Old 05-11-2008, 05:51 AM   #1
Nick Makwell OP
Bavarian Murder Weapon
Nick Makwell's Avatar
Oddometer: 672
Wicked R65 Project
I'm collecting parts for a project based on a 1984 R65 that I'm picking up shortly (its in ok condition, engine/drive and frame is straight, rest is missing or beat up)
I want to do the following and yes, it will end up being a Frankenbeemer!
1. change gearbox to slash 5 4-speed with kickstart (and remove electric start)
2. install a monolever final drive/swingarm and go to one rear shock
3. use a K75 or similar 3-spoke mag rear wheel
4. change front end (which is bent) to a Suzuki SV650 or something similar, even a Suzuki GS500 with one disc
Questions:
can I do 1-4 without any BIG dramas?
I think the gearbox is a straight bolt on, but converting to monolever im not sure. Furthermore, what particular swingarm/FD is the best (or actually fits) and can take the 3-spoke rear wheels AND the /5 transmission?
Im slowly researching this one and have started to gather parts - yes, it will end up a cafe racer, and I know it will cost a bundle, but I dont care!
I'd really appreciate any help on this one, even if you can just point me to some links etc
_________________
1981 BMW R65 - "Seven"
Nick Makwell is offline   Reply With Quote
Old 05-11-2008, 06:49 AM   #2
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
1) Very likely a 1984 gearbox does not fit without changing the clutch assembly as well (to the later lighter flywheel design), you have to customize the gear shift lever as well as the shift linkages are different
2) Doable, but needs modifications to the frame for the upper shock mount, there might be other limitations I am not aware of
3) If you want mag wheels go with 1985 rear end from a 1985 Monolever R80RT or something, that is plug and play except for issues mentioned under 2). If the bolt pattern matches to a 3-lug monolver drive, it might just work
4) Be aware of rake angle and height: again, a 1985 monolever front end can be used, dual discs and brakes are half decent with options to modify/upgrade
You can go much wilder and install a 1988-on paralever drive with a K1/K1100 disc brake rear end and front K100 forks. I have not seen the K rear end mod in Northamerica (it is quite common in Europe), Lornce did the K100 front forks mod on his R100.
I personally like this BMW-Ducati hybrid with K1 front forks, a K100 rear end and custom made swingarm (based on a monolever) with two exhaust cans under the seat:
Almost everything can be done.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 05-11-2008, 07:17 AM   #3
Nick Makwell OP
Oddometer: 672
Thanks Stephen - ive got the front on picture of that bike, but not the rest!
I would like to go similar route that bloke has done, with cast wheels instead of spoked, and with the monolever rear end.
I think converting to a monoshock entails a K100 type monolever (and similar shock) with a new frame tab and reinforcement (if necessary) welded on to the rear.
I think going to the K1100 front end is overkill - im looking to use Jap bike stuff, maybe from an SV650 or similar, or maybe just one disk.
Another Question - does the K final drive bolt straight onto ANY monolever swingarm?
thanks again Stephen
_________________
Old 05-11-2008, 09:13 AM   #4
StephenB
StephenB's Avatar
Oddometer: 2,044
No personal experience. Just a atter of asking the early Bricks guys for dimensions, I suppose. Also ask for dimensions for the input gear, that might need replacing with a R input gear.
Do yourself a favor and research the subject to death, it might otherwise be a costly experience ...
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 05-11-2008, 11:04 AM   #5
Spicy McHaggis
Darth Peach's cracker...
Spicy McHaggis's Avatar
Oddometer: 3,789
Thumb
I'm watching this one, since I just picked up two (one running, one parts/project) R65's. One is an '84, the other an '82.
2006 DR650
Spicy McHaggis is offline   Reply With Quote
Old 05-11-2008, 12:56 PM   #6
Alfons
Oddometer: 101
Hi lads,
greetings from Germany! I talked to the guy who accomplished this marvellous BMW-Ducati conversion, and he told me that the K final drive DOES NOT bolt onto the monolever swingarm. So this involves a lot of intricate work: you have to weld a flange onto the mono swingarm, adapt the driveshaft (length and so on), which requires expert knowledge.
But there seems to be another way of making a three-spoke K-wheel fit on a mono final drive. The wheel and a brake disc canboth be fitted with the four bolts just like the mono wheel, what you need is an adapter for a brake caliper plus all the rest of the disk brake equipment.
best wishes
Alfons
Alfons is offline   Reply With Quote
Old 05-11-2008, 01:25 PM   #7
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
Post /2 kick-start levers have an extremely short throw. I suspect you will be mighty sorry you got rid of E-start.
