Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 04-16-2009, 06:48 PM   #2296
frog OP
frog's Avatar
Oddometer: 2,774
Renn you heading to knolls?
Thank you MX1WEST, Highway Dirt Bikes Lindsay Machine, Smart Performance, SPS for the Support
257x Solo Baja 1000
If I had not some strength of will I would make a first class drunkard--Shackleton
frog is offline   Reply With Quote
Old 04-16-2009, 07:26 PM   #2297
rennsportgsguy
rennsportgsguy's Avatar
Oddometer: 79
I wanted to, even after I spent last week in bed with pneumonia, but Kevin just told me all sales guys will here on Saturday. Jeremy will be there on a G450X and so will one of our customers Casey Newell. Do you need us to carry anything for you? Let me know,
Renn
rennsportgsguy is offline   Reply With Quote
Old 04-16-2009, 08:15 PM   #2298
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,800
Originally Posted by rennsportgsguy
I've had four bikes with final drives 99 R1100GS 37,000 miles never missed a beat. Still have a 2002 R1150 GS 78,000 miles no problems. I changed FD @ 600 miles and every 12,000 during Maint. 2004 R1150 Rockster 13,000 miles no problems. 2006 HP2 Enduro 6100 miles no problems, I ride the bikes hard on road, off road, stream crossings you bet I don't worry if the final drive is going out I just ride I don't believe BMW calls it a forever fill anymore, and hasn't since 2005, now they recomend @ 600 and every 12 k.
Was I the only one to hear Blah, Blah, Blah?
(Just jerking your chain, sounds so much better than SHAFT )
2004, BMW of North America, LLC
BMWMotorrad
USA
Service Information Bulletin
Subject: Bearing play at the rear wheel drive
Model:
Details:
Aftersales
Solution:
Dealer Operation/
General Manager
Sales-
Motorcycles
Sales -
Used Motorcycles
Business Manager
(F&I)
Service Parts & Accessories Administration
Date: February 2005
Bulletin #33 001 05 (011)
Source: 33 74/2004
BMW Motorrad USA Service and Technical
Contact: Respective Aftersales Business Consultant
R 1200 GS
1: In the rear drive of the R 1200 GS the ring gear is supported by two types of bearings:
one floating bearing and one fixed bearing without preload. Inherent in this design
is a small amount of bearing play at the rear wheel. With all components manufactured
and assembled to stated tolerances it is possible that play in these bearings can be felt
and measured at the rear wheel. This type of bearing play has no effect on motorcycle
handling or on the durability of the bearings.
2: There is a possibility of play developing between the splined wheel flange (P/N 33 17
7 668 659) and the axle tube of some motorcycles manufactured prior to 08/2004, US
VIN# ZL 76187.
1: In the event of a customer complaint, an inspection and measurement of rear wheel
bearing play is to be performed as described below. With cold components the total
play (back and forth travel) allowable at the wheel rim edge is 1mm(maximum). Refer to
the R 1200 GS Repair Manual CD for measuring procedures as well as temperature definition
of "cold components". Replace the entire rear-wheel drive assembly if the play
exceeds specifications.
2: If the complaint is "bearing play at the rear wheel" you must first check that the
splined flange is secure before performing the measurement noted in point #1. When
rocking the rear wheel back and forth, you must first make sure there is no movement
between the wheel flange, the rear wheel and the axle tube.
If play is noticeable between these components you must replace the entire rear wheel
drive assembly (complete with flange). Replacing the splined wheel flange only will not
solve the situation, because in all probability the splines on the axle tube will have suffered
some degree of wear as well. If you are in doubt, you are requested to contact your
respective Aftersales Business Consultant.
Warranty: Covered under the terms of the New Motorcycle Limited Warranty.
Important Note: Screw 1 is a drain
plug for repair-related oil changes; it is
not for checking the oil level. When filling
the rear drive assembly with oil,
pour in the defined quantity (0.25 l for
initial fill, or 0.23 l for oil changes)
through the bore for the ABS sensor.
