05-27-2008, 04:25 PM
#1 |
Bring da amber lamps
Oddometer: 1,044
Any TE450 or TE510 owners here?
I think I have a new all in one dream bike, and was curious if any TE450 or TE510 owner care to share their insights/words of caution to the rest of us. I like the 6sp e-star w/kicker backup, and the 250ish lbs and all with a plate. That is just awesome, and the price ain't bad either. Not sure about the whole fuel injection part though. Let's here what you have got to say.
05-27-2008, 05:01 PM
#2 |
Dirty Old Mudder
Oddometer: 3,930
I've got an 06 TE510, regeared for more friendly pavement duty, a few protective parts & a 3.9 gal tank. I love it, for my needs its perfect. weighed on bath scale under skidplate with a full tank of gas it was 305 lbs. No idea on the new 08 injected ones though, but if you check the Husky forum on Thumpertalk, new 08 owners can chime in.
P.S. there was a TE510 & a TE450 that went cross country on the TAT last year. No issues to speak of cept that I was suppose to be part of that ride & couldn't
We spend our lives chipping away at our ignorance :wisdom by Dakez Friendship is like peeing your pants, everyone can see it, but only you can feel the true warmth.: wisdom by ?? Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet 06 Husky TE510 |
05-27-2008, 05:38 PM
#3 |
Oddometer: 1,044
Thanks for chimin in Ruffus. Saw you in the Husqvarna TE 450 - Info needed thread.
05-27-2008, 07:07 PM
#4 | |
gooligan
Oddometer: 4,316
05-27-2008, 07:32 PM
#5 |
Dirty Old Mudder
Oddometer: 3,930
I wish, only report from them was adding a wee bit on to a RR from other guys who rode the TAT & they met on the way. I could be wrong & just missed it. But I did search for quite a while & came up empty. My minds a little fuzzy & lost all PM's while we were planning it, guys names were"LOUGE", "SHERPA", & Norm" can't recall his forum name
We spend our lives chipping away at our ignorance :wisdom by Dakez Friendship is like peeing your pants, everyone can see it, but only you can feel the true warmth.: wisdom by ?? Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet 06 Husky TE510 Ruffus screwed with this post 05-28-2008 at 11:22 AM |
05-28-2008, 04:37 AM
#6 |
Oddometer: 1,044
Puffy, thanks for the info. For the $200 difference, the 510 seems like a no brainer. Do you DS your bike much? My XR400 is plated, and aside from the knobbie vibes, is a real joy on the street. What are the vibes like in the butt, bars, and pegs (motor wise)? I find that the XR is not nearly as vibey as a lot claim it is, and have no issues doing all day in the saddle (cept the seat gets old after a few hours). I also have a 95 YZF, and it is a great bike too, but not nearly as fun as the XR. I could only imagine how much more fun I would have on a lighter bike with more power and a 6spd.
I haven't outgrown the XR, but the Husky looks real nice on paper. I am curious what it's like in the SM version.
05-28-2008, 07:15 AM
#7 |
Dirty Old Mudder
Oddometer: 3,930
I have been using mine for commuting & only pavement commuting because of a lingering injury. Regeared to 15\48 from the factory 13\50. It rev's about 5800 @ 60 mph, redline is 10500 rpm. Most of my commute is @ 55 to 60 mph for 30 miles each way. No issues in 1800+ miles. My valves are still in spec, but I'll be shimming them to the outer limit of spec just for piece of mind.. & They're very easy to check & adjust.
The factory TE610 rack or even the PMB rack can be adapted to the 510. Factory headlight sux, I put on a Buell assembly thats a major improvement @ reasonable cost. The seat ain't comfy, but after a week of daily commute my butt adapted Adding secondary rim locks front & rear smoothed out over 40 mph hop, it now rides as smooth as a DOT knobby can. P.S. 06 & up TE 510 has a cush clutch assembly, I don't know about earlier models
05-28-2008, 11:18 AM
#8 |
Dirty Old Mudder
Oddometer: 3,930
Found a small link with some pic's of Louge's TAT trip
http://www.thumpertalk.com/forum/sho...22#post5334522 hope it works P.S. hope you don't mind Louge
05-28-2008, 02:52 PM
#9 |
Oddometer: 120
2007 Te510
I admit to owning a TE 510!!!
