Old 07-10-2008, 09:10 AM   #61
rnr
Simple. Fast. Paid for.
rnr's Avatar
Oddometer: 1,005
Well, did ya?
Originally Posted by 911racer
A good farkle is one someone did on badweb was add 1 1/2 inch spacers on the flat right side air scoop to help with engine cooling/air flow. I'm going o try it this weekend.
911racer:
Did you try this? Did it work?
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
rnr is offline   Reply With Quote
Old 07-10-2008, 10:40 AM   #62
rudolf35
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
Cool in TX
I do not know where, but somewhere on this site there is a posting showing the mounting of pancake fans in the oil cooler of a Uly.
Well, having access to a motherload of fans, I tried this and it does work. I mounted the fans BEFORE I mounted the right side scope and there was a most defenite decrease of "main" fan use driving around town. I can now sit at lights longer before the main fan comes on - I managed a 35 mile comute without the main fan kicking in, in 95F weather!
I want to thank the user who posted that idea!!
rudolf35 is offline   Reply With Quote
Old 07-10-2008, 11:51 AM   #63
Tefloncandy
Oximoran
Tefloncandy's Avatar
Oddometer: 194
Fan on the Oil Cooler Pics Please
Rudolf,
Show us pics of your setup and provide a part number list. I would like to look into this modification.
"No good decision was ever made in a swivel chair" George S. Patton
Tefloncandy is offline   Reply With Quote
Old 07-10-2008, 11:57 AM   #64
rudolf35
rudolf35's Avatar
Oddometer: 797
Uly light bar
While changing the oil on the Uly I had a good long look at the front of the bike. I noted that there is a very convinient spot to mount a light bar. The top front fender is mounted to the bottom tripple tree with two screws that are not part of the critical fork fasteners. Once these bolts and fender is removed there is a nice flat spot to mount a light bar.
The idea which I will build, once I am done with a planned road trip:
1 Take a 3/16" x 1" x 18" steel bar and drill two holes in it to match the spacing for the fender bolts on the bottom tripple tree.
2. Obtain (grade 8) bolts that are 3/16" longer than the stock bolts (might not even need to do that if the stock bolts are not to short) and mount the fender with the light bar behind it to the bottom tripple tree. There is a space, as is, between the fender and the bottom triple tree so that extra 3/16" will not matter.
3. Once the light bar is in place it is just a matter of locating the lights one plans to use. Mark the spot, take the light bar back off, drill it, rattle can paint it black and put it all back together - one easy light bar for about $5.00.
Old 07-10-2008, 12:20 PM   #65
rudolf35
rudolf35's Avatar
Oddometer: 797
Originally Posted by Tefloncandy
Rudolf,
I will add pictures once I am back from the road trip. As to the fans, they are two 2" x 2" x ~3/8" pancake fans. They run on 12v. You can get the fans at any electronics shop for about $6.00ea. There are several type of fans which have higher RPM and Cmf rating, get the ones that have the highest rating - the cost difference is pennies.
I ran a wire off the back of the cigar lighter down to the oil cooler. Wired the fans to the hot and ground, then, mounted them with copper safty wire through the oil cooler. The whole setup was a test that seemed to have worked itself into a permanent instalation. I was a bit worried that the fans would be "over spun" by the air rushing in but that has thus far, 2k, not come to pass. They come on when i turn the key on and go off when the key is set to off. The power draw is in the MaH.
The only thing to make sure off is that the fans BLOW on the oil cooler. If they are mounter to SUCK they will fight the air coming in while driving - not a good thing.
Old 07-10-2008, 12:29 PM   #66
longdog uk
longdog uk's Avatar
Oddometer: 292
Here is the link for the oil cooler fan thread...........
http://www.badweatherbikers.com/buel...38/317089.html
longdog uk is offline   Reply With Quote
Old 07-10-2008, 04:08 PM   #67
TREADMARKS
TREADMARKS's Avatar
Oddometer: 286
You're Quite Welcome!
TREADMARKS is offline   Reply With Quote
Old 07-10-2008, 04:16 PM   #68
TipsyMcStagger
TipsyMcStagger's Avatar
Oddometer: 1,023
You mean like this?
Contact GME. Hey sells them wth the bolts, shipped to your door for $35.
Tipsy
2008 Buell XB12X Ulysses
"There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy
TipsyMcStagger screwed with this post 07-25-2008 at 06:26 PM
TipsyMcStagger is offline   Reply With Quote
Old 07-15-2008, 09:01 PM   #69
Skyclad
Original Bastard
Skyclad's Avatar
Location: Moran Nation, confused as a baby in a topless bar
Oddometer: 5,603
Tipsy,
How are you controlling the PIAA's?
Ignorance breeds Fear. Fear breeds Hatred. Hatred breeds Ignorance. Break the chain.
cancer
For some, a glue stick would be a better option than Chapstick
Skyclad's Wanderings - Bald Eagle Bastards - The Mountains are Calling, and I Must Go
KCCO
Skyclad is offline   Reply With Quote
Old 07-15-2008, 09:03 PM   #70
RogueSoldier76
VooDoo 7
RogueSoldier76's Avatar
Oddometer: 7
Question...
Does anyone know the holding capacity(in liters) the stock hard luggage cases hold? Top and sides.
"The only Tyrant I accept in this world is the still small voice within me"
"There's room for all of God's creatures... RIGHT NEXT TO THE MASHED POTATOES!"
RogueSoldier76 is offline   Reply With Quote
Old 07-16-2008, 04:25 AM   #71
TipsyMcStagger
Oddometer: 1,023
Originally Posted by Skyclad
Tipsy,
Skyclad, I used the stock Piaa switch on a small homemade bracket mounted under the mirror stem.
I used the Piaa harness but modified it by removing several feet of unnecessary wiring and replacing the stock Piaa connectors with Delhi connectors.
The Piaa relay and the low beam HID relay are both controlled by the "Euro" light circuit.
Tipsy
Old 07-17-2008, 12:10 PM   #72
rudolf35
rudolf35's Avatar
Oddometer: 797
Originally Posted by TipsyMcStagger
You mean like this?
Tipsy
Thank you! I will send him a message; see what happens.
Old 07-19-2008, 05:45 PM   #73
rnr
rnr's Avatar
Oddometer: 1,005
Simple, cheap cruise control
Anyone got any of those ideas?
Didn't I read something somewhere about using a big o-ring?
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
Old 07-20-2008, 12:49 PM   #74
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,550
I have a Vista Cruise and a throttle rocker on mine.
Old 07-25-2008, 08:41 AM   #75
PSO
Oddometer: 196
Rudolf35 I also use HVMP weights on my 06 and also got a set for fiance's Scg. Noticable difference. Put them on bikes whe both bikes were fairly new. I would do it again.
PSO is offline   Reply With Quote
Times are GMT -7.   It's 12:34 PM.
