Old 12-18-2012, 08:27 AM   #601
Beez
Given to fly
Beez's Avatar
Oddometer: 5,794
Originally Posted by Nous Defions View Post
The headlight is a 6 inch Rigid LED headlight.
Did it just bolt right into the stock shroud or did it require modification? What about wiring?
Beez is online now   Reply With Quote
Old 12-18-2012, 08:47 PM   #602
Nous Defions
Oddometer: 7
The headlight bolts right in. The headlight comes with the male and female end of the plug that your solder to the headlight low beam wires.
Nous Defions is offline   Reply With Quote
Old 12-19-2012, 09:14 AM   #603
Beez
Given to fly
Beez's Avatar
Oddometer: 5,794
Wow, that sounds easy and it must be a huge improvement in light output. I have an '07 with the older headlight shroud and have wanted to get the newer one just because I think it looks better. But add that Rigid light and it becomes a functional improvement as well.
Old 12-22-2012, 02:41 PM   #604
biggsxr
Oddometer: 40
Is this the official TE510 Thread?
I just bought a 2007 TE510. A bit rough , but running.
# 1 big issue...
Do I have any chance of finding a used Clutch Case and cover?
biggsxr screwed with this post 12-22-2012 at 09:35 PM
biggsxr is offline   Reply With Quote
Old 12-22-2012, 04:28 PM   #605
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
J & B Weld?
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 12-22-2012, 06:47 PM   #606
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,774
The infamous kickstart crack....another example, not really amenable to a JBWeld fix, I wouldn't think.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 12-22-2012, 09:42 PM   #607
biggsxr
Oddometer: 40
This is beyond JB weld, epoxy, etc, Mine is totally detached as well, cracked top to bottom, plus it propagated to the clutch cover. I'm not sure about the inner RH Case yet.
More pics;
I can TIG weld, so I'll give it a go. I just brought it home today, so I'm beginning my search for knowledge; Factory Manuals, owner's manuals, "they all do that" knowledge. Seems they all self destruct upon kick start eventually... suck.
Old 12-22-2012, 11:41 PM   #608
benwiggin2
benwiggin2's Avatar
Oddometer: 2,119
CafeHusky manual thread.
http://www.cafehusky.com/threads/hus...nd-more.17158/
benwiggin2 is offline   Reply With Quote
Old 01-04-2013, 05:45 PM   #609
cybernetics
Oddometer: 145
2007 and 2010 TE450
I just bought a 2007 TE 450. The chassis, forks and other parts have a lot of rust on them but it works well. I am wondering why it feels a lot faster than my 2010? It makes less noise and runs stronger. It seams that it is geared a little shorter and that may be the difference. Both are full power as far as I can tell.
cybernetics is offline   Reply With Quote
Old 01-11-2013, 01:53 PM   #610
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,774
2008-2010 TE 310, 450, 510
Watch for rubbed wire bundle into the ECU where it rests on the fuel injector bracket. On mine, the Brown with white stripe wire had a bare spot and was grounding to the injector bracket. This wire is connected to:
Dashboard, DC relay, RH switch, Main switch, Pump relay, Fan relay, ECU interface, ECU, O2 sensor
The short was weakening my spark to the plug, the plug fouled badly, I fixed the wire and put my old 10,000 mile plug in, and it started right up.
Old 01-14-2013, 12:43 PM   #611
dirtfarmerrich
Richard
dirtfarmerrich's Avatar
Oddometer: 106
Tank Problems
I. Just put a Safari tank on my 2009 TE 510 Everything fit well except the wiring to the in tank fuel pump was to short. I had to unwrap the wiring harness and reroute the pump wires. Has anyone else had this problem. Also the seat is a lot harder to put on. I,m not sure what to do about the seat fitting because the tank can not be moved forward and the seat needs to be moved farther forward to be able to latch it.
dirtfarmerrich is offline   Reply With Quote
Old 01-14-2013, 12:46 PM   #612
benwiggin2
benwiggin2's Avatar
Oddometer: 2,119
I have to gently pry my IMS tank forward to get it to fit over the (2) steel studs that are on the frame, the ones with the rubber grommet on them. Once my tank is properly seated, the seat will fit as it should.
Old 01-14-2013, 01:17 PM   #613
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,814
I didn't have any issue installing the tank at all, including the wiring, but the Corbin seat did not fit, no matter what, and the stock seat needed the front slot dremeled out a bit to make fit.
drrags is offline   Reply With Quote
Old 01-14-2013, 01:43 PM   #614
dirtfarmerrich
Richard
Oddometer: 106
Tank
I think I need to Dremel the front slot on the seat and it will fit better. Thanks for info.
Old 01-19-2013, 07:27 AM   #615
OU812
Legend in my own Mind!
OU812's Avatar
Oddometer: 9,494
I looked at an 07' 510. Really like the look and having 1000 miles it seems to run right.
The Akropovic? sounds nice and not obtrusive.
Already re sprung for my weight.
Hard not to just lay down the cash.
Great thread folks!
This would be my 1st Husky.....
AMA, NRA, AFL-CIO Forrest City.
Getting Old ain't for pussies....................Lorazapam
Even when you do something right people will think you didn't do anything at all.
OU812 is online now   Reply With Quote
Times are GMT -7.   It's 10:31 AM.
