Old 06-24-2008, 06:13 AM   #46
rnr
Simple. Fast. Paid for.
rnr's Avatar
Oddometer: 1,005
here's one I like
A nice little bar end mirror cleans up the topside.
I used 7/16th black plastic hole plugs from Lowe's to cleanly close the mirror holes.
This mirror mounts on the plastic between the grip and the handguard clip.
It is clear vision even at idle! at all speeds. Gives a good view to the rear, with just a touch of elbow and the saddlebag.
Get 'em here. Good, fast service. Good quality mirrors (sold in pairs.)
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
rnr is offline   Reply With Quote
Old 06-24-2008, 06:50 AM   #47
Skyclad
Original Bastard
Skyclad's Avatar
Oddometer: 5,751
Biggest problem that I would have with bar end mirrors is they vulnerability when the bike gets tired and lays down for a nap. More of a concern for those of us that like to get dirty with the Ulysses.
Do these bar end mirrors have any sort of easy fold or break away design built into them? I do like the look and the improved rear visibility would be nice.
Ignorance breeds Fear. Fear breeds Hatred. Hatred breeds Ignorance. Break the chain.
cancer
For some, a glue stick would be a better option than Chapstick
Skyclad's Wanderings - Bald Eagle Bastards - The Mountains are Calling, and I Must Go
KCCO
Skyclad is offline   Reply With Quote
Old 06-24-2008, 06:59 AM   #48
rnr
rnr's Avatar
Oddometer: 1,005
uh-huh.
No. They move around on a ball. Not like the slick one I used to have on my old Suzuki GS650G.
But two allen bolts, and it's off. Some guys mount them on dual-sports handlebars inboard of the controls. They are protected there, and you look under your armpit. But the shape of the Uly bar seems to negate that.
And it limits your backward view.
YMMV.
(Your Mirror May Vary)
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
Old 06-24-2008, 08:34 AM   #49
TREADMARKS
TREADMARKS's Avatar
Oddometer: 286
I have those mirrors.
They are cheap enough if you drop the bike.
I also added GRG lane splitter knuckles to allow them to fold back.
TREADMARKS is offline   Reply With Quote
Old 06-24-2008, 09:28 AM   #50
RedUly
Esse Quam Videri
RedUly's Avatar
Oddometer: 5,778
Can you elaborate on that? Did you have to modify anything or did they just bolt on?
The point is that one doesn't have to dismiss their sense of decency and diplomacy to make a point. - Luap
I think people who are that bad at lying are probably too stupid to be taken seriously. - #18
You're a slut. But you're cute, so it's ok. - MayQueen
RedUly is offline   Reply With Quote
Old 06-25-2008, 06:49 PM   #51
rnr
rnr's Avatar
Oddometer: 1,005
they just bolt on
Instead of putting in the end-of-the-bar plug, I just opened the thing up, and mounted it on the plastic widget on the end of the handlebar. You know, the one that the handguard clips to?
There is just enough room for the clamping part to bear down there. Fits perfect, in fact.
The mirror does tend to rotate on the plastic if you bump it.
Which is a good thing, since I'd forgotten how vulnerable they are out there.
Here it is crossing the Mackinac Bridge for breakfast on Sunday.
I'll try and get a farkle report up on teamuly.com tomorrow, and cross link here.
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
Old 06-25-2008, 07:16 PM   #52
rnr
rnr's Avatar
Oddometer: 1,005
Bar-end installation for Buell Ulysses
They install like this: (I put one on; used another on a Suzuki DR650.)
Class dismissed.
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
Old 06-25-2008, 08:55 PM   #53
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,355
Those plastic plugs you attached the mirror to are pretty shallow. I pulled them to mount my Kaoke throttle control and it takes very little effort to remove them. Maybe a dab of RTV?.....
joenuclear is offline   Reply With Quote
Old 07-01-2008, 05:46 AM   #54
RedUly
Esse Quam Videri
RedUly's Avatar
Oddometer: 5,778
Thanks for the details!
Old 07-01-2008, 05:56 AM   #55
RedUly
Esse Quam Videri
RedUly's Avatar
Oddometer: 5,778
Just ordered a set!
Old 07-01-2008, 08:01 AM   #56
rudolf35
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
Handlebar weights
I am looking for a good set of handlebar weights for my 06 Uly. The only caveat is that I would like to keep my hand guards. Any ideas or suggestions?
rudolf35 is offline   Reply With Quote
Old 07-01-2008, 12:29 PM   #57
RedUly
Esse Quam Videri
RedUly's Avatar
Oddometer: 5,778
I assume you're trying to get rid of vibrations? If so, before going with the weights, go ride an brand new Uly. If you're 06 is more vibey, replace the front isolator.
I did mine this past weekend and I can't believe how smooth the bike is.
Old 07-02-2008, 06:02 AM   #58
rudolf35
rudolf35's Avatar
Oddometer: 797
Good idea
That is a good idea. The 06 is a used Uly (15k on the clock), in very good shape, but the front isolator could be worn down?!? Worth a check.
Old 07-02-2008, 06:16 AM   #59
rhinoWERX
Crikey mate!
rhinoWERX's Avatar
Oddometer: 870
I use the HVMP's with the handgaurds
Has worked well for the past couple of years
rhinoWErX
"Do you see what I see..."
IBA #30079
rhinoWERX is offline   Reply With Quote
Old 07-10-2008, 08:06 AM   #60
rnr
rnr's Avatar
Oddometer: 1,005
he's right ...
Joe, I thought you were overreacting.
But that plug does tend to pull out.
Thanks for the tip!
RNR
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
Times are GMT -7.   It's 11:11 AM.
