Old 01-22-2013, 03:35 AM   #616
Seppo
Oddometer: 502
no fan?
okay, i have a problem.
I installed a IMS tank on my 07 TE450 some time ago and i´ve been riding around without a fan since then. latley, on a tight and sometimes steep singetrack, the bike boiled over. that doesn´t really concern me much, but i have a trip in mind that will take me to the sahara dessert. altough it is in winter, the temperatures will climb to maybe 30°C and riding in the sand (not riding big dunes or anything) will for sure rise the enginge temp.
so, what can i do to improve cooling (special coolant?) or do i have to install a "push" type fan in front of the radiator?
cheers
josef
00' Buell M2, 07' Husky TE 450, 95´ Ducati 916, 92´Ducati 900SS, 03´ KTM 950 ADV
Seppo is offline   Reply With Quote
Old 01-22-2013, 06:26 AM   #617
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,775
You can try different mixtures of several "engine ice" type of products, but a fan will mean you can skip all that experimentation and just switch the fan to "on" when the bike is moving less than 10mph.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 01-22-2013, 06:34 AM   #618
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,076
cheers
josef
An oil cooler?
Here's a link to one such application. Looks like the pictures are gone though.
Husky oil cooler adapt
Nevermind I found a picture link.
http://s163.photobucket.com/albums/t...Rally%20Husky/
Doesn't show much of the oil cooler though. Decent build though
P.S. don't forget about changing the coolant "T" fitting with an UPTITE "Y" fitting, there's also a high volume water pump impellor available, and always keep your containment bottle half full to prevent the plastic from melting in case of an overheat purge. One more thing, change the rad cap to higher BAR rating. I believe one from 2 smoke Kawi 80 cc works perfect. Can find out for sure if you want that info.
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus screwed with this post 01-24-2013 at 08:53 PM
Ruffus is offline   Reply With Quote
Old 01-22-2013, 07:50 AM   #619
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,814
I had the original Triumph T595 in Tucson, AZ and they were notorious for overheating. After much discussion I used Redline Water Wetter and pure water; no antifreeze. It made a world of difference. Antifreeze is mis-named coolant because it hurts heat dissipation. I'd give that a try before I tried more expensive options. .
cheers
josef
drrags is offline   Reply With Quote
Old 01-23-2013, 02:27 PM   #620
Beez
Given to fly
Beez's Avatar
Oddometer: 5,796
I have an 07 450 as well and an IMS tank and tried to install a fan. I disconnected it because it was draining the battery when the bike was off. I probably just had it connected to the wrong wires but electrical has always been my weak point.
I ordered a pusher fan from eBay and installed it as such.
The radiator guards are from Big Fat Guy Racing, or maybe it's Old Fat Guy Racing. More photos of it are in the same gallery as the one I posted.
Beez is online now   Reply With Quote
Old 01-23-2013, 02:33 PM   #621
benwiggin2
benwiggin2's Avatar
Oddometer: 2,119
What the hell you went to DAKAR in 2000? Awesome!
benwiggin2 is online now   Reply With Quote
Old 02-06-2013, 08:46 AM   #622
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,775
Looks like I may have a leaking head gasket, at 12,400 miles, on my 2010 TE 450. I had been plagued by what I thought was water in the gasoline for several weeks now, but the problem would only really happen after I had put the bike away after a day's ride and then go to start it later that night or the next day, it would be water logged. I'd get it cleaned out, with the decomp lever and pulling the plug, sometimes draining the tank, but now, after several different sources for the gas and using regular gas which is supposed to be less contaminated than premium, I am still getting water logged, so it's gotta be the head gasket, even tho there are no bubbles in my rad water stream, and my oil looks fine, it must be a very small leak that transfers small amounts of water to the combustion chamber, usually under pressure when the bike is cooling down. I am going to use Treadstone's tip about removing the cylinder studs to do the gasket swap in-frame. I think I'll ride one more weekend and do this job next week....lazy butt that I am...
http://www.treadstonecycles.com/Tech...Husky_Tech_Tip
AustinJake screwed with this post 02-06-2013 at 09:21 AM
Old 03-01-2013, 08:18 AM   #623
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,775
Finally fixed it, took 10 days instead of 9 hours, an electrical gremlin reared its ugly little head after the re-install, then I messed up on the cam timing because I used a slightly thicker head gasket, then I messed up the cam timing again since I believe my cam marks are not right, as a mech, I grade about a D-...., finally got it wrapped up and its running as good as ever. Below are some pics from the head gasket replace. The leak was in between 2 of the layers in the 3-ply gasket. The 2 gasket pics are the 2 sides of the single leak into the combustion chamber. The 3rd pic is where I thought I saw some discoloration from coolant in the piston crown.
AustinJake screwed with this post 03-01-2013 at 08:31 AM
Old 03-01-2013, 08:25 AM   #624
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,814
Dang, what a hassle. I'm glad you got it all back together and working
Old 03-01-2013, 08:34 AM   #625
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,775
I DID use the "in-frame" technique that I referenced in post 622 to get the head out, that save a ton of time and effort, versus pulling the engine. I had the head off in 3 hours.
Old 03-01-2013, 08:42 AM   #626
benwiggin2
benwiggin2's Avatar
Oddometer: 2,119
Jake, what's that black thing hanging near the back of the front fender?
Old 03-01-2013, 09:02 AM   #627
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,775
My rad blocker made from a black plastic trash can from wally world?
Old 03-01-2013, 09:20 AM   #628
trekkingjon
trekkingjon's Avatar
Oddometer: 14
YEs oh Yes I have a 510
Twin Falls Idaho, 2008 TE 510.
currently only 600 miles on the machine. Really would like to get out and do more this year.
IF anyone has suggestions, I am looking for a slip on exhaust.
3 dealers said they have nothing that will fit this bike.
Thanks for all your pics and post.
Ride More 2013.
trekkingjon is offline   Reply With Quote
Old 03-01-2013, 09:22 AM   #629
benwiggin2
benwiggin2's Avatar
Oddometer: 2,119
Ride More 2013.
Any pic's? If the machine has been "powered up" then the Arrow can that came with the power up kit is fine IMO.
Old 03-01-2013, 09:23 AM   #630
benwiggin2
benwiggin2's Avatar
Oddometer: 2,119
Wow! How cold does it get where you ride?
Times are GMT -7.   It's 01:04 PM.
