Old 05-05-2012, 10:04 AM   #106
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,013
Funny that this bike is regarded as heavy....even though a new C14 or FJR weigh 100 lbs more,LOL
XR200R
KTM 950SM
CBR Fireblade-GTU Endurance racebike
1996 YZF 600-Lost Era racebike
1999 R6-Rookie Challenge racebike
omnivore is offline   Reply With Quote
Old 05-05-2012, 11:40 AM   #107
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
Comparing wet weight to wet weight, the difference is more like 60 pounds - Still quite significant, but then we are talking about bikes with bigger engines, bigger fairings, longer wheelbases and 40-70% more power. A better comparison might be the Sprint St, which is around 80 pounds lighter (and has 25% more power - oops!) , or the contemporary ZZR1100, which was about 50 pounds lighter with 45% more power
Like I said, I'd love to see Yamaha have another go at the RADD concept.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 05-05-2012, 03:34 PM   #108
cobrajunkie
Oddometer: 7
Not trying to start an argument and I'm certainly biased with respect to my new-to-me GTS but not sure I really understand the comment..."it has far too many serious flaws."
Wet weight specs for similar sport-touring bikes:
FJR1300 644 lbs
Kawasaki C14 688 lbs
BMW1600GT 703 lbs
GTS1000 615 lbs
cobrajunkie is offline   Reply With Quote
Old 05-05-2012, 04:12 PM   #109
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
Originally Posted by slartidbartfast View Post
Comparing wet weight to wet weight, the difference is more like 60 pounds - Still quite significant, but then we are talking about bikes with bigger engines, bigger fairings, longer wheelbases and 40-70% more power. A better comparison might be the Sprint St, which is around 80 pounds lighter (and has 25% more power - oops!) , or the contemporary ZZR1100, which was about 50 pounds lighter with 45% more power.
Um... no. Your examples are a generation or two separate from the GTS which was designed in the early nineties. Its actual contemporaries would be the likes of the Katana 1100, the ST/CBR1100, and the ol' Concours, which had similar power to weight ratios.
JamesG is offline   Reply With Quote
Old 05-05-2012, 04:52 PM   #110
cobrajunkie
Oddometer: 7
Dont burst my bubble man! So in love with this ride and now searching for red one. I just spent two hours detailing it and getting ready for a sunny Sunday. Power to weight is 6.15:1 My four wheel cage is 2400 pounds wet and 500hp or 4.8:1. I have spare underwear in the trunk.
Old 05-06-2012, 07:54 AM   #111
slartidbartfast
Oddometer: 4,863
I picked one modern bike and one contemporary - The ZZR1100 came on the market a couple of years before the GTS.
I LOVE my GTS! ...I'm just not blind to its flaws. Going to take it out today I think.
Old 05-19-2012, 06:17 PM   #112
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Originally Posted by advNZer? View Post
i always wondered why they didnt put a shaft drive on this bike
I wish they did I would sacrifice some more HP from the detuned FZR engine already about minimum needed or wanted HP
rotten is offline   Reply With Quote
Old 05-20-2012, 06:45 AM   #113
ec90t
Oddometer: 232
Please do a nicer job of tucking in the cotter pin. That looks aweful
Here's a neat project that I did back in college in a composites class. A kevlar clipboard with a picture from a '93 sales brochure.
ec90t is offline   Reply With Quote
Old 05-20-2012, 07:21 AM   #114
Lakeguy556
Lakeguy556's Avatar
Oddometer: 112
As a mechanic, my absolute biggest pet peeve in the world is improper cotter pin installation. Drives me up a fucking wall. This is how its done people:
The FAA recognizes one preferred method of installing cotter pins which we will cover here. There are some optional methods when space does not allow for the preferred method and those optional methods can be found in AC43.13-1. First and foremost the cotter pin must be of the correct size. If not called out, a good rule of thumb is the 2/3rds of the hole diameter but in any case the cotter pin should fit neatly into the hole, with very little side play.
If you look closely at a cotter pin you will notice it has a long leg and a shorter leg. The long leg is intended to go over the top of the bolt or fastener and the short leg along-side the nut.
1. Insert the cotter pin with the long leg on top.
2. Seat the bulbed end of the cotter pin securely into the nut and bolt.
3. Using duck-billed or needle nosed pliers, grab hold of the upper leg and in one fluid motion bend to a vertical position.
4. Using side-angle cutters (dikes- to most of us) trim the short leg so as not to cut into the structure when bent.
5. Bend the short leg down vertically along-side the nut.
6. Using your dikes trim the remaining long leg so it will lay 1/2 to 3/4 across the end of the protruding bolt or fastener.
7. Bend the remaining leg over top of the bolt or fastnener ensuring it is flush so as not to become a snag.
Here are some general rules that can help you in installing and inspecting your cotter pin installation.
a. The prong leg bent down should not rest against the surface structure or washer.
b. Never reuse a removed cotter pin, use a new cotter pin at each installation.
c. If you mess up on the installation, remove the cotter pin and give it another go until it is installed correctly.
d. The prong leg bent over the bolt end should not extend beyond the bolt diameter. This can cause a snag and injure you or someone else.
e. All prongs should be bent over a reasonable radius. Sharp-angled bends can cause breakage. Lightly tapping with a light mallet can assist you in bending the prong legs on larger diameter cotter pins.
Lakeguy556 is offline   Reply With Quote
Old 05-20-2012, 08:16 AM   #115
cobrajunkie
Oddometer: 7
DOH!!! Busted by the cotter pin police.
Old 05-20-2012, 11:41 AM   #116
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Nothing like the assumption that how a picture looks when it was taken is how it remains.
Old 05-20-2012, 11:46 AM   #117
BikerGeek99
Horizon Chaser
BikerGeek99's Avatar
Oddometer: 1,347
Thank God for the man who put the white lines on the highway.
- Michael Stanley
- '09 FLHTCU
- '04 FJR1300
BikerGeek99 is offline   Reply With Quote
Old 08-08-2012, 07:46 PM   #118
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Another link for gts owners http://www.gummycarbs.com/wiki/index...amaha_GTS-1000
Found this handy in finding fuel filter replacement.
Old 08-08-2012, 08:04 PM   #119
GrahamD
GrahamD's Avatar
Oddometer: 5,306
I don't care what anyone says, this is one cool bike. Pity there are bugger all around where I live.
They had the audacity to charge European money for it so hardly any one bought it.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 08-09-2012, 09:40 AM   #120
wannaklr
wannaklr's Avatar
Oddometer: 7,458
Everytime this thread gets bumped I go looking for a 94 with the Krauser bags.
And my DL is getting boring!
Back in Iowa!
I like my music like I like my women. Loud, angry and with bagpipes!
From Scottie Boy "If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle."
wannaklr is offline   Reply With Quote
Times are GMT -7.   It's 08:09 AM.
