Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 05-09-2012, 07:36 PM   #17641
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 9,004
Steven,
Apology accepted.
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Old 05-09-2012, 08:26 PM   #17642
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,236
Originally Posted by The Walrus View Post
Steven,
Apology accepted and I'm sorry too.
Do I have to do everything for you?
pluric is offline   Reply With Quote
Old 05-09-2012, 08:35 PM   #17643
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,236
Old 05-10-2012, 07:32 AM   #17644
dakardad
Not waiting for anyone
dakardad's Avatar
Oddometer: 445
Whats the interest in Fantasy Canyon?
Why is it worth it?
Where am I going you ask.... I dunno really
just THATAWAY!!
dakardad is offline   Reply With Quote
Old 05-10-2012, 07:40 AM   #17645
dakardad
dakardad's Avatar
Oddometer: 445
Ok, nevermind. Its an interesting stretch of the legs.
just THATAWAY!!
Old 05-10-2012, 07:51 AM   #17646
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,236
Why is it worth it?
Men have been interested in "Fantasy Canyon" since the dawn of time.
Now whether it's worth it is another age old question.
Old 05-10-2012, 09:56 AM   #17647
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,236
Originally Posted by Ryman View Post
Ahhhhhhhh! Fantasy Canyon.
I guess I was thinking more Fantasy Cave. Canyons not bad either.
Old 05-10-2012, 01:27 PM   #17648
RetrogradE
RetrogradE's Avatar
Oddometer: 1,226
Hey, I know this is a bit of a stretch, but do any of you have an aftermarket seat for an 1150GS Adventure?
I can either trade a stock black / yellow GSA seat or some dead presidents.
The standard GSA seat is a little too tall for me; I like the stock low seat I am using but wouldn't mind something a little . . . nicer.
PM me if you've got anything--thought I'd try Utards before posting in flea market.
RetrogradE is offline   Reply With Quote
Old 05-10-2012, 01:58 PM   #17649
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,236
How many of those Presidents do you have???
Old 05-10-2012, 04:12 PM   #17650
dakardad
dakardad's Avatar
Oddometer: 445
Ummm, mearly a snack ma boy, mearly a snack.
just THATAWAY!!
Old 05-10-2012, 07:14 PM   #17651
miatre
So yeah about that.
Oddometer: 88
CRF motor pro needed
I have a crf250x moto that I am in the process putting a new top end on.
I put a 250r head, a hot cam and weisco piston in. Everything else is stock.
I have everything installed to make the motor run and it does run and start just fine.
Started it for the first time and there is an abnormal noise in the motor.
Turned it off and removed and reinstalled the kick starter and that helped with some of the abnormality noise but something else still doesn't sound right.
Im not certain what to look for next.
I have shimmed the valves prior to starting can turn the motor over by hand using allen head with no abnormal noise that I can tell.
The motor has ran for maybe 30 seconds. How long does the motor take to prime the oil to the head?
Suggestions?
TIA!
miatre is offline   Reply With Quote
Old 05-10-2012, 07:29 PM   #17652
pilo
Rhymes with below
pilo's Avatar
Oddometer: 944
I'm no motor pro but I've been in a few.
1) Did you take off the side cover and remove the kickstarter mechanism? They can be a pain to get back in properly.
2) Can/could you tell where the noise was coming from?
3) Are you sure the cam chain tensioner is installed correctly (tension pulled OUT before installation)?
4) All bolts were torqued properly (with a torque wrench).
pilo is offline   Reply With Quote
Old 05-10-2012, 08:00 PM   #17653
miatre
So yeah about that.
Oddometer: 88
I oringally had it in wrong. I took it out and put it back in. Some of the original bad noise is now gone. There are alignment marks on the kick starter that I didnt know of at the time.
Not really I think its maybe in the head/cam chain but havent let it run long enough in fear of damaging something.
Not certain about this one. What do you mean about tension pulled out? I installed the ACT with the pressure retracted, screwed it in and then let the tension out onto the cam chain. Ill go re-read the fsm.
All bolts other than the case bolts have been torqued.
Thanks for the fast reply.
Old 05-10-2012, 08:21 PM   #17654
pilo
Rhymes with below
pilo's Avatar
Oddometer: 944
Does the kick starter engage in the same spot it did before and spring back to the same spot? I've put them in wrong and they make a nutty sound.
By the way, the pressure builds pretty quickly, but when I go in to the head/valves I always dump a little oil around cam just to make sure there is enough there on startup.
Old 05-10-2012, 08:35 PM   #17655
pilo
Rhymes with below
pilo's Avatar
Oddometer: 944
Oh, and it sounds like you did the tensioner exactly correct.
Times are GMT -7.   It's 08:46 AM.
