Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 08-16-2012, 04:10 AM   #18346
Trail Dumpster
4.5 Years to Freedom
Trail Dumpster's Avatar
Oddometer: 152
I'm headed home from the STAN soon, any rides planned for mid September or October?
C-Advisor http://www.advrider.com/forums/showthread.php?t=741902
2010 Victory Vegas (Stock Rocks)
1992 Yamaha WR-500ZD (Plated) Needs rebuild Threw chain cracked case
1975 Honda XL175
1991 Klr 650.. 1994 FE501 Berg'
Trail Dumpster is offline   Reply With Quote
Old 08-16-2012, 06:25 AM   #18347
dentedvw
Where did I put that
dentedvw's Avatar
Oddometer: 2,164
There can be.
I have a jetting question, I am a carb newb. I never rejetted the DRZ after moving from a few hundred above sea level. In fact, I never rejetted it after I bought it from someone in Mississippi and shipped it to Michigan either.
It runs ok, but when I give it a lot of gas, for example trying to go up a steep trail, or over a tall step, or tree it will hesitate. Also, it smells like fuel a lot, but it could just be that it's so hot when I ride often. I haven't fouled the plug, and it always starts fine, idles fine.
Is there something I should adjust, move the needle up or down, or say some magic words? I honestly don't know that much about carbs and I would like to learn, and you lot are the only people I know to ask.
I've been invited on a four day ride in Idaho, and I want to make sure the bike is as ready as it can be, and this is one problem that bugs me sometimes. It doesn't prevent me from riding, but I worry sometimes that it's going to be a problem at high altitude one day. The higher I go, the worse it is.
"Even though my trip turned out badly, I don't regret the kind of life I chose to live. Adventure!" RIP-Clay Schwartz 9/14/07
The bike never has been, never is, and never will be the limiting factor in my, your, or anyone else's ability to have an adventure. -jake28-
dentedvw is offline   Reply With Quote
Old 08-16-2012, 06:46 AM   #18348
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,929
I put a dynajet kit on mine years ago. It got rid of the low speed stumble. I can't begin
to remember the settings. Just that I spent a whole afternoon dicking with it to get it right.
You should be leaner at this altitude. Try dropping the main a size or two. From the factory
they are lean on the needle so it may fine at SLC levels.
pluric is offline   Reply With Quote
Old 08-16-2012, 09:17 AM   #18349
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,519
Bitches,
I have confirmed that I have days off in September; the 7th through the 19th, to be specific. I am considering a ride to Bend, OR as there is a little KTM gathering going on at that time, but could easily be persuaded to hang out with scum like you instead. I am very open to any ideas for rides at that time and can bring the 300, the SFE (Super Fucking Enduro), the soon to be picked up 500 XCW, or all three.
Awaiting your reply.
Sincerely,
The handsomest Utard in Lubbuttock, TX
Ate-oh-one. ate-7ven-niner. one-0ne-5ve-7ven
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 08-16-2012, 09:35 AM   #18350
GISkev
wwfsmd?
GISkev's Avatar
Oddometer: 1,781
Giddeeup!
Originally Posted by HickOnACrick View Post
Bitches,
Sincerely,
I could probably roll out the BRP and ride a day on each side of a weekend...
Merge w the traffic, but don't go w the flow!
--GoProHero Helmet Cam!--http://www.youtube.com/results?searc...y=utahkev&aq=f
5 deserts:http://advrider.com/forums/showthrea...3#post15462553
KTM 520 (plated), Wee-Strom (commuter bike)
GISkev is offline   Reply With Quote
Old 08-16-2012, 12:36 PM   #18351
Ryman
Oddometer: 472
I'm kind of in the trenches right now, but I'd love to have a ride.
Ryman is offline   Reply With Quote
Old 08-16-2012, 12:50 PM   #18352
HickOnACrick
Groovinator
Oddometer: 2,519
I'll ride ya big boy
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 08-16-2012, 12:54 PM   #18353
Ryman
Oddometer: 472
Seriously......If your cummin I'm ridin.
Old 08-16-2012, 01:09 PM   #18354
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,929
swallowing.
Okay, time to take it to a PM. Some of us just had lunch .
Old 08-16-2012, 01:11 PM   #18355
Ryman
Oddometer: 472
EEww gross. I see you and my smart phone have the same dirty mind. Who would think of that........
Old 08-16-2012, 01:48 PM   #18356
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,929
You and Hick. Was that some sort of trick question???
Old 08-16-2012, 04:53 PM   #18357
GISkev
wwfsmd?
GISkev's Avatar
Oddometer: 1,781
Hey look! Hicks Keys!
Old 08-16-2012, 05:06 PM   #18358
GISkev
wwfsmd?
GISkev's Avatar
Oddometer: 1,781
Butt seriously....
so i changed the rear wheel brake pads on the Vstrom and now my brake lights are permanently on... do i need to take fluid out? if so, what's the best way to do that. I've bled lines and I've got to say that it's not my favorite wrenching operation.
Old 08-16-2012, 05:08 PM   #18359
KMC1
There is no spoon.
Oddometer: 2,562
Kevin, there's usually an adjusting bolt on the brake pedal to move the engagement point.
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 08-16-2012, 05:18 PM   #18360
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,929
Geez how thick were the new pads??? Make sure the brakes aren't dragging. Maybe bleed a little
fluid out. 8mm bleeder on the slave cylinder. Just don't let it suck air in. Quick open and close once
or twice should do it. I do have a speed bleeder if you want to replace the oil. Only takes a few minutes.
If you have this style rear brake light switch just turn it to take some spring pressure off the switch.
Times are GMT -7.   It's 10:52 AM.
