Old 05-23-2012, 06:04 AM   #17866
trackhead
Oddometer: 2,684
Originally Posted by Ryman View Post
I've been looking at big bikes. Thought I had a deal on the silver one but alas. The price on SE's is crazy. I think in 07-08 you could get one new from the dealership for around 9k. Now I see used ones going for 11-15k???? I've never seen a bike appreciate like that.
Ryman,
Why do you want a big bike? It seems like your bike is perfect. I've never heard you post anything about any mechanical issues, it's more well rounded than a big bike, and you can pretty much ride it everywhere? It seems more reliable than those big KTM's too? What am I missing?
trackhead is offline   Reply With Quote
Old 05-23-2012, 06:31 AM   #17867
Ryman
Oddometer: 596
Originally Posted by trackhead View Post
Ryman,
I'm not getting rid of the 690. It is the coolest, most versatile bike ever created. Just looking for something new to play with. On a RTW type of trip the Adventure would be great. I'm not totally sold on the big bike idea, just kind of shopping around and checking things out.
Utards in Baja
http://www.advrider.com/forums/showthread.php?t=674444
Ryman is offline   Reply With Quote
Old 05-23-2012, 07:35 AM   #17868
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 8,092
I had a wonderful wrenching session on the BMW's yesterday....must have been in the breeze. Since I did oil/valves/sync in the fall, those items were not the issue. Somehow, I've never flushed the hydraulic clutch and lost it this past spring. First symptom was the catch point was closer and closer to full pull. One week of that and it evolved into pull the lever and no clutch. Those Bavarian folks are not benevolent when it comes to design and build. The end of the clutch circuit should have a bleeder nipple, but no.........it's got an aluminium tip which incorporates a check valve.....
The original Gspot FAQ's tell you to put a bleeder nipple on top of that but cap effn screw stripped out........effn aluminium being soft as pluric's ricky....so I started to think it needed replacing....wrong, you can remove it an place the grub nipple behind it on that fitting.....
Turns out the K1200RS has the same aluminium fitting on the front brake circuit on the right side caliper and since I'm opening fresh DOT4 as the replacement clutch fluid, I might as well flush all four ABS brake lines....so off to the stealer....and thanks to Ryan at the remaining Sandy BMW......for a matched set of nipples to bleed the lines....Now those of you who have spilled DOT4 on anything know that you must have at least 4 damp rags covering any exposed paint or plastic cause sure as shit, that stuff will get on it and dissolve it......I think it took around the four hours Moo quoted to complete this joyful task.....and since it's been two years since my last recorded brake flush on both bikes, the fluids were looking pretty ugly......especially on the short front line of the K12 where the folks I paid at BavarianMW hadn't replaced the fitting nor flushed that section of line................looks like it's better to cuss and do it correctly yourself than to pay someone to do it halfway.........
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Old 05-23-2012, 08:09 AM   #17869
Double Moo
lookin' for adventure
Double Moo's Avatar
Oddometer: 953
I got an M7x1.0 tap you can use...
"Rember... Wherever you go... there you are"
Buckaroo Banzai
Double Moo is offline   Reply With Quote
Old 05-23-2012, 08:10 AM   #17870
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,718
You and Double Moo should get together. Seem to have a lot in common
when it come to dealing with anything oil related.
"soft as pluric's ricky"..... damn that's like putty.
pluric is offline   Reply With Quote
Old 05-23-2012, 08:23 AM   #17871
Double Moo
Double Moo's Avatar
Oddometer: 953
Putty is definitely less pliable than the aforementioned marshmallow... is all this oil/lube talk having an effect on Ricky?
Buckaroo Banzai
Old 05-23-2012, 08:26 AM   #17872
The Walrus
The Walrus's Avatar
Oddometer: 8,092
Thanks, but I did not need to tap it, you just pull that aluminium off and discard it as in the second photo...
pluric • Today 09:10 AM
.......I've been brushing up on my prose with a wonderful tutor...........
Old 05-23-2012, 08:32 AM   #17873
Ryman
Oddometer: 596
Really??
Utards in Baja
Old 05-23-2012, 08:37 AM   #17874
Double Moo
Double Moo's Avatar
Oddometer: 953
I've got a tap for that...
Buckaroo Banzai
Old 05-23-2012, 08:52 AM   #17875
The Walrus
The Walrus's Avatar
Oddometer: 8,092
Originally Posted by double moo View Post
i've got a tap for that...
m7............?
Old 05-23-2012, 09:14 AM   #17876
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,718
I had one, it turned into BMW aluminum.
Old 05-23-2012, 09:23 AM   #17877
dakardad
Not waiting for anyone
dakardad's Avatar
Oddometer: 417
Im headed out for a few days starting the 1st to the 5th. Planning on taking the north slope rd to the Yampa bench, then south to hook up to the kokopelli. From the bench thru the kokopelli is new for me. Lots of possibles but looking for suggestions on a cool route. Single track is ok but I dont have GPS.
Right now Im solo but a ride partner would be good.
I may not know where I am, but I'm not lost.
But I'm gonna keep looking.
dakardad is offline   Reply With Quote
Old 05-23-2012, 10:17 AM   #17878
z987k
z987k's Avatar
Oddometer: 976
z Just checking out your pics. Pluric would be proud.
Ya that was a few years ago. Reminds me of what massive pig that lump is.
I don't ride the fat one's anymore
z987k is offline   Reply With Quote
Old 05-23-2012, 10:25 AM   #17879
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,718
Suit yourself.
Old 05-23-2012, 01:13 PM   #17880
trackhead
Oddometer: 2,684
Originally Posted by pluric View Post
Suit yourself.
That, and post/beat off on ADVrider.
Times are GMT -7.   It's 02:12 AM.