My bike has been extensively modded for true dual sport use: Photo at sea level crossing into Death Valley in April. I bought the bike used, so not sure how many miles/km on it in total. I have put 5300 km on it now, about 50% off road and 50% on. It also takes me to work everyday in Vancouver, about 70 km round trip all on pavement. Here are the troubles I have had to date: Clutch slave cylinder failed, needed a replacement. May have been my fault, as I had been running drug store mineral oil in the hydraulic system. It was fun to be able to say my bike ran on laxatives.... Radiators had a couple holes and caused bike to overheat. My fault, or maybe the previous owner's. I don't know what caused the holes, they are fixed now. Oil leaking from a breather hose on the right side of the engine. Finally fixed with a rubber spacer and some high temp silicone. When loaded with gear, the bike likes to fall over on its side. Crappy kickstand design. Oh well, now I carry some cord to tie it up to trees, rocks, signs, other bikes etc. Honestly I wish the transmission was wider ratio. Lower first gear, higher 6th. I would get one again in a second. Its not the most comfortable bike for long distances. Whatever. 1.5 months ago we completed a long off road tour, and ended up with 700 km of pavement at the end to get back to the truck. No problems highway cruising at 90 kph, but the seat was beginning to hurt! Finally put the bag I had been using to carry drinking water on top of the seat, sat on that, problem solved. Should we have a TE 450/510 owner's sign-in thread, in imitation of the 610 thread??? Brian
____________________________________________ Brian Pegg Vancouver, BC Husky TE510 |
05-28-2008, 03:39 PM
#10 |
Oddometer: 185
Can't comment on the FI, as I have an '07. Have not heard anything bad about it tho', and have heard that it has been on one of the models in Europe for a year or two. I think the TE610, but can't say for sure.
I have an '07 TE450 Euro. My take on the bike is this: It is a racebike with a plate. I use it to connect trails and ride AMA Dual-Sport rides, but in my opinion it would not make a good DS/Adventure bike. The 6 Sp gearbox is good off-road, but limits the bikes top speed quite a bit on road. That is unless you don't mind revving the guts out of your bike riding down the road. I had to make some 'adjustments' to the bike after buying it. I suppose all bikes are a bit like that and require the owner to 'personalize' them, but a few things should have been corrected at the factory in my opinion. It's fast, it's responsive, and it gets traction like nothing I've ever ridden. The TE450 has a bit of a hit which makes it a blast to ride, but does not make it a handfull in tight stuff. Mine came from the dealer as the most perfectly jetted bike I've ever ridden. It makes close to 50hp. Off-road the bike's a stud. On road, for speeds over 50 mph or so, the TE610 would probably be a better choice. But that would be a personal opinion, as it's all in what you like and need. My TE is the best bike I've ever ridden, but it's not quite perfect.
05-28-2008, 06:18 PM
#11 |
Oddometer: 884
Thats what I want for my next bike(te450).Have been looking at them for a while now.Hopefully now that BMW owns them,we will get a dealership around us.I guess I will try and sell the KTM to Tim,sounds like you already have your mind made up,so I guess you don't want to buy it.I have to admit,I will keep the KTM for 2 or 3 more seasons.
05-28-2008, 07:00 PM
#12 | |
Oddometer: 1,044
05-28-2008, 07:17 PM
#13 | |
Oddometer: 655
![]() And here is Sherpa who was along for the ride also on his TE450.
05-28-2008, 07:39 PM
#14 | |
Dirty Old Mudder
Oddometer: 3,930
05-28-2008, 08:24 PM
#15 |
Twisted Throttle
Oddometer: 1,673
I've got a new 08 TE510 and am very impressed with the bike.
Stock gearing of 13/47 will put you over 90 mph and quickly. For dual sporting you can easily swap in a 14 or 15 tooth counter. Did 230 day ride last Saturday with the 14/47 gearing and could idle along on the pavement sections at 55 to 60 mph. Offroad dirt roads that were curve-less I cruised at 60 to 65 mph. Fuel economy was ~ 40 mpg for the entire ride which included pavement, dirt road, fire road and double track. I also exercised the throttle and approached mid 80's multiple times. Yesterday I stuck the 15 tooth on and could easily cruise along at 65 mph on the interstate at RPMS not much above lugging speed. The only negative I've experienced is the saddle for extended duration riding while seated on one spot and limited fuel supply with the stock FI tank. I've added a front Acerbis .8 gallon tank on the rear sub-frame to extend my range which is ~100 miles in dual sport mode as a substitute until a larger dessert tank hits the market. The front light is the same problem found on the TE610/ For fast offroad throttle action .it is a dream come true.. BTW, this TE510 has the power up kit with Arrow exhaust, revised fuel mapping and throttle stop removed. Valve check was done at 600 miles and required NO adjustment what so ever. some photos ![]() ![]() ![]()
Fast1 screwed with this post 05-28-2008 at 09:50 PM |
