8gv
Oddometer: 2,368
Bruce
Golf for me = three clubs and a case of balls
Old 06-07-2012, 02:49 PM   #607
Jeremiah
Jeremiah's Avatar
Oddometer: 138
Yeah!
Shouldn't that be 3 balls and a case of beer? When the balls are gone we get down to business.
DL1000K3
R65
R100S
GL1800
Jeremiah is offline   Reply With Quote
Old 06-07-2012, 11:14 PM   #608
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
Originally Posted by MrBob View Post
I got my bike nicely jetted for elevation but the trade off seems to be hard starting. I've gone from one or two kicks for the first start of the day to a bunch of kicks until it fires. Once it has been started, subsequent starts are usually one kick.
What is the starting procedure that works best for you?
My valves were adjusted about 500 miles ago and the sparkplug and air filter are new.
I don't know if others have had this problem, but giving a good kick on the arm often mashes my foot into the peg.
This evening I tried pulling the peg, removing the spring, and tightening the pinch bolt. Now, I can fold up the peg and clear it with the kick starter. A light tap on the peg with the toe of my boot and it falls back into place.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 06-08-2012, 07:26 AM   #609
Fire Escape
Oddometer: 1,551
Laugh Mashed Foot - Kick Starting
Yes more than one has had that issue! I heated and reshaped the lever so that I could keep my foot 'outside' of the peg. Someone recently had pictures of how they shortened the lever so that it ended up even with or above the peg which looked like a great solution to me. There was a time when I could just start it by hand, that avoided the whole issue but wasn't exactly easier.
Bruce
Old 06-08-2012, 07:47 AM   #610
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
That was me playing around in the welding shop. I've switched back and forth between a shortened and stock kick start arm and I think the shortened one will work better now with the peg out of the way.
bwanacswan's dad
Old 06-09-2012, 07:10 AM   #611
8gv
Oddometer: 2,368
When you get your bike to start on half a kick you won't hit the foot peg.
Try this:
Fuel tap left on all the time, even for two weeks of non use.
Enrichment lever on full.
Throttle at idle.
With bike on side stand, stand tall and gently push the kicker down half way.
You will feel one compression stroke. If you missed it, do it again.
Give a good swift half kick.
It now runs and is increasing in speed so start backing off the choke to stay under 2000 rpm.
Old 06-09-2012, 08:47 AM   #612
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
Try this:
Throttle at idle.
Another turn out of the mixture screw to 3 turns, get on the compression stroke, half choke, one kick and she fires yesterday evening as I'm off for my ride in the countryside to watch the sun set behind the rockies.
bwanacswan's dad
Old 06-11-2012, 06:45 PM   #613
250kicker
Oddometer: 21
Today my Custom Dynamics LED 1157 bulb arrived. The part # is GEN-20-R-1157. Installing it in the rear bulb socket required a few minutes with my Dremel. The edges of the bulb cluster barely rub on the socket and prevent it from fully seating. A little grinding on the plastic edge of the socket and it was home.
Huge difference, the brake light is much brighter. You numbers people can work out how much amperage I saved.
The bulb cost me 32.95 and shipping from N.C. was 8.95. I'm sure the bulb will outlast the bike.
I'll post up photos eventually.
http://www.customdynamics.com/motorcycle_lights.htm
I just bought this bulb after reading your post WOW its bright- kinda made me think the brake light was stuck on so i hit the brakes and it got even brighter. I was all ready with the dremal tool but didnt need it at all. I got the same part # (off you) I have a 1999 KLR250. i pulled the old bulb out and this one spun, locked and slipped right it with NO modifications. you sure you needed to dremal or maybe model years different or something? anyways...great investment.
250kicker screwed with this post 06-11-2012 at 07:20 PM Reason: modifications not needed for mine.
250kicker is offline   Reply With Quote
Old 06-12-2012, 06:52 AM   #614
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
My bulb seems unaffected by the dust and vibration of all the trail riding I've been doing and I'm quite pleased with it. I'd like to find an LED substitute for the headlight and save even more amps for my heated grips. Did you get a coupon with your bulb?
In my case, I did need to slightly chamfer the lower edge of the white plastic to get the bulb in without forcing it but, YMMV. The Dremel was perfect for that.
bwanacswan's dad
Old 06-13-2012, 09:13 PM   #615
newcastleadam
Artful Tagger
Oddometer: 3,455
Sold my '98 KLR250 the other day, made me
Then picked up a project '86 KLR250 today, made me
Adam
Times are GMT -7.   It's 06:08 AM.