We highly recommend using BMW
Super Synthetic Gear oil. 75W 90, P/N
07 51 0 394 082
Blame MaddBrit
pluric is offline   Reply With Quote
Old 04-17-2009, 09:17 AM   #2299
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 8,971
Originally Posted by Roostre
Saturday April 18th. Knolls, UT- 40 miles this side of Bendover.
Big bikes launch at 12:00 or so.
Bring your 50cc and race in the fast fiddy race to be held right after the big race ends- I'd guess around 3:00 p.m. or so.
I'd love to see Infidel all geared up on a 50!!
OK, but it was NOT pretty.......
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Old 04-17-2009, 10:07 AM   #2300
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,800
Sweet! According to Tuckerdt we should get together and ride sometime.
(I see you have lost some weight too!)
Old 04-17-2009, 10:13 AM   #2301
The Walrus
The Walrus's Avatar
Oddometer: 8,971
Originally Posted by pluric
Sweet!
ya.......almost 5 kg.......I count in kilos and military time just fo' you....
Old 04-17-2009, 06:30 PM   #2302
frog OP
frog's Avatar
Oddometer: 2,774
I was cleaning out the garage today and found a few 990 parts. If any utard wants them before I put them on fleamarket.
A set of crash bars used well and many times and needs to be re aligned to fit on bike . Free to someone that will use them well and often. If you take these you have to take the plastic lower tank protector I have right side and it's new in the plastic.
Come and get it.
257x Solo Baja 1000
Old 04-17-2009, 07:40 PM   #2303
dbltrbl
dbltrbl's Avatar
Oddometer: 46
Come and get it.
I can put those crash bars to good use.
Ok maybe not nearly as good as you but they will get used
dbltrbl is offline   Reply With Quote
Old 04-17-2009, 07:51 PM   #2304
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,800
Come and get it.
What did you hit at Starbucks to bend them?
Old 04-17-2009, 10:29 PM   #2305
BrShootr
BrShootr's Avatar
Oddometer: 907
Soooooo.....
anyone riding Sunday or am I clear to get shitfaced Sat. night?
shots at red neck party
As long as I am the big spoon!!!
BrShootr is offline   Reply With Quote
Old 04-17-2009, 10:47 PM   #2306
frog OP
frog's Avatar
Oddometer: 2,774
I was doing a helmet shirtless wheelie in the parking lot and dumped it.
I'm heading out to knolls in the morning on the se. Probably leaving around 8:30-9:00 if anyone is interested. Planning on hitting dirt in grantsville or delle and trying to go the rest of the way to knolls on dirt. Need to be there around 10:30 to sign up for the race so it won't be a scenic ride. six six niner two niner fiv eight.
257x Solo Baja 1000
Old 04-18-2009, 08:17 AM   #2307
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,516
Do you need a pit-crew?
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 04-18-2009, 09:26 AM   #2308
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,800
Originally Posted by BrShootr
Soooooo.....
I thought "Shitfaced" was your regular look.
Was it hard to photoshop breasts on that guy???
Old 04-18-2009, 09:47 AM   #2309
SkiFastBadly
A beer? Yes, please
SkiFastBadly's Avatar
Oddometer: 1,528
Soooooo.....
Only a pussy would think those two things are mutually exclusive.
The crows seemed to be calling his name, thought Caw.
2008 Buell Ulysses
2008 Triumph Scrambler
2004 HD Heritage Softail
SkiFastBadly is offline   Reply With Quote
Old 04-18-2009, 12:06 PM   #2310
BrShootr
BrShootr's Avatar
Oddometer: 907
True. They're not exclusive, as we proved in Mesquite....or....rather, "I" proved in Mesquite. Infidel didn't even finish his flask of tequila!
Anyway, Sunday should be a good day to ride. 5 mile on big bikes?
Times are GMT -7.   It's 01:13 AM.
