Old 05-20-2008, 03:16 PM   #1
blkhrt81 OP
Oddometer: 617
Scrambler hack
Got my old Velorex hack bolted up to the Scrambler yesterday, set toe-in and leanout this morning and it is on the road! Had to adjust the leanout after the first 200 yds, it was pulling real hard left, backed off on the leanout and now it goes nice and straight. The Scrambler handles it really well though I was bucking a headwind coming home and had trouble holding highway speeds. I was pretty well on the pin at 110 kmph, had a truck go by and break the wind and I could get back up to 120.
blkhrt81 is offline   Reply With Quote
Old 05-20-2008, 03:18 PM   #2
blkhrt81 OP
Oddometer: 617
Front mount
Old 05-20-2008, 03:21 PM   #3
blkhrt81 OP
Oddometer: 617
Back mount, the subframe is bolted to the centrestand lugs.
Old 05-20-2008, 03:23 PM   #4
blkhrt81 OP
Oddometer: 617
Top front mount
Old 05-20-2008, 03:43 PM   #5
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,879
Pretty cool! Did you change your sprocket(s) so the gear ratio was a little better for dealing with a car?
"My sister is a slut." Charlotte Bronte
"My sister is a cheap whore." Emily Bronte
Mista Vern is offline   Reply With Quote
Old 05-20-2008, 04:04 PM   #6
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,105
looking good!
05 R1150R....now 2 wheels...soon 3 wheels.
84 Kwaka GT750 Cafe Project & 84 Kawaka GT750 Outfit
TouringDave is offline   Reply With Quote
Old 05-20-2008, 06:03 PM   #7
JohnTM
I suck toes
JohnTM's Avatar
Oddometer: 29,206
Very cool! What does that sidecar weigh?
JohnTM is offline   Reply With Quote
Old 05-20-2008, 06:26 PM   #8
wyowillys46
Hau Ruck!
wyowillys46's Avatar
Oddometer: 2,115
You might look into shortening that standoff. It looks like it could be prone to bending if the sidecar hit a bump or came down hard on something. Just my .02 from an engineering perspective.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo
wyowillys46 is offline   Reply With Quote
Old 05-21-2008, 04:51 AM   #9
JohnTM
I suck toes
JohnTM's Avatar
Oddometer: 29,206
Upper rear one, or all?
Old 05-21-2008, 07:35 AM   #10
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,685
Here's a mount that was done by Doug Bingham of SideStrider.
The mounts seem a lot more substantial.
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 05-21-2008, 04:21 PM   #11
wyowillys46
Hau Ruck!
Oddometer: 2,115
Upper rear.
Old 05-21-2008, 08:24 PM   #12
blkhrt81 OP
Oddometer: 617
Good point, thinking I might weld a tube and gusset there to stiffen it up.
Old 06-12-2008, 08:42 PM   #13
blkhrt81 OP
Oddometer: 617
So far gearing is stock,think I'll run for a bit and decide on a change. Not sure what the car weighs but compared it to a Velorex 562 a little while ago and I think it is heavier. Fellow told me he needs 80 lbs of ballast in his 562 and I haven't been running any. My brother and I carried the car to the garage so I doubt it is much over 150 lbs.
Old 06-13-2008, 08:52 AM   #14
Mista Vern
Mista Vern's Avatar
Oddometer: 16,879
Cool - be curious to learn how it handles head and cross winds. Thanks for sharing your progress!
Old 06-13-2008, 09:41 PM   #15
blkhrt81 OP
Oddometer: 617
It handles crosswinds pretty well, almost better than solo I think. I mounted a windshield but haven't had it out with the hack on since and I'm back at work now so won't get a chance until mid July. Headwinds slow it down but other than that are no problem. I am really pleased with the way it handles, MUCH better than with the old IZH that it was originally on. Road camber has quite an effect on it but on smooth pavement with minimal headwind I've hit 135 kmph or about 80 mph and it has stayed stable and neutral steering.
Times are GMT -7.   It's 02:23 AM.
