Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 08-16-2012, 09:17 AM   #18301
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,503
Bitches,
I have confirmed that I have days off in September; the 7th through the 19th, to be specific. I am considering a ride to Bend, OR as there is a little KTM gathering going on at that time, but could easily be persuaded to hang out with scum like you instead. I am very open to any ideas for rides at that time and can bring the 300, the SFE (Super Fucking Enduro), the soon to be picked up 500 XCW, or all three.
Awaiting your reply.
Sincerely,
The handsomest Utard in Lubbuttock, TX
Ate-oh-one. ate-7ven-niner. one-0ne-5ve-7ven
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 08-16-2012, 09:35 AM   #18302
GISkev
wwfsmd?
GISkev's Avatar
Oddometer: 1,796
Giddeeup!
Originally Posted by HickOnACrick View Post
Bitches,
Sincerely,
I could probably roll out the BRP and ride a day on each side of a weekend...
Merge w the traffic, but don't go w the flow!
KTM 520, Versys
GISkev is offline   Reply With Quote
Old 08-16-2012, 12:50 PM   #18303
HickOnACrick
Groovinator
Oddometer: 2,503
Originally Posted by Ryman View Post
I'm kind of in the trenches right now, but I'd love to have a ride.
I'll ride ya big boy
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 08-16-2012, 01:09 PM   #18304
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,237
Seriously......If your cummin I'm
swallowing.
Okay, time to take it to a PM. Some of us just had lunch .
pluric is offline   Reply With Quote
Old 08-16-2012, 01:48 PM   #18305
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,237
EEww gross. I see you and my smart phone have the same dirty mind. Who would think of that........
You and Hick. Was that some sort of trick question???
Old 08-16-2012, 04:53 PM   #18306
GISkev
wwfsmd?
GISkev's Avatar
Oddometer: 1,796
Hey look! Hicks Keys!
KTM 520, Versys
Old 08-16-2012, 05:06 PM   #18307
GISkev
wwfsmd?
GISkev's Avatar
Oddometer: 1,796
Butt seriously....
so i changed the rear wheel brake pads on the Vstrom and now my brake lights are permanently on... do i need to take fluid out? if so, what's the best way to do that. I've bled lines and I've got to say that it's not my favorite wrenching operation.
KTM 520, Versys
Old 08-16-2012, 05:08 PM   #18308
KMC1
There is no spoon.
Oddometer: 2,561
Kevin, there's usually an adjusting bolt on the brake pedal to move the engagement point.
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 08-16-2012, 05:18 PM   #18309
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,237
Geez how thick were the new pads??? Make sure the brakes aren't dragging. Maybe bleed a little
fluid out. 8mm bleeder on the slave cylinder. Just don't let it suck air in. Quick open and close once
or twice should do it. I do have a speed bleeder if you want to replace the oil. Only takes a few minutes.
If you have this style rear brake light switch just turn it to take some spring pressure off the switch.
Old 08-16-2012, 07:38 PM   #18310
Abey
Abey's Avatar
Oddometer: 13
I was going to Cherry Creek on a dirt bike .
White Carbon Matrix plus 60-70# RKT 31.5" draw
xenon hid kits 40-50# SpiralX 31" draw
Abey is offline   Reply With Quote
Old 08-16-2012, 08:14 PM   #18311
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,237
That's a good start. And?
Old 08-16-2012, 10:10 PM   #18312
KMC1
There is no spoon.
Oddometer: 2,561
Lmao! And EWWWWWWW!!! I'm never gonna let another elephant rub it's trunk over my face and body......again,,,,,
Old 08-16-2012, 11:08 PM   #18313
dieselcruiserhead
Oddometer: 1,462
Pretty bummed, first went on a crazy adventure a couple weeks ago trying to find the end of a trail that connect Brighton Estates (up in Guardsman's) to the midway/AF canyon trails. At the end the trail disappeared and we basically had to hike a bike for a mile or two and it was steep as hell and the bikes went over probably a dozen times or so in the process.
Then after a dump there must have been some oil that got into the cyclinder somehow and it appears I lost my rings I guess. Bike starts and runs, but... 50 PSI on the cycl. Oil was coming out of the exhaust. Bummer because there aren't a whole lot of miles on this motor, maybe 2000 or so since the last rebuild? Oddly still starts and runs but definitley burning a ton of oil too..
Anyway, questions are:
- Does anyone have the top end KTM RFS tools I could borrow.
- Carb also seems to have stripped out its fuel screw because a POS aluminum Tusk knob. Do not buy a Tusk aluminum air/fuel knob for your KTM, always buy brass.
- This is an 02 which is good but has less top end than the later ones. Anyone have a '03 to '07 525 engine lying around, even if it needs a rebuild?
- Not sure if I should upgrate to a 41mm carb in the process, I have a '39 on this 02 but the later ones had the 41.
- Not sure if folks have recommendations on parts and/or where to machine locally. I'll def be finding some stainless valves at bare min and imagine the head and cyl will need some work.
- Considering pulling the bike completely apart and possibly repowdercoating the frame. Not sure if that is overkill...
All ears on recommendations...
dieselcruiserhead is offline   Reply With Quote
Old 08-17-2012, 07:49 AM   #18314
harcus
harcus's Avatar
Oddometer: 1,333
Bitches,
Sincerely,
I think it all depends on how much fun you can handle. Since defection to the south I am certain you are out of practice, physically n mentally. I would recommend you leave all 3 MCs at home & bring your Schwin so you can retone your decrepit body.
Want Creative Adventure Products? - See Globetrottin.com
Current rides - '14 KTM 1190 R Adv <2k, '07 990Adv 39k, '12 500EXC 7k, '09 GasGas 300 Raga
harcus is offline   Reply With Quote
Old 08-17-2012, 07:53 AM   #18315
harcus
harcus's Avatar
Oddometer: 1,333
Isn't oil in the exhaust usually a bad valve guide seal?? Why not just pull the head and check it out?? It doesn't require any special tools. You could take the head to lindsay and check out the rings yourself. You could probably be back and running for under $100.
Or a broken ring. If oil got into the cylinder while in an upside down position it could have over pressurized & cracked a ring. Anyway, it needs to have the top popped off & inspected before more damage occurs.
IMHO, that is...
Shit happens...
Times are GMT -7.   It's 10:49 AM.
