Old 09-03-2008, 09:30 AM   #31
G.Kennedy
G.Kennedy's Avatar
Oddometer: 1,850
Originally Posted by meat popsicle
.......................was to insert the spring into the carb, then connect the slide valve onto the cable, ...........
Ya might want to check that .... if I am reading your description correctly ... you have the parts backwards.
Pretty sure the spring goes between the brass part and the threaded part. Spring goes on the cable first then the brass part .... the tension of the spring holds the brass part in place while installing .... take a look at the microfiche
.... Pretty sure.
'00 R1100RT
'05 525EXC
'08 Hypermotard
IBA#11791
G.Kennedy is offline   Reply With Quote
Old 09-03-2008, 10:40 AM   #32
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,243
.... Pretty sure.
yeah you right GK... why didn't I think to look at the fische? well, at least the tank ain't back on yet. I'll go back and edit my post. OK, third time will be the charm.
meat popsicle is offline   Reply With Quote
Old 09-22-2008, 03:01 PM   #33
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
I guess most people know that the DR650 also uses the BST40 carb
Mine had phillips screws holding the bowl on.
They were a bastard to get off. I ended up liberally soaking them in WD40 before leaving them to sit for 20 minutes.
One head was mangled getting them out. Replaced with 2 allen head screws.
Kientech have a range of DR parts including a fuel screw which should fit all BST40
BurnieM is offline   Reply With Quote
Old 09-22-2008, 09:58 PM   #34
bmwktmbill
Traveler
Oddometer: 5,205
Burn,
If you get that stuck Philips screw, mangled head syndrome again, take a small needle nosed vice grips and lock on to the head of the screw...it will come loose easily. I carry a small needle nosed vice grips at all times.
Handy in many ways.
b.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 09-23-2008, 05:59 PM   #35
RightSpin
RightSpin's Avatar
Oddometer: 648
Laramie, consider yourself with groupie. That walkthrough just saved me a ton of time. I really appreciate it.
Steve
2005 R1200GS
2003 KTM 625 SXC
RightSpin is offline   Reply With Quote
Old 10-22-2008, 09:24 AM   #36
Gregarious
Gregarious's Avatar
Oddometer: 360
Air jets
Great thread -- I've been using it help diagnose a leak problem. This should definitely be on the LC4 Index.
One item I would add is the air jet:
http://rides.webshots.com/photo/1058...36995609fbyxiT
I didn't know what these were until other threads discussed 1.1 and 1.2 air jets.
F800GS, 250 XCF-W, 690 Enduro R
Gregarious is offline   Reply With Quote
Old 10-22-2008, 12:02 PM   #37
1stworks
dude
1stworks's Avatar
Oddometer: 1,615
sweet
Thanks for the post!!!
firstworks
1stworks is offline   Reply With Quote
Old 10-27-2008, 06:41 AM   #38
meat popsicle
Ignostic
Oddometer: 14,243
dump
Can't remember where I saw folks discussing fitting throttle cables to a carb and MacGuyvering the old 90 degree cable adjuster assembly onto the new cable, maybe because they didn't know about this:
http://www.sudco.com/100degree.html
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
Old 10-31-2008, 06:19 AM   #39
voidjava
n00b warrior
Oddometer: 3
how i can install this? i am trying but is too hard
voidjava is offline   Reply With Quote
Old 10-31-2008, 02:41 PM   #40
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
A bit of wd-40 or 2 stroke oil smeared on the o-ring.
NordieBoy is offline   Reply With Quote
Old 11-07-2008, 07:50 PM   #41
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Where might I find the bigger idle jet online?
Thanks for the write up, its time for a goin' thu'
found these:
http://www.motorcyclecarbs.com/MIKUN...P10376C798.cfm
and this
http://www.motorcyclecarbs.com/MIKUN...P10352C797.cfm
I think its the first one?
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly screwed with this post 11-07-2008 at 07:57 PM
Surly is offline   Reply With Quote
Old 11-07-2008, 08:03 PM   #42
meat popsicle
Ignostic
Oddometer: 14,243
Perhaps Sudco can be of assistance Surly?
Old 11-09-2008, 06:36 AM   #43
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Thanks, Maybe a phone call is in order. I didn't see the little holes in the pics like the version above. Id like to order the right stuff before I have parts al over the garage
Surly
Where is Surly?
Old 11-09-2008, 07:16 AM   #44
meat popsicle
Ignostic
Oddometer: 14,243
Isn't this the type?
Pilot Jets
VM22/210
Old 11-09-2008, 07:17 AM   #45
laramie LC4 OP
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,415
you can usually find the jets for these carbs at Kawasuzuki dealers or Harley shops. both of them use the mikuni carb for several models. you may try one of these places before ordering threw the mail.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Times are GMT -7.   It's 09:32 AM.
