01-22-2013, 05:14 AM
#931 | |
Oddometer: 141
Sent from mobile
Don '05 KLR 250; '09 Suzuki TU250x; '70 Honda Trail 90 |
01-22-2013, 06:51 AM
#932 |
Oddometer: 1,083
Here's a few more pictures I just took:
Kick starter clearance. It's tight but works: ![]() The gusset at the bottom is where the hook is currently: ![]() I think I'm cutting a small notch in the fender to move the hook up to just above the frame: ![]() Bag sits a bit crooked. Notching the fender and moving the hooks up will fix this ![]() Strap is right at the limit. Again, a fender notch will fix:
01-22-2013, 07:13 AM
#933 |
Oddometer: 81
Good Frt Brk Pads? EBC Sintered R Series?
These are made in the USA, FA67R. Seem to get good reviews online. Thanks for any feedback. ('89 KLR250)
01-22-2013, 12:32 PM
#934 |
I just....don't know
Oddometer: 254
01-23-2013, 12:24 AM
#935 |
Oddometer: 896
I've mentioned my '89 basket case. I am reading and re-reading this thread for info.
I realize I need the KLR 600 base manual, and the KLR 250 Supplement. I found that the KLR 600 appears to have been in production from '84-'90? I am wondering, would the manual of any particular year be preferable? |
01-23-2013, 05:36 AM
#936 | |
Oddometer: 2,019
You could probably interpolate some yourself and "get by" with a KLR650 manual, either Kawasaki publication or Clymer's, but . . . wouldn't say the technique "preferable" to a KLR600 manual; YMMV! |
01-26-2013, 07:53 PM
#937 |
Artful Tagger
Oddometer: 3,423
Finally got my basket case twofiddy running. The 1.0mm over Wiseco piston worked great....until the slighly ganked cam chain tensioner cap screw gave way and started burping oil. Also noticed that the handlebars took some hits, so that's on the list too.
Adam 86 KLR250 01 KLR685 06 K1200LT As ever, buyer and seller of all things KLR KLR Doohickey Wrench available! The North Florida Tag-O-Rama wants YOU! |
01-26-2013, 08:29 PM
#938 |
Oddometer: 9
I have a Klr 600 base manual for sale you can have.
01-27-2013, 05:36 PM
#939 |
Oddometer: 141
Got my bash plate installed, finished setting the valves and got her put back together. Wired in phone, gps, and Trail Tech computer on a switch. So far so good.
Then I pulled the rear suspension links and pins to swap for lowering links and was disappointed to find rusty pin surfaces and rusty pins where the links were in contact with them. I tried polishing out with steel wool, but there is very shallow pitting. After seeing that the pins rotate on roller bearings, and those surfaces were clean and undamaged, I have come to the conclusion that unless there is a loose fit, the rusted links and pins are not a problem. Thoughts? ![]()
01-28-2013, 06:56 AM
#940 |
Artful Tagger
Oddometer: 3,423
Should be fine. Perhaps apply a film of anti-seize during re-installation?
01-28-2013, 06:21 PM
#941 |
Oddometer: 141
anti-seize... good idea
Not in my routine, thanks for suggestion!
01-30-2013, 02:05 PM
#942 |
Oddometer: 81
Selling '89 KLR250 Soon: Maryland
I bought a well-maintained '89 KLR250 from another member here but have decided I miss having a XT225 too much. This is advance notice as I need to sort out a front brake problem first. This is the last year of the 28 hp model. After that you got 23 hp. Some of you may remember this bike and the owner. I will probably be asking $1000. for it and a box of spares. More pics available on request.
02-01-2013, 08:46 PM
#943 |
Adventurer/Goof-off
Oddometer: 50
Wish you were closer stevemd
That's just the bike I'm looking for close to birmingham al. I've got an 88 I've fixed up and want a match for a tat trip with my son this summer.
2003 YZ450F 1988 KLR250 |
02-02-2013, 06:11 PM
#944 |
Oddometer: 1,252
Safety switches...
Ok so I'm finally going to disable the switches on my KLR250. I'm too lazy to look it up. Am I making the circuits or breaking them? Is there a cleaner place to do this such as under the tank?
Thanks! |
02-02-2013, 06:43 PM
#945 |
Oddometer: 141
What? Why?
I just added switched power outlets for phone, GPS, and trail computer. Maybe removing signals horn and such to make it a woods bike? Sent from mobile