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 05-11-2008, 02:19 PM   #8
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,228
Questions:
There will always be big dramas on stuff like this.
The kick will work OK. You might get tired of it. You'll have to either go to the early flywheel and clutch or make some other conversions because the /5 tranny isn't 100% compatible with your clutch. But you can get the kicker in an '81-on 5-speed tranny also, which will just bolt on.
You'll have to use an '85-on Airhead monolever and final drive. Then it's mostly a bolt-on. Otherwise you'll have to adapt the driveshaft and so forth. Remember you'll have to work out the rear brake, since all of the monolever Airheads were drum and the 3-spoke wheels are all for disk.
Old 05-11-2008, 05:29 PM   #9
Nick Makwell OP
Oddometer: 672
Thanks for the replies so far.
Update - bike is bought, and will be shipped to me by the end of the week.
I have already done some research, but will be spending a lot more time as I get into this more - I have my eye already on a pre-74 (1971 /5) tranny - apparently after '74 the kickstart lever wasnt that well built.
I'm used to low compression kickstart bikes, and this project will be a Sunday morning/Friday night poser bike (I admit that!) so, I don't think I'll be too concerned about the kick!
I thought that the best way was a post 85 R-airhead monolever swingarm and final drive, mated to a 3 spoke K bike should only require a bracket/space etc for the disk brake - so thanks for confirming that Anton - and YES I have been reading your site too!
Hmm...changing the clutch/flywheel etc may be a drama - but I may have to replace the original clutch anyway on the donor bike, so maybe not?
Thankyou Alfons for the info as well - the BMW-Ducati conversion is brilliant. I have a picture somewhere of a guy with similar swingarm and front end, but with no fairing. Ill post it later.
Just bought a spare R65 triple tree - so I'll start researching what front end I can put on the bike (the original will be sold, its a single disk with a pitted fork).
anyone know the fork diameter on the R65?
_________________
Old 05-11-2008, 07:25 PM   #10
RocketJ
Oddometer: 674
Input shaft
Of course, if you are real good with angle grinder you can cut .250 off the 4 speed input shaft..............
RocketJ is offline   Reply With Quote
Old 05-12-2008, 01:34 AM   #11
Alfons
Oddometer: 101
Hi it is Germany again here,
R 65 forks are 36 mm just like the forks used in all the type 247 airheads. I would suggest considering K 100/K75 forks as these are made for bikes which are not as heavy as the K 1100s, so the forks springs might work well in a much lighter bike.
If I were you I would keep an electric starter since they are more convenient than a kick starter, particularly since the kick starters of the later series are useless, and with a /5 gearbox you would be restricted to the heavy flywheel.
Keep us informed
Alfons
Old 05-12-2008, 08:10 AM   #12
Zebedee
Zebedee's Avatar
Oddometer: 809
I hate to disagree, but having just acquired a very tired example of an R65, the info that I've found is that the R65 forks are not interchangeable.
[edit: full article here]
I'd love to be proved wrong.
Regards
John
The perverse must persevere
Zebedee screwed with this post 05-12-2008 at 11:12 PM
Zebedee is offline   Reply With Quote
Old 05-12-2008, 12:37 PM   #13
Alfons
Oddometer: 101
Hi John,
again it's Germany calling. You are right in so far that the forks are definitely not interchangeable since yokes (fork legs are about 7mm wider apart) and interiors are different from the the forks used on the /5 to /7. However, the diameter is the same.
greetings
Alfons
Old 05-12-2008, 05:59 PM   #14
Zebedee
Zebedee's Avatar
Oddometer: 809
... However, the diameter is the same.
Well you live and learn ...
Old 05-12-2008, 10:56 PM   #15
Nick Makwell OP
Oddometer: 672
link doesnt work?
interesting - in my search for a different front end, i hadnt contemplated the K100/1100 front (see first photo above) but, am open to ideas...and I might be able to get my hands on a good example, complete.
So - another question - - does that front end bolt on to an R65 frame, or need some mods?
failing that, what other bikes have 36mm forks?
Bike is being shipped this week........happy days. Wife has told me to hurry up and sell first bike, but she's interested in this project....
_________________
Times are GMT -7.   It's 04:31 AM.
